Question about Karcher Garden
When machine is just sitting when on, motor kicks in & out ( pulsating)
    Scholar:
    New Friend:
  • 90 Answers
Sounds normal. Unloader opens because pressure is too high. Pressure goes down and unloader closes. Pressure builds and the unloader opens again Leave it running like that and the water will heat up. If you have a thermo valve it will protect you a little. One of the fastest ways to destroy your pump is to let it run for long periods without using it.
Posted on Jan 22, 2013
Why i dont have injector pulse on 3 injectors?
YOU NEED EXPERT TEST EQUIPTMENT,,YOU NEED DEALER TECK HELP. TAKE IT OR TOW IT TO A DODGE DEALER
Jan 21, 2016 | 1999 Plymouth Breeze
How do I change the brushes on my washing machine?
Hi Shirley
Well, If you are talking about the brushes (electrical brushes) which are inside the main drive electric motor.?
Then firstly I would check to see if this motor has brushes.
Most AC motors don't use brushes on a copper commutator.
Electric motor Wikipedia the free encyclopedia
They do however use a large external capacitor to kick start them in a particular direction and these can go bad.
AC motor Wikipedia the free encyclopedia
They often sit there & hum and can be push started. Not with the fingers or hand. A wood stick on the belt drive. But thats just to prove that it will work when the Cap is replaced.
This is better done on a work bench.
motor start capacitor
But... if you know that the motor has internal brushes you still have to take the motor out & pull the back end off to see & change the brushes.
So, either way, you will have to get access to the machine to remove the motor. While there check for a tin can attached close to the motor (the Capacitor)
Usually a job for an Electrician so be careful to disconnect from the power before opening the machine. Water & Electricity can be deadly.
Good Luck
Cheers
Aug 29, 2015 | Beko Washing Machines
My bernina E65 will not work,Help
since the machine has been sitting up for close to 2 years it needs to be serviced also.
when a machine sit up the grease & oil can become yuckie & machine will not respond good & sometime not respond at all.
it's also possible that the machine can have a loose or broken part
Mar 19, 2012 | Bernina Sewing Machines
My machines (WF-T7014PP) pulsator circle came loos what do i do?
starting washing after water lever sensor motor cannot function error, spin & wash alarm blinking.
May 30, 2011 | LG WFT1071TP Top Load Washer
Power comes on but will not start wash cycle justs sit there and humms
Try the steps below:
- try running it without any load to see if it still hums.
- if it does, see anything underneath the pulsating disk if there's anything stuck. (like a coin or a pin)
- if it doesn't, You can also try removing the belt between the motor and the pulsator to isolate if it's a defect in the motor or the pulsator.
After that, If the motor is defective, then you'd have to replace that or repair it if you know how to. If the pulsator is defective, check again if there's something stuck in the bushings. If you've used the washing machine for quite a long time, you may need to replace the bushings and bearings of the pulsator. You can also buy an assembly unit for the pulsator if there's one available in your area.
Hope this helps.
Jan 27, 2011 | Washing Machines
I have a 83 280zx non-turbo which quit running. Heard pulsating noise at fuel pump relay (kicking in and out) under dash passenger side. Replaced relay, still does same thing. Replaced water temperature...
You need to replace the fuel filter. Also the age of the car warrants replacing the fuel pump too. If its drawing high amps the relay will fail. Straight wiring a fuel pump is a safety concern. A fire or explosion hazard exist due to arcing at fuel pump motor. Yes it is inside the fuel tank and is very old. Replace it.
May 24, 2017 | 1983 Nissan 280ZX
The machine runs for brief periods, then shuts itself off. If it is allowed to sit for several minutes, it runs again, then shuts itself off.
the motor is heating up to much and the cut out switch is kicking in. You need to check the the motor filter, and worse case you may need to new motor..
Oct 04, 2010 | Dyson DC14 All floors Bagless Upright...
Machine fills with water, sits for a couple of minutes, agitates for 15-30 seconds, stops for 3-5 min. agitates for 15-30 secs etc... When rinsing, empties water starts to spin, kicks into high gear for a...
Your motor/clutch combo is on the way out. The motor is overheating and turning off. Cools down and restarts.
You need a new motor/clutch combo or a new washer. I do not recommend another GE.
Jul 07, 2009 | GE Washing Machines
Garden Logo
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
