Question about Sunpentown 9000 BTU Portable Air WA-9010E Air Conditioner
Sunpentown WA-9000E 9,000btu
Green Light is blinking with no noise, and not blowing cold air. Any suggestions on what it may be?
4 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: Why is my sunpentown WA-1210H portable AC not
Might be a dirty filter, a burnt compressor wire or a bad capacitor. Or it could be a bad thermostat.
Posted on May 10, 2009
daddyo742001
  • 70 Answers
SOURCE: My Sunpentown WA-1220E portable air conditioner is
Sounds like compressor failure, overheat or some other reason can't get started. Make sure everything is clear and unplug and let it set for a while and try again. If that don't help take it to shop.
Posted on Jun 28, 2009
2rns4u
  • 22 Answers
SOURCE: My Sunpentown WA-1210E airconditioner stopped
Have you checked the water container in the unit? It has a float switch that when it is full it will not allow the unit to run so that it will avoid spilling water on to the floor. Hope this helps 2rns4u <*{{{>(
Posted on Jul 22, 2009
Why did SPT Portable Air Conditioner stopped blowing cold air?
Unit needs to be taken apart and washed out , also check to see if motor turns freely by hand , clean base of unit fans / blowers and drain ports / channels . Check outdoor motor to see if bearings are tight or fan overheats and cuts off if so replace outdoor motor .
Oct 04, 2014 | Heating & Cooling
Hi my wa-121oe is not blowing cold anymore
hi.maybe your compressor not working maybe you need charge.
Jul 16, 2014 | Sunpentown WA-1210E Air Conditioner
Ac is working fine on cool then it goes to fan and the air aint cold anymore
Fan mode only moves the air around the Room it will not cool make sure your on a cooling only setting
Jul 03, 2011 | Sunpentown WA-1200E Air Conditioner
Need instruction manual for Sunpentown WA-7500M
You can get the manual on the link below I hop it will help you.
http://www.sylvane.com/images/productpages/sunpentown/manuals/WA-7500M.pdf
Good Luck and please rate 4 thumbs up for the free answer
Jun 19, 2010 | Sunpentown 7500 BTU Portable Air...
My Sunpentown WA-1210E airconditioner stopped working. It emitted several beeps and the power light is blinking continuously. When I unplug, wait a few minutes and replug in the unit, it shows the same...
Jun 29, 2009 | Sunpentown WA-1210E Air Conditioner
My Sunpentown WA-1220E portable air conditioner is not working. Comp light is flashing (red light). Any idea what could be wrong?
Jun 28, 2009 | Sunpentown WA-1220E Portable Air...
Air conditioner
filters blocked or fan cage full of dust cant pickup the air if this is a zoned system then maybe zone damper is stuck not letting the air through
Jun 20, 2009 | Sunpentown WA-1210E Air Conditioner
Why is my sunpentown WA-1210H portable AC not blowing cold air anymore?
May 10, 2009 | Sunpentown WA-1220E Portable Air...
Fan blows.. no cold air... no hot air exhaust blowing
This sounds like you either need to clean or replace the filter, but if the filter is some what new you might want to take a look at the coils just past the filter, if the coils do not have a shine to them then you might want to buy some coil cleaner (i found simple green or formula 50 works great), then you will have to spray the coils with the cleaner, let sit about 10-15 min, then give it a very good rinse with warm water. After that it should work like it is brand new. Enjoy!
May 28, 2007 | Sunpentown WA-1210E Air Conditioner
Sunpentown 9000 BTU Portable Air WA-9010E Air Conditioner Logo
Top Sunpentown Heating & Cooling Experts
Dan Webster
Dan Webster
Steve F
Pete Norton
Are you a Sunpentown Heating and Cooling Expert? Answer questions, earn points and help others
