Question about Sony DVP-NC665P/S Multi-disc DVD Player
Black & white picture
I only have a black & white picture when everything is hooked up properly. Double and triple checked all connections. I have heard of these units doing this right out of the box. Is that possible?
Check input type on what ever you are viewing the DVD on. Sometimes there are menu settings on the TV ~ monitors.
Posted on Jan 24, 2008
How does the Power Head wire up to the switch on the Rainbow SE?
Here is the wiring for a D4 switch:
Rainbow D3 D4 SE power switch
Rainbow no longer makes the switch with 6 wires, it comes now with only 4.
GoodVac.com
800-775-6586
Jun 29, 2014 | Rainbow 75th Anniversary Canister Vacuum
Black and white picture on wii
Double check your connections, may I ask which inputs are you using?
Feb 23, 2013 | Sanyo 42 in. LCD TV
I'M TRYING TO HOOK UP MY INSIGNIA 42'' 1080P FLAT-PANEL LCD HDTV TO OUR DVD PLAYER USING THE COMPONENTS (RED, BLUE, GREEN, RED & WHITE CABLES) PROVIDED AND THE PICTURE IS IN BLACK & WHITE....
The three picture cords (red/blue/green) often are a little larger around than the sound cords (red/white). If they are they same size, they are often grouped separate by picture and sound. Double check to verify if you have the "red" cords correct. Good luck.
Jan 20, 2011 | Insignia 42" LCD Flat-Panel HDTV
I plugged our wii into new tv. the screen shows a black and white picture. how do i fix it?
    What to do will depend on how you're connecting your Wii console to your TV.
    • With the yellow, white, and red AV cables that came with your system:
      • Did you have to use the red/green/blue inputs on your TV because it doesn't have the standard (yellow) AV inputs... if this is your first time hooking up the Wii console or have you moved it to another TV, . Our experience shows that many times this issue can be solved by double-checking your connection and finding the correct Input Select for your TV or VCR.
    • With the blue, green, white, and red component cables (sold separately):
      • Review our step-by-step Wii Component Cable to make sure the cables are properly inserted and that your TV is set to the proper input.
    If you have verified the connection is correct, and are still receiving a blank or black and white screen when powering on your Wii console, then the problem is likely with the system and it will need to be repaired. Please call 1-800-255-3700
Dec 26, 2010 | Nintendo Wii Console
Having just installed a new Wii console I have good sound but everything is in fuzzy black and white - no colour at all. What should I do to get colour?
      • If this is your first time hooking up the Wii console or have you moved it to another TV, Our experience shows that many times this issue can be solved by double-checking your connection and finding the correct Input Select for your TV or VCR.
      • Review our step-by-step Wii Component Cable connection guide to make sure the cables are properly inserted and that your TV is set to the proper input.
I am wiring my new Fahrenheat hydronic baseboard heater. I notice that inside the left endcap (and also inside the right endcap) there are TWO pairs of wires already attached together, a red with a...
Hello,For 220volt Choose which side you will connect to.Take the nut off that side black=black / white=red leave the other side alone.The manual is useless.
Oct 17, 2010 | Fahrenheat Electric Hydronic Baseboard...
Am installing a ceiling fan and do not have the installation instructions. The fan has a black wire (labeled Motor), a white wire (labeled Neutral) and a blue wire (labeled Light). What is the proper...
When dealing with older houses, you run into this a lot, but the somewhat newer houses will actually have the 3 wires to hook up the ceiling fans. You can still use your 2 wires, but you will have to double up the motor and light wires. Wire nut the Black and Blue wires together with your Black wire from the house, and the White wires will be tied together for your neutrals. You should also have a green ground wire also, be sure to hook that to a ground in the house too. Hope this helps!
Aug 04, 2010 | Heating & Cooling
Black and white picture on the JVC TH-505
If you hold the VFP button while a movie is on, you will get a small box on the corner that shows your color. My default color also turned black and white. I just moved over to a user1 color setting (push the right arrow on your remote), and it allows to the change the colors. You might be able to put the colors to come out through here. Hope this helps.
Jan 28, 2007 | JVC TH-M505 System
Sony DVP-NC665P/S Multi-disc DVD Player Logo
133 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
