Computer powers on. Screen is black. - Computers & Internet
    Guru:
  • 170 Answers
YOU CAN CHECK YOURS POWER ADAPTER CABLES WITH CPU & UPS. IF U CANNOT GET SOLUTION THEN YOU CAN CONTACT WITH ME AGAIN ON MY CELL.NO. +919779366100 OR THROUGH YAHOO MESSENGER: sanjeevkumar.suri@yahoo.co.in OR THROUGH TEXT / SMS MSGS. I M ALWAYS AT URS SERVICE.
THANKS ALOT,
SANJEEV KUMAR
Posted on Jan 22, 2009
Screen is black
If you're getting just a flashing cursor on a black screen it's probably a motherboard/video card/hard disk problem (probably motherboard).
If there's not even a flashing cursor - just a black screen - you can add a failed power unit to your list of problems.
The easiest way to check is to borrow a power unit and video card from a friend's computer. There's no need to remove your existing power unit. Simply disconnect the power cables from the motherboard and connect the spare power unit in its place.
If your computer powers up it is obviously a faulty power unit to blame. IIf there's still nothing on the screen, power down the computer and replace the video card with the spare one. If there's still nothing on the screen when you power it up then in all probability your motherboard is history
Nov 29, 2013 | HP Computers & Internet
HP laptop screen is black
A blacked-out screen doesn't necessarily indicate a broken monitor.
If the computer has run out of charge or is in hibernation or sleep mode,
if the screen is too dark, or if the display cable has come disconnected from the motherboard, the screen may appear black or fail to turn on. To fix a blacked-out laptop screen, troubleshoot the screen settings, check the LCD connector and see if the computer is awake and receiving power.
Touch the touchpad or move the external mouse to see if the computer is asleep or hibernating. If the computer fails to respond, press "Enter" on the keyboard. Press the power button if the screen remains black.
Confirm that the power indicator light, found at the front of the computer or above the keyboard, is glowing solid green or blue. Confirm that the power adapter is plugged into the computer and into a wall outlet. Confirm that battery indicator light is glowing solid green or blue. Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases.
Some computers also use the "F6" or "F7" keys to increase screen brightness.
Hold down the power button for 10 seconds to turn off the laptop.
Remove the AC adapter from the computer, close the screen, and then turn the PC over.
Slide the battery latch to eject the battery. Pull the battery out of its compartment. Turn the computer back over, open the lid, and insert the edge of a flathead screwdriver or other flat, solid object beneath the bezel above the keyboard. Wedge the edge of the keyboard bezel off of the top cover.
Work your way along the edge of the keyboard bezel to loosen it.
Pull the bezel off the laptop.
Trace the cable coming from the laptop screen to the connector found beneath the bezel. Reconnect the display cable to the motherboard if the cable has come loose from the connector. Line up the tabs on the bezel with the slots along the top of the keyboard. Insert the right edge of the bezel into the gap above the keyboard, and then push the bezel back in place. Turn the computer back on. If the laptop screen is still blacked out, connect an external monitor to the video port on the side of the PC to confirm that the video card isn't defective. If the external monitor works, the LCD screen could be broken. If the monitor doesn't work, the motherboard or video card might need to be replaced. Hope this helps
Jan 08, 2013 | HP VM114UA notebook
My mp3 player screen went black, it is getting hot on the inside, and when i press the power button and press it to play, i get a repeating noise. computer will not recognize it. and screen stays black,...
my mp3 player screen went black, it is getting hot on the inside, and when i press the power button and press it to play, i get a repeating noise. computer will not recognize it. and screen stays black, what is wrong
Jul 08, 2010 | Philips SA3025/37 Flash MP3 Player
Black Screen!
perform power drain. take out the battery and unplug the power adapter. press and hold the power button for 30 secs. put the battery back in and plug in the power adapter then turn on the computer.
May 03, 2010 | Computers & Internet
Screen black computer laptop not starting ,hp pavillion entertainment pc,power lights on but screen black screen black computer laptop not starting ,hp pavillion entertainment pc,power lights on but screen...
hi,
if nothing(even hp logo ) is not coming on the display then please try this.
1.remove the battery and then press the power button for 30 sec.Again refix it and check.
2.If windows sound is there then this mught be the issue with display.
3.If there is no windows sound might be the issue with RAM so please get it checked.
May 29, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
Screen went black; power cord is working but won't power computer
the power plug on the laptop may be loose or broken
Mar 03, 2009 | Acer Aspire 3680 Laptop
Samsung monitor troubleshooting
my computer power is on and my computer also start quick but the screen of the this moniter start after 15min to 30mins this problem how to solve.
Aug 23, 2008 | Samsung SyncMaster 540N 15" LCD Monitor
Black screen
how can u fix this black screen? the green power light is on, shows vista for a bit then turns black and stays black. any solutions or do i have to send it back?
Apr 03, 2008 | Microsoft HannsG HU171D 17" LCD Monitor
Dell monitor
Monitor Help CH000315, Black borders on side of screen. CH000316, Dead or black pixels. CH000403, Macintosh and/or PC monitor compatibility.
Black borders on side of screen. Additional information about what causes black borders on computer displays.
Good Luck, Please dont for get to Vote/Thank You.
Dec 19, 2007 | Samsung SyncMaster 712N 17" Flat Panel LCD...
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
