Question about ASUS P4SP-MX Motherboard
My Mb does not give any sign, . What can I do ? Everything is desconnected except power on the Mb and the Mb switch. I switch the machine on and the only thing works is the CPU fan No any beep
  • 144 Answers
Sometimes you have to have the motherboard , power , cpu , memory and 1 drive connected (IE the basic components) to get the system running
Also check the jumper settings where the board connects to the power switch on the case
Posted on Jan 22, 2009
No power on
Start barebones and work your way up.
Unhook everything except the Power Supply, MB, CPU/with fan, Monitor, Power SW, and Keyboard (eg...no mouse, no hardrive, no cd-dvd....). If no post or no power it might be a bad power supply, MB, CPU, etc.....process of elimination.
Possible "DOA"
May 17, 2011 | Intel DQ45CB Motherboard
No Display on boot up
When a motherboard does not beep that isnt good news and its either the Motherboard or CPU. Have you fot the FSB settings correct on the board? Is your power Supply Good? Does your graphics card need power and is it plugged in? Unfortunately the only way to findout exactly is at fault is through a process of elimination. Can you try a different power supply first? Also try removing the CPU and re-seating it. If not, then you need to try and get hold of another motherboard and see if everything works in that. If not then it could be the CPU. Diagnosing CPU or MOTHERBOARD is always tricky without spares. Good luck
Aug 30, 2007 | ASUS P5NSLI (0610839134670) Motherboard
When I turn on my computer it runs for a couple of seconds and then stops.
Unplug everything inside the computer, except the motherboard and the front panel power on switch. Power up the computer. If the PS fan continues to run, (power supply doesn't shut down)and the CPU fan runs, then power off the unit and reinstall each device, one at a time, turn the power supply on after each device is installed (and off, before installing the next device).
You can not easily start the power supply if it is not connected to the cpu motherboard.
If the power supply shuts down with only the motherboard attached, then you will need either another power supply, to test the MB, or another MB to test the power supply.
R
Feb 02, 2011 | Acer DPS-420GB (dps420gb) Power Supply
No power on dell e520 dimension
On the 20 pin connector, short the green wire to any black wire with a paperclip. This will force the power supply to turn on manually if the motherboard is not giving the correct "ON" signal.
Feb 26, 2010 | Dell Dimension E520 PC Desktop
No signal on monitor
You might try switching the VGA cable if you haven't. If that doesn't work then I'd agree with you in saying the motherboard is likely fried.
May 26, 2009 | AMD ASUS A7V8X-X MOTHERBOARD ATHLON XP...
L7vmm mb. display went out. Monitor works on
Dear User. to plug in the AGP card you dont need to check or see the CMOS. if u have pluged an AGP card and problem still persist then the problem is at *********** side or in RAM. just plug out RAM and other hardware except Processor and cables of switches. the switch on it and if it gives beep then your motherboard and processor is OK. there would be problem in your RAM so change RAM. and if it dont give the beep at startup then the problem is in your motherboard or power supply.
Apr 17, 2009 | Computers & Internet
Emachine T2890 won't power up. After reading some posts on this issue I went ahead and replaced the power supply, but the unit still won't power up. I am fairly certain that the old ps was fried since...
If you remove all the RAM fro the system and power it on, you should hear "Memory Error Beeps" if not, then it is usually Motherboard or CPU, for around $30.00 you can purchase a PCI POST code reader to try to pin the problem down further.
I am assuming from the post that all PCI cards (dial up modem especially) have been removed. Sounds like a bad MB or CPU, but if the video is integrated,( built on the motherboard, and not a seperate card, the memory is responsible for video also, and it maybe defective.
Feb 19, 2009 | Intel D845GVSR Motherboard
Emachine T2890 won't power up. New power supply.
move its bios jumpur on cofig mod and after some time post it its orignal post .it will ok ok Insha Allah
SHUT DOWN PROBLEM
try to add-on memory that compatible to your computer so that your computer become faster.....
Dec 17, 2007 | ASUS P5PE-VM Motherboard
ASUS P4SP-MX Motherboard Logo
74 people viewed this question
Top ASUS Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
