Question about KitchenAid KGRT607 Gas Kitchen Range
KGRT600HBL FROM THE MODEL NUMBER YOU CAN ASSUME THAT I OWN AN OLDER MODEL OF THE 600 SERIES. I'LL MAKE THIS QUICK. BEFORE MY OVEN HEATS TO THE SET TEMPERATURE IT BEEPS 3 TIMES AND TURNS ITSELF OFF. tHE DISPLAY READS "F7:E0" CAN SOMEONE GIVE ME THE TRANSLATION TO THAT FAULT CODE? OTHERWISE I'M STUCK WITH A FREESTANDING COOK TOP.
  • atpcvos Jul 09, 2008
    Mine has a similar problem with a code of F2:E3. It will not allow me to use the oven at all. We have tried unplugging it to allow the computer to reset which it does and then immediately goes back to the error code. I have given up and am buying a new one since I am told if it is the computer circut board it is very expensive. We have had problems with this oven ever since we purchased it and will never get another one with all these electronic controls to create problems.
  • 5,911 Answers
I couldn't find an exact match for your fault code, but nearly every range fault code of F7 that I have experienced means you have a defective Electronic Range Control (ERC). This the electronic computer with clock and timer. The circuit board is usually not serviceable and has to be replaced. Usually an expensive repair. Sorry...I hope this was helpful in some way.
Posted on Jul 05, 2007
SOURCE:
Kenmore gas stove,oven is not heating properly. I set it for 450 it heats to 250
You probably have a bad thermostat. These usually aren't very expensive or hard to fix.
Mar 02, 2015 | Kenmore Kitchen Ranges
Frigidare self cleaning oven 554s034p01
What is the model number? The number you posted is for a dish washer.
Jul 21, 2013 | Kitchen Ranges
Replacing element in an old Chef Auto 600 Oven
Good news!
You probably can do this yourself.
Most appliance parts stores will "demand" you give them a model number, but if you find an appliance store that has a smarter older employee, he or she can probably give you the right one by seeing the old one.
Also know the element may be fine.
Older appliances sometimes have bad wires from old age.
When you take this apart, look carefully at the wires that are connected to the socket that the element plugs in to.
You may find the only thing wrong is a bad wire.
Know also that wire connectors for high heat things like stoves are sometimes made stainless steel, for the high heat.
God bless your efforts.
May 12, 2017 | Ovens
Double oven keeps turning off randomly. Entire control panael goes blank. A few minutes later it will reset
Control panel/computer mother board is bad, needs replace. You can order almost any appliance part online or threw Sears. Write down the model number and type of oven and go from there. They carry countless brands of appliance parts. You'll be amazed at what you'll find at Sears. They'll have it or either have to order it for you. Trace your steps when removing the face panel and follow your wire connections. Relatively quick job. 30-60 min job. Lowes, carries appliance parts you can order as well.
Apr 24, 2011 | Frigidaire 30 in. Electric Gallery Series...
Lower oven pre-heats to 190 over an hour, does not go to bake
If your electric2_bing.gif oven is not heating then you probably have a bad heating lelement in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Jul 16, 2010 | Maytag MER6772 Gemini Electric Kitchen...
My oven won't heat to the right temp.
Check the temp censer in the oven It went bad.
Feb 26, 2009 | Frigidaire FEB27S5A Electric Single Oven
Kenmore Gas Oven
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. If the ignitor is a round style - amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If less than 2.5A or 3A respectively - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Ignitor part numbers for round style ones: 4342528, WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Ignitors of the same shape (i.e. rectangular) are interchangeable, if you can splice the wires.
Feb 05, 2009 | Kenmore 33464 / 33465 / 33469 Gas Single...
I HAVE AN OLDER MODEL KENMORE LIMITED EDITION STOVE/OVEN. I DON'T HAVE THE MODEL NUMBER OR OWNERS MANUAL. ANYWAY, I HAVE A PROBLEM, I TRIED TO USE THE OVEN BUT AFTER I SET IT " F5" COMES UP AND IT BEEPS...
you can get the model number and serial number from the oven, just open the oven drawal and get the number and call the customer service from where you got this oven from.
Dec 05, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Older Kenmore oven- door locked by itself
We had a quick power outage and when the power came back on it locked our older (1991) Kenmore electric oven model # 40889 / 40881. Went throought the manuel and nothing pertains to this problem. We have turned off the circuit breaker and turned back on, but nothing seems to unlock the door. Any suggestions would be GREAT!!!!!!!
Nov 21, 2008 | Ovens
Oven probs
I think you are having a problem with a high limit switch that has become faulty. If you are running this around 400 degrees F. These things fail over time and since you said its a blodgett deck oven I assume it has to be over 10 years old. If you need further help please comment me back.
Hope this helps ya
Jun 22, 2008 | Blodgett Ovens
KitchenAid KGRT607 Gas Kitchen Range Logo
302 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Jay B
Level 1 Expert
Colin Stickland
Colin Stickland
ittco
Level 1 Expert
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
