Whirlpool wed5840sw0 heats up but won't spin.
  • Washing Mach... Master
  • 17,129 Answers
If the machine starts with accepting water to the desired level and then not moving forward , it can be related to failure of the motor or the controller unit. check voltage to motor at the wash/spin cycle and if this is absent , the fault is within the processor
Posted on Jan 12, 2013
Jimster
  • 240 Answers
SOURCE: Whirlpool won't spin at high speed
Sounds like you may have lost your basket drive and clutch assembly. This is a pretty involved job to replace for sure, and requires you to remove the inner basket, drop the transmission, etc. Does the unit make any wierd noises, like popping or grinding? Does it agitate ok in wash? I would bet almost for sure that its that basket drive and attached sub-pack thats went bad. If you want to try and tackle this yourself, let me know, and will get you directions to do so. Good Luck!!!!
Posted on Feb 02, 2008
Maytag317
  • 1136 Answers
SOURCE: Maytag top load clothes washer tub spins hard
Hi, You can unsnap the plastic splash ring and see if something is between the tubs. The inner tub turns rather hard anyways. The agitator might have a 1/4" screws in the side of it to hold it onto the shaft of the transmission. If not, just pull the agitator up real hard.
Under the agitator is a spanner nut that holds the inner tub in place. I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on May 27, 2009
Karthik316
  • 187 Answers
SOURCE: LOUD RATTLE ON WHIRLPOOL GHW9150 ON SPIN CYCLE
Try this link
http://www.acmehowto.com/howto/appliance/washer/diagwasher.php
pls rate my suggestion....
Posted on Jun 26, 2009
  • 40 Answers
SOURCE: clunking noise
the roller that the drum rides on shot. there should be two of them located on under side of drum rear
Posted on Sep 05, 2009
Jahn27
  • 1554 Answers
SOURCE: Maytag Centennial Washer model MVWC6ESWW1
It sounds like this is a clutch and brake assembly problem. The clutch spring must provide the necessary pressure for the lining to turn with the hub and the clutch tab to push the brake cam driver and release the brake. The clutch spring of your washer must be weak or the clutch lining is worn causing it to slide and not release the brake. This prevents the tab that holds the clutch spring to force the brake cam driver, release the brake, and allow the basket to spin particularly when the machine is under load. This is manifested in the spinning of the drum when the machine is empty. The clutch and brake assemblies are located just below the tub and the excessive heat resulted from the friction between the clutch lining and the clutch hub.
Remove the thrust washer from the agitator shaft then remove the clutch and brake assembly from the top of the gearcase by removing the retaining clip using a screwdriver. Unsnap the clip and the clutch retaining ring the slide the clutch off the agitator shaft. Make sure to retain the washer located under the clutch.
Install the new clutch assembly on top of the gearcase then insert the clutch band and hold it in place. Using a pair of needle-nose pliers, place the end caps on the clutch spring and compress to insert into the open end of the band. Release the tension on the spring and the band will stay in place the reinsert the retaining clip on top of the clutch.
You don't have to accept or reject this post in order to add comment or information. But accepting the solution should you find it helpful and/or informative will not stop you from posting comments or additional information. You can still communicate with the expert should you need further advice regarding the issue stated herein.
Posted on Jul 30, 2011
What shoudl I check to determine why my whirlpool WED5840SW0 is not heating?
Check the thermal fuse the cutout fuse & all thermostats .
Also check the heating element & check to see if it is touching any metal. It also could be the centrifical switch in the motor.
Hope this helps
May 09, 2014 | Dryers
Whirlpool dryer won't spin
Most dyers after you pull the top up, the front should just lift a little and it should come loose, sounds like you may have the belt intact, but the motor is not conected to the belt.
Jan 12, 2013 | Whirlpool Dryers
Kenmore 96272100 won't spin, but heat comes on....
Broken belt most likely. I looked at your model number and your belt number is 341241. Your actual model number with prefix is:
110.96272100When ordering parts you always add the 110. Anyway to replace the belt you first remove the filter. Then you must remove the 2 screws that hold the filter housing to the top because you gotta raise the top. To raise it you grab the dryers back side right behind each hinge and pull the whole top forward a bit while lifting on the front of the top to release the front portion and rotate it to the back. Then you will need a small screwdriver to assist in unplugging the door switch. Then remove 2 screw holding the front on and LIFT up the front to keep from damaging the bottom clips which are flimsy. Once the front is out of your way get the drum out and inspect the rollers. You can lube them with zoomspout oil, it is safe for appliances.
MY PICTORIAL AND VIDEO
Dec 13, 2012 | Kenmore Dryers
Inglis clothes dryer heats up but drum doesn't
The way to visually see if the belt has broken or not is to 1) unplug the dryer. 2) Remove the lint screen on the top of the dryer. 3) take the two phillips head screws out where the lint trap is. 4) with a flat head screwdriver pop the top of the dryer up by sliding the driver inbetween the top and front of the dryer and pry upwards a little. 5) You'll now see the drum, if the belt is not around it its broken, and if it's visible try to lift it. If it taught, its good. IF THE BELT IS BROKEN OR LOOSE CONTINUE TO NEXT STEPS 6) on the left and right upper inner sides of the dryer you will find two screws, one on each side, remove these and the front should be easlily remove. 7) once off you'll be able to easily see the motor, the belts idler pulley, and everything else.
Apr 28, 2012 | Whirlpool Dryers
Washer won't do spin cycle....and won't start any cycle
Hello & Welcome to FixYa
When the washer fills but does not agitate or spin then you can check if the lid switch is fine. You can jump start the lid switch by connecting both the wires with each other or use the third wire to act as jumper between the two. After this if the problem is solved then replacing lid switch is recommended repair. Please get back to me if you have any other questions.
Kevin
Jul 15, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool dryer at least 10 yrs.old
belt broke remove 2 screws under lint screen release clips under edge of top on each corner by pressing in with putty knife..lift top remove screws upper corners each side top ..disconnect door switch connector lift front off install 341241 belt per diagram on bag
Jul 30, 2008 | Dryers
Washer not spinning
Sounds like the brake liner could be broken. When the machine starts to spin, the motor turns in the opposite direction to the wash cycle and causes the bowl to lift off the brake liner and the bowl then spins freely. Either the riser cam is worn/broken or the brake liner is broken. This is quite involved and you may have to call in a tech.
Nov 03, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
