Question about Sony VAIO F2 Series VPCF237FX/B 16.4-Inch Laptop Matte Black
How do i remove the keyboard on a sony vaio F2 VPCF23JFX?
I have removed all the screws on the bottom but somehow cannot get the back shell off. I am afraid of using force to pry things open because I don't want to damage the internals.
  • Sony Master
  • 7,627 Answers
Posted on Jan 12, 2013
SOURCE: I need steps to replace Fan for my Sony VAIO VGN-S460
the fan is screwed together with the motherboard, the only way i figured is to separate it is completely unscrew the motherboard, cd drives.....then unscrew the fan from the bottom side of the motherboard....
i took the fan out just today, wantted to add some lubricating oil to it, but then can't manage to separate the blades & expose the centre
how much did the replacement fan cost? i am in canada, not even sure sony stores here have it.
Posted on Apr 02, 2009
A2Anderson
  • 8 Answers
SOURCE: sony vaio vgncs16g
You need the original software CD's that came with the laptop and drivers found at: http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGNS360&LOC=3
Posted on Aug 08, 2009
Baytel
  • 19 Answers
SOURCE: How to remove a flickering thin green line that
It sounds like you have a bad screen or video cable.
Posted on Nov 17, 2009
byteguy
  • 2229 Answers
SOURCE: power socket for sony vaio is broken how do I
On a Sony, many times the power socket is a separate piece that can be replaced. Unlike many laptop motherboards, these power sockets are a separate item the plug into the motherboard. \
Bad news is you have to dissassemble the computer to get at it.
Posted on Dec 22, 2009
  • 1087 Answers
SOURCE: How to Remove the bezel from a sony vaio
http://www.fonerbooks.com/laptop_8.htm
Posted on Mar 29, 2010
Remove keyboard 646125-001
  1. Prior to replacing your replacement keyboard for sony vaio vgn-fe880e/h, make sure to remove the keyboard and disconnect the ac adapter from your laptop.
  2. The first step to replacing your laptop keyboard is to remove the screws from the back of your vaio vgn-fe880e/h. Sometimes your laptop will have a picture of a keyboard next to the screws that need to be removed. Otherwise, see your laptop manual for details.
  3. Above the laptop keyboard for sony vaio vgn-fe880e/h, you have a cover panel. If required, remove this part to easily access your keyboard. If you have screws above your keyboard, remove those screws.
  4. Now that you have removed all the screws, you are ready to remove and then replace your new laptop keyboard.
  5. To remove the vaio vgn-fe880e/h Keyboard, take a thin object and pry the keyboard out between the keyboard and motherboard. Be careful when removing the keyboard.
  6. Now that your keyboard is loose, simply disconnect your keyboard. In order to disconnect the keyboard, pay attention to the keyboard connector and connector cable. Unlock the connector cable device and remove your laptop keyboard. Your sony vaio vgn-fe880e/h connector cable should be easy to remove by simply sliding it out.
  7. Now that your keyboard has been removed, get ready to install your new laptop keyboard. Look at the back of the keyboard. If you see any screw holes, you will have a good idea of where to place the screws back in at the bottom of the laptop.
  8. Connect your laptop keyboard for sony vaio vgn-fe880e/h to the motherboard keyboard connection slot. Secure the keyboard cable. Now turn your keyboard in place, and align the grooves on the bottom of your keyboard with your palmrest or plastic bezel. Secure your laptop keyboard in place, make sure it fits properly and is snug. Now simply place the screws back in place.
Nov 30, 2012 | HP 646125-001 - Keyboard Tm - Us
How to open keyboard of sony vaio pcg-6rfl
Remove the Power Cord and the Battery. Turn the laptop over and start removing screws from the bottom of it. There might be screws on the bottom that hold the keyboard, normally they will have the keyboard icon by them. Once you have the screws removed Look inside the battery case to remove any screws. Sometimes there will be screws that hold the keyboard and the strip that is above the keyboard inside the battery case.
Next turn the laptop back over and open the lcd lid. Remove the strip that is above the keyboard. Be careful because there might be a cable attached to the bottom of the strip. Once the strip is removed there might be screws that it was hiding that hold the keyboard so remove them. Now you can lift the keyboard out, but be careful because there is a cable attached to the back of the keyboard.
Apr 15, 2012 | Sony VAIO PCG-K25 Notebook
How to remove the keyboard?
Remove all of the screws on the bottom, as well as the RAM, hard drive, and CD/DVD drive. Then, while the laptop is open, lift up the upper plastic covering on the bottom (you might need a key to get in there) from here, you should be able to see the keyboard mounting screws, make sure you remove the keyboard cable from the motherboard as you remove the keyboard.
May 04, 2011 | Sony VAIO VPC-CW17FX/W PC Notebook
How to replace keyboard on sony vgn-nr498e, broken left hand shift key, i need to replace entire keyboard
If you have the new keyboard, look at the bottom and locate the screw sockets. On the laptop at the bottom, match and locate the approximate location of where each screws are mounted. Remove only those screw. On some laptops, you might need to remove the keyboard top frame - if they are mounted with screws, remove them as well. Some laptops have a small picture or symbol of a keyboard for each screw that needs to be removed on the bottom of the laptop.
Dec 09, 2010 | Sony VAIO VGN-NR498E/S Notebook PC
Instructions for installing a toshiba hard drive MK103GAS in a Sony Vaio laptop
Step 1 - Remove Screws Flip the entire laptop over and remove the battery.617_bottom.jpg
There are a total of 4 screws you need to remove as depicted in the red circles.617_unscrew.jpg
Begin removing one at a time.617_unscrew2.jpg Step 2 - Removing the Keyboard After you remove the four screws from the bottom chassis, flip the laptop over and take a look at the keyboard area.
Now look carefully at the top corners of the keyboard, there is a tiny little button that you need to push in order to release the keyboard. 617_keyboard1.jpg
Push both the release keys while pulling the entire keyboard towards you. 617_keyboard3.jpg
Gently lift up the keyboard towards you, while flipping it over. 617_keyboard4.jpg
The keyboard has been removed!
Step 3 - Removing the Palmrest Looking inside, you will need to remove three screws as depicted in the red circles below.617_unscrewhandrest.jpg Next, gently slide the entire palm rest chassis towards you.617_handrestremove.jpg Before you lift the palm rest, notice the delicate ribbon cable on the underside. Then lift it upwards, flipping it over. Be careful not to rip the ribbon cable that's connected!617_handsetremoved.jpgYou now have access to the hard drive!
Step 4 - Removing the Hard Drive Remove three screws from the cage holding the hard drive as depicted below in the red circles.617_unscrewthree.jpg Next, gently remove the SATA cable from the hard drive. It may require a bit of effort to pull the SATA cable from the hard drive, just try to be gentle. Note that there is tape over the SATA cable underneath the hard drive making the SATA cable more difficult to pull out.617_removesata.jpg
Be careful in this step not to rip the ribbon.
The hard drive is now removed!
The next step is to just remove the stock hard drive from its cage be removing the screws on the edges and replace it with the hard drive of your choice. Carefully screw it all back in place, slide the keyboard back in and power on your system! 617_hardrives.jpg
Replacing Toshiba 120GB hard drive 5400RPM with Seagate 100GB 7200RPM 2.5? Hard Drive.
Enter the BIOS by pushing on F2 key during the VAIO boot screen. Ensure the proper hard drive is listed in the BIOS. 617_biosscreen.jpg
Insert your Windows XP or Recovery DVD disc to begin installing the operating system!
if it help full to you please vote me
thanks:ayyunoora
Oct 27, 2010 | Computers & Internet
How do you replace a sony vaio ux lcd screen?
Basically remove all screws holding the front bezel (screws are behind the rubber thingies). Once you have pried off the bezel there are several screws on each side of the screen. Removing these will be needed, along with any remaining screws on the top and bottom. Once the screen can be leaned forward, with a sheet of paper towel, on the keyboard. There is a long connector at the top of the screen; remove this connector. Another smaller connector is at the bottom, remove it as well. This ought to get you well on your way!
Sep 21, 2009 | Sony VAIO VGN-UX280P Notebook
Remove keyboard
You need to locate screws below you laptop, the keyboard was ajusted by some screws(2-4), Vaio do this in almost all models. Detach your screws and your kb will be removed.
thanks
vcrtech
Apr 20, 2009 | Sony VAIO PCG-GRT100F PC Notebook
Vaio VGN-TXN25N, need to remove hard drive
Usually the laptop hard disk is only reside in the side of the laptop. Sometime you need to remove the small cover first before you can see the screw. Look in the right side of the laptop or in the back but there is also laptop model that the hard disk is below of the keyboard.
Apr 23, 2008 | Sony VAIO VGN-TXN25N/B PC Notebook
Replace wireless card on sony vaio vgn-n130g
usually there are screws coming upward from the bottom to remove the keyboard,then you have to remove the palmrest which the touchpad is integrated into.
Apr 07, 2008 | Sony VAIO VGN-N130G/W Notebook
How can I remove the hard drive from a Sony VAIO PCG-F305?
Remove the keyboard also,there's usually some more screws under the keyboard.
Oct 17, 2007 | Sony VAIO VGN-S460 Notebook
Sony VAIO F2 Series VPCF237FX/B 16.4-Inch Laptop Matte Black Logo
255 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
