Quick Change System Mega changer on Tehnics Compact Disc Changer Shown?
Discs want play this message is shown constantly on CD Disc Screen Quick Change System Mega Changer
5 Suggested Answers
techman
  • 3130 Answers
SOURCE: Disc gets jammed mid-way between CD magazine slot and inside player
Thats alot of disc this ubit holds. 110+1!! The CD changer arm mechanism sounds like is out of timming or the gears have slipped there teeth, and or the cam is broken, or theres a couple of small microswitches that can get broken as well.. The only way to work on this unit and see what the problem is, is to get a service manual and go through the mechanical alighnment and see where the problem is. Unless you can do a physical examination and know where every lob and gear is suppose to be, I do not see any other ways.
Posted on Oct 06, 2006
TVTECH55
  • 4 Answers
SOURCE: No play
Sounds like the drive belt that spins the disk is slipping or broken. You have only one actual cd reader so no matter what slot the disc is in it has to go to the same cd reader drive.
Hope this helps...
Posted on Dec 28, 2007
  • 23 Answers
SOURCE: Bose Wave Music Sys & 3 CD Changer
I have had a few of these come to my shop. The gears jump out of timing causing the cd lift to jam or become unalligned. The unit will probably have to be disassembled to get the CD out or have it serviced.
Posted on Mar 18, 2009
kachi_1
  • 677 Answers
SOURCE: Magnavox AZ9855 mini system (7 CD changer), trying
Hi,when a system eject a CD and with a message "failed CD" It caused by the CD mechanisms that allows the CD to play to damaged that's why the CD keeps on rejecting the CD's being inserted into the CD player.
When you replace the CD mechanism that allow CD to play, problem solved.
Take care.
Posted on Oct 06, 2010
HOW TO PLAY COMPACT DISC WHEN COMPACT DISC PLAYER IS ON?
You press the play button......
If you have multiple disks, press the appropriate disk and it will play
How to Use Six CD Changer
6 Disc CD Changer Instructions eHow
Feb 10, 2016 | Panasonic Technics 5 Disc Compact Disc...
Please help my 61 Disc CD Juke box just stopped playing and loading CD's all that it does is continuously displays the text message accross the screen stating Quick Change System Mega Changer over
Had this problem with a similar model, the drive belt had stretched and couldnt move the carrige. I replaced the belt with an O ring from True Value Hardware for .59 cents. It works like new now. The size is
1 1/16 outside dia.
15/16 inside dia.
1/16 wall
Captain Ken
Jan 13, 2013 | Technics SL-MC4 61-Disc CD Changer
For the(Technics Compact Disc Changer SL-MC59,60+1 CD Changer/quick change system)The equalizer is working,the control stereo Reciever is working but,the compact disc changer itself will not work. It...
if you can get to the laser eye take a paper towel or tissue paper soak in rubbing achole and clean the eye if you cant reach it or it is hidden in the mechinism get a disc cleaner and run that in the system it sounds like the laser eye is dirty i do it to my cd player all the time when it can't read the disc
Dec 21, 2012 | Audio Players & Recorders
CD function in 5 disc stereo constantly flashing "CHANGE"
Open the drawer and check to verify the disc was put in the disc 1 position. Sometimes the changer gets confused if disc 1 is not in the disc 1 cavity. Also, 5 disc changers are very prone to failure
Nov 17, 2012 | Audio Players & Recorders
2004 GRAND CHEROKEE 10 DISC C/D CHANGER MALFUNCTION.
It fixed it's self,the next day the changer was working normal.the battery is weak and going to be replaced.so maybe the problem was low system voltage." IT'S A JEEP THING " ???
Feb 04, 2009 | Cherokee Jeep Grand CD Changers - 10-Disc
"Err" message
i had err 2 screen. removed case (about 10 screws, took just a few minutes) and found 1 disc was had been knocked out of the tray. removed all discs. replaced case. works fine again
Dec 29, 2007 | Denon DCM-280 5-Disc CD Changer
No play
Hope this helps...
Dec 27, 2007 | Technics SL-MC7 110-Disc CD Changer
Dec 23, 2007 | Bose Wave music system Multi-CD Changer...
29 people viewed this question
 Grubhead
Grubhead
