In the last 5 days the 2000 toyota avalon starup at 2000 rpm in cold weather idle unstable for the first 20 to 25 minutes
SOURCE: Runing high rpm while in idle
The concern happened after you relaced the plugs? You need to look for a vacuum leak that may have been created during the install.
SOURCE: mitsubishi pajero io 1.8 GDI idle unstable
sounds like the cabbruter is losing pressure cheak tubes may be lose or damaged
SOURCE: idle too low on hot starts 2001 Avalon
Sounds like you idle air control valve is going bad. They start acting up on a hot engine due to sticking or high resistance through its internal windings. It will get to the point where the engine will stall every time you take your foot off the gas.
I suggest getting it replaced and the throttle body cleaned at the same time since it will need to be removed to replace the IAC.
SOURCE: 1995 k2500 suburban idle too fast
replace the coolant temp sensor,it`s values are off,it is defective.Also if this does not work,witch I think It will,change the throttle position sensor.
SOURCE: I have a 1987 Susuki Samurai, 1.3 engine. Cold
Yeah it sounds kinda high. There is no adj except for the idle screw on the throttle, the computer does the rest, if it has one. If not, then you can adjust it some how. If carbureted, check for 2 little screws in the front, and check the choke, If throttle body, then just the idle screw, the idle should be around 1000. Hope this helps.
http://schematicsdiagram.blogspot.com/2011/12/how-to-adjust-rpm-on-2009-dodge-charger.html
Engine cuts out at 3000 RPM?http://schematicsdiagram.blogspot.com/2011/12/engine-cuts-out-at-3000-rpm.html
Cold start problem and vehicle shudder around 2500 to 3500 rpms
http://repairhelpcenter.blogspot.com/2012/10/cold-start-problem-and-vehicle-shudder.html
High rpm in neutral? Inconsistant high RPM in neutral?http://technoanswers.blogspot.in/2012/02/high-rpm-in-neutral-inconsistant-high.html
Jetski Sputters and Low RPM? http://whatisbyme.blogspot.in/2012/07/jetski-sputters-and-low-rpm.html
Fuel Injection Problem And RPM suddenly increaseshttp://whatisbyme.blogspot.in/2012/07/fuel-injection-problem-and-rpm-suddenly.html
2005 Toyota Highlander: Engine runs hard RPM below 3000?http://whatisbyme.blogspot.in/2012/05/2005-toyota-highlander-engine-runs-hard.html
1987 Toyota Camry: RPM Drops going Up hills?http://whatisbyme.blogspot.in/2012/05/1987-toyota-camry-rpm-drops-going-up.html
Cruise Control stops working, Excessive cranks to start the engine and RPM goes max 2500 http://whoisbyme.blogspot.in/2012/07/cruise-control-stops-workingexcessive.html
1990 Toyota 4Runner: Engine cuts off when reaches 2000 RPM?
http://whatisbyme.blogspot.in/2012/05/1990-toyota-4runner-engine-cuts-off.html
1999 Toyota Camry: Erratic stalling and high engine RPM at idle?
http://whatisbyme.blogspot.in/2012/05/1999-toyota-camry-erratic-stalling-and.html
1995 Toyota LS: Misfire at idle or low RPMhttp://whatisbyme.blogspot.in/2012/04/1995-toyota-ls-misfire-at-idle-or-low.html
Lexus RX: Tapping noise under Valve Cover At Low RPM?http://technoanswers.blogspot.in/2012/04/lexus-rx-tapping-noise-under-valve.html
These will help.
Thanks.
