Question about Microwave Ovens
Whirlpool microwave model number MH8150XJB will not heat food or drinks. any suggestions?
Comes on as if its working but is not working.
  • Microwave Ovens Master
  • 17,130 Answers
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if the switch contact are not good then it will not trigger the processor to switch on the waveguides. If the lights or fan work without any display or action of program being triggered to start then it can be a possible fault on the main board or the processor. Sometimes insect secretion can short the board and display panel and so the processor can work in such an erratic manner. If so clean, solder and reset the board. Now identify the parts by clicking this link: http://www.espares.co.uk/advice/microwave/a/5/141/identifying-microwave-parts.html
If there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron. Check this link to know how a microwave works:
http://www.espares.co.uk/advice/microwave/a/5/1443/how-a-microwave-oven-works.html
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off. Check the wave guide covers, if food had deposited
then it must be checked or replaced. See link:
http://www.espares.co.uk/advice/microwave/a/5/1146/how-to-replace-a-microwave-guide-cover.html
Now keeping clear of the microwave, switch on; use a cup of water inside to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.
If there is heating without any issues, you can use the microwave safely
Posted on Jan 12, 2013
Skill Will
  • 53 Answers
SOURCE: Microwave does not heat/cook
hi
power spikes are very damaging to a microwaves internal parts, it sounds like your transformer and/or magnetron are blown. if the unit is out of warranty I would recommend calling a repairman or getting a new microwave (the transformer & magnetron are expensive and dangerous to work on) also get a small single plug surge protector for the new one.
Posted on Mar 23, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Samsung MD800SC Microwave runs but stopped heating
Chances are you have a bad connection, maybe the cook relay or at the magnetron, but feel free to write back with details when it fails again.
Posted on Aug 19, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Whirlpool microwave MH1170xsy0 1000 watts
With the symptoms you mention, I would suspect:
- loose or corroded connection at the magnetron
- bad magnetron
- shorted high voltage diode
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
Posted on Aug 21, 2008
  • 2468 Answers
SOURCE: whirlpool model number MH7140XFB no longer heats
you either need a new h.v. capacitor or h.v. diode in the magnetron circuitry if you cant hear it cycle when it runs as in a low pitched hummmm when its drawing current to operate the magnetron tube, each part runs about $30 to $45 each,normally its the h.v. capacitor though
Posted on Jul 28, 2010
jsrock516
  • 5911 Answers
SOURCE: I have a GE Spacemaker
If everything works, but the microwave oven does not heat, this is commonly caused by a failed magnetron. The magnetron is essentially, the heart of the oven. This is what produces the RF energy that heats your food.
Here's what you need to determine whether or not its worth fixing:
1. You will need to uninstall the oven from over the range in order to replace the part (you will need to do this anyway, if you decide to buy a replacement oven).
2. You will need to ensure the oven is UNPLUGGED before servicing anything inside the cabinet. You will need to remove the exterior case in order to access the magnetron. There are several websites that you can use that illustrate how the oven is assembled:
searspartsdirect.com pcappliancerepair.com appliancepartspros.com
If you've never repaired an appliance on your own before, a microwave oven is usually not a recommended appliance to start with. Some models can be rather involved in taking apart.
3, The magnetron replacement part number for the model you have listed is WB27X10305. The average cost is about $80. NOTE: I found the part listed for the best price at appliancepartspros.com at a cost of $76.
You need to decide whether or not $80 and the amount of labor involved is worth the effort as opposed to replacing the entire oven at a higher cost and less labor (other than the installation). Review the parts illustrations at the recommended websites to see if this is something that you may be able easily take apart and reassemble.
If you have any questions, please post back and let me know. I hope you find this information helpful
CAUTION: DO NOT operate a microwave oven with the exterior cover off. The voltage inside the High Voltage network where the magnetron is installed can exceed 3,000 volts.
Posted on Aug 17, 2010
Testimonial: "Hi jsrock516 - thanks for your expert information. I don't think this is something we can fix on our own and as you said probably cheaper to replace. "
I have a Whirlpool GH5176XPS microwave and everything seems to work fine except that it does not heat anything. I have checked all the fuses and they are fine. Any suggestions?
The problem is more than likely a bad magnetron, "heats food" the other two considerations are the high voltage capacitor and diode.
Mar 31, 2011 | Whirlpool GH5176XPS Microwave Oven
Own Whirlpool microwave model MH7100XY, everything works on it, however it does not heat anything, heard a small pop and after that it does not warm or cook anything?????
The pop sound is an indicator the magnetron is gone that heats the food. It is cheaper to replace the microwave oven than have it repaired.
Mar 19, 2011 | Whirlpool MH7140XF Microwave Oven
What are the MINIMUM AND MAXIMUM TEPARATURE in the Oven?
a microwave is measured in watts,, not by temperature,, it works by passing microwave radiation through the food or drink, it is called dielectric heating,, so in other words it depends on the power setting and the time it is set for that determines how much the microwave radiation will pass through
Jan 28, 2011 | Whirlpool MT4155SP Microwave Oven
Our Whirlpool over the range microwave makes a clicking sound for a few seconds then shuts the microwave off. The microwave is unusable. The sound seems to be coming from the control panel.
If the cooling fan is not working, that would explain the shutdown problem. The function of the fan is to cool the magnetron down when it is warming or cooking the food, if the fan fails to run, the thermal fuse will detect heat rise causing a shutdown with in 5 seconds or more, the clicking suggest fan issues. I would recommend a whirlpool technician to go through the system.
Jan 27, 2011 | Whirlpool MH7140XF Microwave Oven
Whirlpool model number MH7140XFB no longer heats
Jul 28, 2010 | Whirlpool MH7140XF Microwave Oven
My house lost power earlier today, and now my microwave is not heating the food, and has a lower case "d" in the display after the time. Any suggestions?
It is in the demo mode. To turn off here is what the manual says:
The microwave oven and Timer must be off. Touch and hold Timer Off or the number 3 pad (depending on model) for three to five seconds (depending upon model) until two tones sound and “d” or "Demo" (depending on model) appears on the display. Repeat to turn off and remove “d” or "Demo" icon from the display.
May 10, 2010 | Whirlpool GH7145XF Microwave Oven
Whirlpool MH7140XFQ-1 microwave no longer heating
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
kggk
Apr 24, 2009 | Whirlpool MH7140XF Microwave Oven
hi
Mar 21, 2008 | Microwave Ovens
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part (such as a shorted diode)
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 19, 2008 | Whirlpool MH6150XMS Microwave Oven
Microwave Ovens Logo
59 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
