Question about ASUS Original 19v 3.42a Ac Adapter Charger For N193 V85
Asus charger won't charge
Okay so i got this computer in june 2012 the charger stoped working in December 2012 I have no idea what happened to it The tip of the charger is very loose and bends i have to bend the cable along the tip in a certain way/direction to get it to charge and when it does charge it makes this fax machine noise + when it's done The tip of the charger is extremely HOT. Also it just starts charge off and on repeatedly. If it's connected the normal way ( direct ) it won't charge at all. ^ that area Will buying a new charger be the solution ?
  • Brian Jan 13, 2013
    i have tried other chargers (brick was way bigger ) and the tip still get's very hot
  • ASUS Master
  • 787 Answers
Stop using that charger. I sounds like you have a break in the wire and when you hold it in the right position, the two pieces touch and current flows. Unfortunately the heat is probably being caused by arcing and is a potential fire hazard.
Posted on Apr 11, 2017
My Asus LaptopModel X205Ta is fully dead and won't charge or turn on.
MF. Could be the new charger is faulty, return charger for exchange or refund. Battery could also be faulty, have it tested if you can by a computer tech. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
My laptop notebook will not turn on
my asus laptop wont even charge or turn on after it shut off mid windows...
Laptop Won Come On Even When Connected To Charger
Why Won My Laptop Turn On Even Though It Plugged In
Jul 09, 2016 | ASUS Computers & Internet
Nikon s6300 won't turn on
Coolpix Cameras are tricky to use with chargers. I will assume your USB Charger EH-69P is 100 - 240V 50/60 Hz so it CAN work in many places around the world with an adapter. Do not go over 240V or you could damage it.
These cameras like to have the power supply connected when it is on to charge - meaning if you have it connected and you plug the charger in the wall it will NOT charge. So if you plug the charger in the wall first and then plug the cable in the camera it will work. The camera is actually ON when it charges and I never REMOVE the memory card when it is ON.
When you have a dead battery. Plug the camera in and make sure the ON LED lights and the Charge LED flashes. Then don't mess with it. Let it charge completely (Charge LED stops flashing and is OFF) and then unplug it. It will turn off. Then later you can turn it on.
May 08, 2017 | Nikon COOLPIX Cameras
Battery won't stay charged and has been repalced twice since October
hi, you replaced the batteries twice? using the same charger, have you tried another charger ?, okay let me tell you about mobility scooter chargers, it quite complex but some chargers will charge your new batteries correctly due to resistance etc, it more complex than this however now as your batteries get older your charger maybe having a problem charging your batteries , not because they faulty, now this is due to internal resistance once again the batteries problem reappears within 3 to 6 six months , it could be just the batteries are not good enough , I have seen a whole combination of faults , please bear in mind there are some dodgy batteries out on the market....
1. first try another charger
Jan 19, 2013 | Pride Mobility Go-Go Ultra X 4 Wheel...
7" touch andoid tablet won't charge
It may be the charger has a loose wire. In that case a new charger would fix the problem. Mine has a problem with the charging port itself. I am fortunatly that my tablet is under warrenty they are going to replace the tablet for me.
Dec 27, 2012 | Nextbook Premium 7 Capacitive Touch...
My htc incredible s won't charge, I've tried
It sounds like the charging port on your phone is broken. This could have happened a number of ways. Either by dropping your phone, putting the charger in wrong, or taking it out wrong. If you call HTC(866-449-8358) and it is still under warranty they will probably fix it for free as long as it doesn't have any water damage( Otherwise you could also get a new phone.
Oct 19, 2012 | Cell Phones
2012 VW Jetta TDI battery won't hold charge and car only clicks and won't start
You need to charge your battery up more. Either get a battery charger or leave the jumper cables hooked up for a longer period of time.
Your battery was probably completely dead. You might even need a new battery...they really don't like to be completely drained.
Oct 09, 2012 | 2012 Volkswagen Jetta TDI Sedan 2.0L...
My asus laptop won't turn on and so I have it
may be the wire of the charger has got defect in it. check thoroughly. If your charger is OK it is problem with your motherboard.Replace it to get rid of the problem.
Feb 08, 2012 | ASUS Computers & Internet
My samsung gt 15500 won't charge up. It was working fine 2 days ago and yesterday i brought the usb lead to work with me to charge it with my computer. Nothing happened when i plugged it in so i...
If the phone was totally dead before it refused to charge initially, then the refusal to charge is due to the fact that there was no residual charge left to bring it to a charge, because the battery completely died.
To fix it, kick start the charging process.
Remove the battery, and using a universal charger (desktop charger) charge the battery for say 10 minutes, before re- inserting the battery to the phone and continuing with the normal charging process.
If this does not work out, then problem is with the charging port. It has to be replaced. This can be done by nearby local phone repairers.
Hope it helps?
May 12, 2011 | Cell Phones
My battery for canon camera 550d flashes orange when charging, its been 4 hours now and it hasnt turned green yet.. I am charging it first time.. is this normal
Okay what happens sometimes is the charger gets into a feed back loop. What to do is remove the battery unplug the charger wait a few seconds (Maybe 20/30) plug the charger back into the outlet and then put the battery back in the charger. It should start to charge again and a few minutes later go to the blinking for full charge green.
It'll happen the other way as well meaning if the battery gets a memory (they say they don't but they do) you need to unplug the battery let is sit till it's cool and put it back on charge again. I've had this problem many times and have put it on charge and back off several times with in 15 minutes before it started to charge as it should.
Also these batteries do have a life span and if it's a three year old battery with many charges it could be failing meaning it just won't take a full charge.
Apr 19, 2011 | Canon Cameras
ASUS Original 19v 3.42a Ac Adapter Charger For N193 V85 Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
