Question about Precor Efx 546 Version 1 Lower Body Elliptical Crosstrainer, 110v
Replace battery on precor efx 546 - Precor Efx 546 Version 1 Lower Body Elliptical Crosstrainer, 110v
  • Precor Master
  • 914 Answers
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: precor efx 546 error.
please follow this steps and fix it. God bless youError 43 - Zero Switch not FoundDescriptionThe C944 and several versions of C96X used a lift position identification system that did notutilize a potentiometer.Instead, it utilized a switch that would be physically actuated by the lift when the lift was in thezero incline position. A revolution sensor counted lifted motor revolutions to determinesubsequent lift positions. In addition two limit switches where used to remove power from the liftmotor if the lift moved outside of it's normal range.When the unit was powered up the lift would start to hunt for the zero switch. It would first go up4% (maximum lowest physical position was -3%) if it did not find the zero switch or it hit the upperlimit switch, it would then go down until did find the zero switch. When the zero switch waslocated it would stop, the system would then know its physical position and be prepared tomonitor the revolution sensor. If during this power up procedure the zero switch was not found anerror 43 would be displayed.Possible Causes1. The lift position actuator does not physically operate the zero switch.2. The lower PCA is bad.3. The zero switch is bad.Possible Remedies1. There are several physical problems related to the lift platform mounting or the plate the zeroswitch is mounted on that can cause the actuator knob to miss the zero switch as it movespast. Repair the lift platform mounting, repair or replace the lift switch mounting plate asrequired.2. The lower PCA provides a 5 VDC power source for the zero switch. You should measure 5VDC across the zero switch when the zero switch is activated. If the reading is significantlylow, remove both wires from the zero switch and repeat the measurement across the wiresremoved from the zero switch. If the reading is still significantly low, verify the zero switchwiring. If the wiring is intact and correctly connected, replace the lower PCA.3. Move the lift to position where the zero is switch is not activated and remove power from thetreadmill. Remove both leads from the zero switch and measure the zero switch with anohmmeter. The zero switch should read very near 0 ohms. While measuring the zero switchwith the ohmmeter, activate the switch by hand, the reading should change to infinite (open).If either of the above readings are significantly incorrect, replace the zero switch.
Posted on Mar 15, 2013
Can I adjust the stride length?
Precor EFX 546 Version 1 Elliptical Trainer (Refurbished)
www.amazon.com > ... > Elliptical Trainers
Amazon.com, Inc.
Rating: 4.3 - ‎9 reviews
Working out on an elliptical can burn as many calories as working out on a treadmill. ...allowing you to go forward and backward, as well as adjust stride length to target ...The Precor EFX 546 allows you to stride smoothly while holding the ...
EFX® 546i Elliptical Fitness Crosstrainer™ ' Precor
www.precor.com/en-us/.../efx-546i-elliptical-fitness-crosstrainer-33
With the unique Precor CrossRamp® technology, users can alter the path of the EFX®546i between 13 and 40 degrees in both forward and reverse stride motions, cross ...Excellent stability and freedom of movement for users of all sizes.
FAQ - Precor
Dec 28, 2015 | Precor 546 Elliptical
What kind of battery do i need for efx 546?
There a few possible options for the battery. This link will take you to all of them. Please have your serial number ready to help narrow your choices.
Repair Parts for Precor EFX 546i Ellipticals SPORTSMITH net
Jun 21, 2014 | Precor EFX 546i Elliptical Version 4
My precor efx 546 makes noise like a squeaking in left pedal it seems I tried to tighten pedal but I the whole bolt and screw turn together and the other pedal makes no noise
This squeak is normally caused by a bad bearing in the wheel. In order to provide you with the correct wheel, I will need your serial number. The following link will take you to our Precor EFX 546 page.
Repair Parts for Precor EFX 546 Ellipticals SPORTSMITH net
May 29, 2014 | Exercise & Fitness
Precor efx 546 wobbles when raising incline
It may be either the front shroud is installed incorrectly or broken, or the corkscrew for the incline motor is bent. If it is bent, it would need to be replaced.
Feb 10, 2014 | Precor Efx 546 Version 1 Lower Body...
How to repair a 546 efx precor
Assuming the buttons are working, the numbers change on the display, and the incline works, it may be the lower circuit board or the generator. If it is a very old unit, it may be the electromagnet or the data cable that connects the two circuit boards.
May 08, 2013 | Precor Efx 546 Elliptical Version 2...
Error 44 precor eliptical 546
Precor Error 44, Un-commanded Lift Motion Probable Cause 1. Intermittent or bad connection in the lift position sensor(potentiometer).
2. Lift position sensor (potentiometer) is bad.
3. Lower PCA is bad.
Corrective Action
  1. Bad or intermittent connection of the lift position sensor (potentiometer) is the most common cause of the error 44. Inspect all wiring and connections related to the lift position sensor (potentiometer). Repair or replace wiring connections as necessary.
  2. Monitor the lift position number displayed while operating the lift in diagnostics mode. If the reading makes large changes or is erratic, the lift position sensor (potentiometer) is likely bad. Replace the lift position sensor (potentiometer) or lift motor if the lift position sensor (potentiometer) is internal to the lift motor.
  3. If the lift moves without any command entered either manually or through a program, replace the lower PCA.
Precor Error Code 44
Nov 22, 2012 | Precor EFX 546i Elliptical Version 4
My precor efx 544 has stopped recognising that i am using it. does not display strides or calories burned. any ideas?
My Precor Elliptical EFX 546 Timer Stops After 7 Seconds, what is wrong? The most common cause for the Timer to Stop After 7 Seconds on a Precor Elliptical is NO RPM Feedback.
Knowing the status of the unit from its last use as well as the last service or part replacement is a great place to start.
Check the connection of the speed sensor to the lower board. Reset connection if necessary.
Check the magnet. The magnet is located on the user's right crank arm on versions 1 and 2 and the user's left on version 3. The magnet passes the speed sensor with each revolution of the crank arm. The magnet should be installed so that its south pole is facing the speed sensor. You can check the magnet polarity with another magnet that has marked poles or a compass. The north pole of the marked magnet or the south facing needle should be attracted to the magnet. Correct magnet installtion if necessary.
You may also check the spacing of the speed sensor to the magnet. The spacing should be 1/8" to 1/4". Adjust if necessary.
Also see the following link for additional information.
Replaced Crank Arm on Precor EFX 546 and Display Doesn Work
Jan 14, 2011 | Precor EFX 546i Elliptical Version 4
I have a Precor EFX 546. How do I replace the drive belt?
Using your model and serial number, use this link to view a service manual with procedure instructions. http://www.sportsmith.net/
Sep 19, 2010 | Precor EFX 546i Elliptical Version 4
Error 45 on Precor EFX 546 Elliptical
Precor Error 45, Lift Moving in Wrong Direction Probable Cause 1. Lift motor hysteresis.
2. Lower PCA is bad.
Corrective Action 1. The error would usually occur when the lift was already in motion (usually downward) when a lift command in the opposite direction (upward) was made. Some lift motors used in production exhibited a very long turnaround time and the lift motor would still be moving in the original commanded direction while the control system was trying to move the lift in the opposite commanded direction. If the error continues to re-occur, replace the lift motor.
2. It is a rare condition, however if the lift moves in the opposite direction commanded, replace the lower PCA.
Precor Error Code 45
Jul 19, 2009 | Precor EFX 546i Elliptical Version 4
Precor Efx 546 Version 1 Lower Body Elliptical Crosstrainer, 110v Logo
311 people viewed this question
Top Precor Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Shehu Pro
Shehu Pro
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
