Question about Brother HL4150CDN Laser Printer
Activate the cleaning cycle
It tends to splatter ink
How to fix problem, ink jets out towards back of inner printer instead of down on to paper
I would not worry about the ink on the inside of the printer. This is almost certainly just waste ink that has splattered here during printing/cleaning. The printhead is forced to face directly down inside the printer and if it was not this would cause the cartridge to be rejected and stop any printing.
If your pages are coming out blank I would recommend taking the following steps:
  1. First off please run any printer head cleaning cycles available from your printer software and check the quality of your prints.
  2. Fold a piece of kitchen tissue or any other non fibrous tissue and dab it under a tap to make a small damp patch. For best results make sure the water is warm.damp-paper-tissue.jpg
  3. Take the cartridge out of the printer and hold the damp patch over the printhead for 30-60 seconds.hp-300.jpg hp-300-on-tissue.jpg
  4. You should now hopefully have a small ink soaked patch on the tissue with traces of all the relevant colours. ink-patch.jpg
  5. Then wipe the printhead several times on the dry part of the tissue and you should start to see the colours come through. wipes.jpg
  6. Reinstall and run one more head cleaning cycle and with any luck you should be ready to print.
Sadly these cartridges are getting on a bit now and it is entirely possible that the printhead of the cartridge has stopped working entirely or is irreversibly clogged. If the cartridge has been purchased recently contact whoever you purchased it from. if not I would recommend buying a new black/colour ink cartridge.
Source: http://www.refreshcartridges.co.uk/igloo/refilled-cartridge-not-printing-correctly/
Sep 06, 2012 | Dell A940 All-In-One InkJet Printer
Black ink printing on back of paper
Your paper feed rollers have some black ink contamination: wipe the rollers, all around, with slightly moist tissue paper until there are no more ink evidence coming off the rollers. To moisten tissue, warm water with a very small amount of Windex, dish soap or rubbing alcohol does wonder.
Also clean gently around the bottom of the print head assembly to remove any obvious splatters.
Hope i helps.
Sep 26, 2011 | Canon PIXMA® MP530 All-In-One Printer
Sparks are coming from behind the little revovable plate inside the oven.
these covers are made of a mica material; and tend to get grease-soaked from food splatter. this is where the microwaves pass through. if cover is burned, you will need to replace and clean greasy mess underneath. hopefully, the magnetron is not damaged.
Aug 06, 2011 | Jenn-Air JMC9158AA Convection Microwave...
I've tried printing twice and ended up with a paper jam. I cleared it, but also saw what looked like ink splatters inside the printer. I took the cartridges out and cleaned up the splatters and replaced...
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Dec 06, 2010 | HP PhotoSmart C4280 Laser Printer
Ink splatters from new toner
Clean the drum unit cartridge and the charge roller unit.
Apr 15, 2010 | Minolta DI2510 Black and White Copier
Ink pen splattered in Kenmore front loader washer...
I would try running a few empty cycles with some oxyclean through it...
Jul 08, 2009 | Kenmore Washing Machines
Can not print
replace your cartridges clean the ink splatter sponge and make sure the cartridges are set in correctly and the printer is aligned this is crutial this will be in program specs
Jun 01, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Printer seems to be leaking ink?
take those out are uusing off brand ink
Feb 03, 2008 | HP PSC 1510 All-In-One InkJet Printer
Black ink splattering the sides of the paper
remove ink cartridge wipe off print head area with rubbing alcohol
applied to a microfiber cloth
Jan 17, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Brother HL4150CDN Laser Printer Logo
32 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
