Question about Sewing Machines
How do I disengage the upper cutting blade on a Pfaff overlock maching?
3 Suggested Answers
akylas
  • 26 Answers
SOURCE: thread wont overlock
When the thread breaks too often, try these, that goes for all sewing machines
1. Replace the needles,
2. Loosen slightly the tension of the needle threads.
3. The top threads are to thin,
4.The sewing (rotary) hook or looper, has burs,
5. Wrong threading
Posted on May 28, 2008
sewinsnap
  • 135 Answers
SOURCE: sharpen the cutting blades
You really can't sharpen them...you have to buy new ones.
Posted on Jun 24, 2010
I am trying to figure out how to disengage the blade on a BL4-738D Pro line serger. I do not have the book and not figure out how to do it.
BL4 738D Baby Lock Proline Serger Overlock Users Guide Owners Instruction...
Most serger upper blades can be "flipped" out of the way by pushing in and rotating it at the same time. HOWEVER, remember it is not recommended to run the machine with the blade deactivated. The loopers can be damaged/broken when they contact fabric that has not been trimmed.
Jun 12, 2017 | Sewing Machines
Can I stop my semco 750 overlocker cutting the material when I'm sewing
You should be able to disengage the cutting blade. Probably a button that you push in then rotate anti clockwise, this will turn the blade down under the machine therefore not cutting the fabric.
Good luck
Oct 04, 2014 | Sewing Machines
BLADES DON'T MEET ON OVERLOCKER
hi there
please see link to download user manual for JUKI MO-644D
http://www.juki.pl/support/HSM/Manuals/MO-654DE_manual_UK.pdf
and you must made upper and lower knife very close to cut material correctly.
regards
ASHRAF
CAIRO - EGYPT
aabozid@hotmail.com
Nov 22, 2013 | Juki MO-644D Mechanical Sewing Machine
Overlocker Bernette
If this is new it will still be under guarantee so have it checked out. It sounds like a badly aligned or blunt upper blade.
Overlockers will sometimes struggle with thick fabrics and putting something to help keep the foot level to " jump the bump" will often help, discuss that with the sleasperson too.
Nov 04, 2013 | Sewing Machines
Pfaff embroidery cutting blade
do you want a cutting blade?? have found a site that has spare parts for Pfaff machines - hope this will help
Parts For Embroidery Machines ... Edge Cutter Attachments ... We carry new and used machines from Singer, Pfaff, Durkopp Adler and many more. ... We stock a wide range of rotary, drag and tangential blades, sign blade holders and blades, ... www.sloanmachinery.com/
Feb 28, 2012 | PfaFF Sewing Machines
I accidentally sewed over a pin and now the moving
Disengage and then engage the blade to see if this will reset the position of the blade.
You could replace the blade - this should be in the manual or you may need to take the machine in for service as replacing the blade may or may not be all that needs to be done.
May 12, 2010 | Sewing Machines
I want to know which knob I use to make the stitching narrower
there are generally two variable controls .. one adjusts the stitch length (distance between stitches measured in stitches per inch) ... the second is stitch width .. that adjusts how far the zigzag moves left and right .. thats usually just a number from 0 to 10 or so .. 10 would be maximum width .. 0 would be used for straight stitch ..
so you need to adjust the stitch width control to make the stitching narrower .. the controls are called different things on different brand sewing machines .. if you have the brand and model number then there may be instruction booklets available ...
Jan 04, 2010 | Sewing Machines
How do you get the blades to cut on a hobbylock 794 serger
It should just cut. Don't know too much about this machine as I'm new owner, but from what I can gather, either you need a new blade, or the upper knife is disengaged. The metal knob inside the threading area should be turned downwards, engaging the upper knife. The upper knife doesn't usually need replacing unless damaged, apparently. Hope this helps somewhat.
Dec 04, 2008 | PfaFF Hobby 4260
Sewing Machines Logo
18 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
