Question about Keurig B100 Coffee Maker
B40wont work properly
All the lights aer lit the water is full but it does nothing when power button or on switch is pushed
    Problem Solver:
  • 6 Answers
I have 2 Keurig coffee makers and have found that if you make sure the seal connecting to the water source and the bottom are tight and the lid is pushed down with the coffee in it, tight it reboots itself. Blinking lights should stop. Also I have found that if the filter needs cleaning sometimes that stops it. Keurig is really great at troubleshooting and replacing their struff call the 1800 # if you don't get results.
Posted on Oct 21, 2013
Model mgh-055 furnace. Why won't it light?
Pushing down the button causes enough gas to be fed to the pilot to allow it to be lit and remain burning. If nothing happened, the gas valve could be at fault.
Sep 20, 2015 | Heating & Cooling
Goldair dehumidifier GD-2020 has stopped working? 'CONT' light on front panel flashing and now cannot get to operate?
cont button just means continuous run mode . the power light is lit , the full light is out . try reseating the water catch bucket a few times , most machines have a safety that wont allow the thing to operate if bucket isn't just perfect in its slot (you don't want water on your floor )
May 23, 2015 | Dehumidifiers
Machine won't work.
Robert. You have a bad water valve OR completely clogged up filter screens on the valve. My past experience with this machine with this type of problem is to replace the valve assembly. part Number W10364988
Apr 09, 2014 | Maytag Bravos Series MVWB300WQ Washer
Machine has stopped working and is in alarm
Possibly a stuck or defective ice level switch in the ice bin. It's supposed to cease the ice making when the bin gets full and then return the ice making components back on when the ice level drops to a certain level. Should be an easy fix if the switch is bad. The wires have push connectors on them.
Sep 06, 2017 | Kitchen Appliances - Others
My Frigidaire Dishwasher FDB1050RES2 gets stuck in a rinse cycle. The light on the front will be lit "clean" but the bottom of the washer is full of water. Opening the door does not turn off...
by the descrition you are giving you will need to replace the main control board.Part number 154568401.you may also need to check the float switch.The part will run about 110.00 dollars from a local parts store
Dec 29, 2010 | Frigidaire 24 in. FDB1050RE Built-in...
32'' Panasonic television. Power switch does not turn the set on.
1 It appears that connecting cable is faulty. Normally when you connect and push the power switch the standby light should lit. Try the cable on another appliance and see its function. Also switch on the TV and try to switch it on with your remote control.
Nov 19, 2009 | Televison & Video
My hyosung has stop runing it has no lights nothing is workeing at all can you tell what it can be
  • Is the battery 2 or more years old? It may need to be replaced. Check the fuses.
  • Before charging, add water to fill each battery cell to nearly full. Distilled water works best.
  • Use a 1amp or a 2amp battery charger
  • Is the kill switch on? Does the side stand have a kill switch? Is it working properly? Is the gas valve on?
    If no spark, then check again but with a new plug.
  • Check the operation of the ignition switch and all kill switches with a volt ohmmeter. Check the wire harness. Did a wire come unplugged? Are all wires clean and with solid connections? Any abraded or pinched wires? Is the bike in neutral and the neutral light is lit up? If no neutral light, check the neutral switch and wire connection on the center gearbox casing.
Apr 16, 2009 | 2003 Hyosung RX 125
Burner on new Whirlpool gass water heater will not stay lit
One of the proper ways to light a gas water heater, is to turn the black knob to Pilot, put a match to the end of the pilot light, while holding the match there, push the red reset button down and hold the match & the reset button down for one full minute. Then, release the reset button and turn the black knob to On. This should keep the pilot light on.
Jan 21, 2009 | Water Heaters
My Friedrich P-09 manual states that to use condensation pump to press both temp and temp- at the same time,when the unit is powered on and the water full light is lit. When i push those keys however it...
I have the same problem; pressing both buttons does not start the pump. Besides the "water full" light comes on almost after an hour of operation and I'd need to get up and drain manullly. Not getting any sleep.
Jul 29, 2008 | Friedrich Heating & Cooling
Buttons lit up, washer not going
If nothing works, no water and no motor action, then it sounds like a door switch or door lock problem. Check to make sure door is properly shut and switch is operating.
Feb 28, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Keurig B100 Coffee Maker Logo
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
