Question about Bosch Axxis WTL 6307 Electric Dryer
Wtl 6307 cutting out
About 8yrs old.cuts out and stops rotating drum andheating, sometimes after a minute, sometimes after 20, 30 or more . No error lights come up, but the start/stop light flashes. Doesn't seems to be persistent, just intermittent, but annoying!
  • 8 Answers
SOURCE: Bosch Axxis WTL 5400 Electric Condensation Dryer...Lint Filter Light
have you checked the vent line it could be stopped up if the line is bent same affect as the lint filter being full
Posted on Dec 15, 2007
SOURCE: Bosch Condenser Dryer Classixx
I found this on justanswer.com, I am going to try it this weekend and I will post an update.
"Ok if you remove the left hand side panel then located at the back is the drain pump
remove the hose on it which goes up to the bottle and blow up it to make sure its clear.
If thats fine then remove the pump and clear any fluff thats in there and make sure the impeller is ok and turning fine.
Then refit and try again hopefully this should sort it out.
let me know if you need anymore info."
Posted on Jan 02, 2010
sonicboomele
  • 1557 Answers
SOURCE: Hi! I have a new Bosch Dryer. We can't seem to get
i take it you have cleaned the lint filter if so then it has a bad sensor reader in the filter system
Posted on Dec 22, 2010
SOURCE: Bosch WTL5400 Drier runs fine for 5/10 minutes,
I have the same problem, the dial to select the dry program is making a bad contact causing it to stop. Try using a different program.
I tried to clean the dial but it didn't help.
Posted on Jan 12, 2011
  • 19 Answers
SOURCE: Bosch WTA4007GB/04 Tumble Dryer. There is power
There is definitely a problem. Get help from an expert.
Posted on Aug 05, 2011
How to unglaze glazed drum breaks
Rear Drums & shoes should be changed at the same time. The same goes for the front pads & rotors. Usually the drums & rotors are pre-cut but I ask at the counter if they need cutting because I have ended up with uncut squealers once or twice and found the drum needed to be re-cut due to minute warp-age. If the grinding is the same as before the brakes were changed then all th e brakes need changing not just the ones you thought needed it. Quiet pads & brakes have a beveled edge instead of an abrupt 90 degree angle. Ceramics tend not to squeak. As for un-glazing, in the old days we ran 60 grit sand paper along the wear surface until it was sufficiently scuffed to stop the squeal. It didn't work for very long & usually the squeal worked itself out with wear in a week or 2. good luck.
Aug 20, 2015 | 2005 Chevrolet Equinox
My dryer WTL 5410 electric condensation dryer is cutting on and off.
this is normal operation it turns the drum one direction then the other this is because of the way it condensates
Apr 06, 2014 | Bosch Axxis WTL 5410 Electric Dryer
Drum stops turning after 2 turns
the belt could be slipping and worn out it could stretch after the first couple turns
Jul 14, 2012 | Washing Machines
Model:SF-95CJ F9 FAULT CODE
my hitachi model SF-95 CJ is washing machine show F6 ,C4, F4 FAULT CODEcleck
Feb 11, 2012 | Washing Machines
Bosch WTL5400 Drier runs fine for 5/10 minutes, then it stops and the "start" light flashes. Pressing this then restarts the process, but a few minutes later it cuts out again. I have checked...
Dec 06, 2010 | Bosch Axxis WTL 5400 Dryer
No heat in the dryer. It is Maytag Neptune gas dryer about 9 years old. The drum rotates just fine but heat stopped a couple of days ago.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
May 14, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Changed the photoconductor unit on epson aculaser c1100
Hi, the E511 is caused by the printer not "sensing" rotation of the PCU drum & transfer belt (TRO Sensor error). It could be the PCU was faulty. First thing to try is to open the top cover and remove the PCU. Be careful not to expose the drum to bright light, avoid touching it if possible and be very careful not to scratch it. Using thumb pressure at the edges of the drum check it rotates. On the underside of the PCU is a little cut-out window, rotate the transfer belt until you see a little silver square appear. Give this a good clean with a soft cloth. Inside the printer you will see a little sensor sticking up (TRO Sensor) that aligns with this cut-out, give this a clean too. Hopefully your problem is now fixed.
Please take a moment to rate this solution, thanks.
Apr 02, 2009 | Epson Aculaser C1100 Printer
Bosch maxx dryer
The manual for our Maxx WTL6500 says to press and hold the Start/Stop button for 4 seconds. "The child safety lock can be released permanently using the Menu button." In our case that means press Menu 3 times then press Change to set the lock on or off.
HTH
Jul 02, 2008 | Bosch Axxis WTL 6307 Electric Dryer
LG WM1812CW PROBLEM
Just had this same problem on my LG wm1832CW machine. Sensor assembly was replaced and all is well..
Simple and fairly inexpensive to replace.
Oct 28, 2007 | LG WM1812C Front Load Washer
62802 stops running after a few minutes
It sounds as if you have a defective drive motor.  After the motor runs for a while and heats up, the internal thermal switch cuts it off before it gets too hot and becomes a hazard.  Once the motor cools down and the thermal switch makes up again, it will run and then repeat this process.
Oct 15, 2007 | Kenmore 62602 Electric Dryer
Bosch Axxis WTL 6307 Electric Dryer Logo
29 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
