Question about Cell Phones
IPhone error 0xe000084 - Cell Phones
Trying to backup iPhone 6s on my computer using iTunes and keep getting error code 54.
Please refer to the following link:
https://www.imobie.com/support/how-to-fix-itunes-sync-iphone-error.htm
How to Fix Unknown Error (-54) about iPhone/iPad/iPod Cannot Be Synced Sometimes fixing your iTunes sync error (-54) seems a little difficult because it is hard to find which files cause this problem. In this case, you have to sync separately to find what kind of data you can't sync. For example, you can sync only songs to iPhone 6 or iPhone 7 to check whether the music files cause this unknown error (-54).
Of course, there are some common tips you can try to fix this error:
  • Update your iTunes to latest version, now the latest version is iTunes 12.6.2.
  • Upgrade iPhone/iPad/iPod touch to latest iOS operating system. Now you can update to iOS 10.3.3. (The iOS 11 will come out soon, you can update to it when it is available.)
  • Authorize computer in iTunes.Open iTunes > Choose "Store" on iTunes menu and authorize your computer.
  • Change permissions of your "iTunes" folder or original files/folder. You can find the originals that you want to transfer to iOS device and change permission. iMore give us one example to change "Read Only" permission of "iTunes folder" to fix iTunes sync error (-54) on Window 10:
    Open Windows Explorer > Go to "Music" folder > Right Click "iTunes" folder > Properties > Uncheck "Read Only".
  • Run iTunes in administrative mode. Sign in to Windows as an administrator > Right click iTunes icon > Select "Properties" > Select "Compatibility" > Check to run as administrator.
  • (For Windows iTunes users) Install all available Windows update service packs. iTunes sync error may be caused by incompatible driver on your windows pc.
  • Use an iTunes alternative After trying solutions mentioned, if your iPhone still cannot be synced due to unknown error occurred (-54), you can try some iTunes alternative, like AnyTrans. As one of the best iTunes alternatives, AnyTrans allows you to transfer media files (like Music, Playlists, Movies, TV Shows, Podcasts, iTunes U, Audiobooks, Voice Memos, Apps, Ringtones, etc.), and won't erase the existing data on your iPhone iPad. Click Here to Download AnyTrans >
Oct 11, 2017 | Cell Phones
I wrote a text message to someone today and at the bottom of the message in a gray box popped the word Velkomin
Hi, you can try FoneDog iOS System recovery.
  • Fix with various iOS system issues like recovery mode, DFU mode, white screen looping on start, etc.
  • Fix your iOS device to normal from white Apple logo, black screen, blue screen, red screen.
  • Only fix your iOS to normal, no data loss at all.
  • Unfrozen your iPhone, iPad and iPod touch
Here are some articles for FoneDog:
Tips & Trick to Fix Your iOS System
iOS System Recovery Guide How to Fix with Various iOS System Issues
May 16, 2017 | Cell Phones
Why does an error message continue to pop up when I am trying to restore my iPhone?
Since you didn't mention the error code number, I am going to assume it is 3014 because it is the most common iphone error associated with restoring the iphone. A fix which have been confirmed to work in most cases can be found here:
Fix iPhone Error 3014 iTunes Error 3014 During iPhone Restore
Sep 24, 2014 | Apple iPhone 5S
I got an error on my 8GB 2G iphone "This iphone
Please make sure you've SIM card inserted in the phone and then connect your phone to itunes.
Mar 16, 2011 | Apple iPHONE 2G 8GB
Hi there.. I have same problem here with my Iphone 3gs
my iphone dosent start normal when i press power botton its start on recovery mode only and if i try to recover and restore it but shows error "your iphone couldent be restored"
Sep 06, 2009 | Apple iPhone 3G
Iphone not sybcing with itunes,error pops up with #13019
error (13019).is iPhone Sync Error if you uncheck ‘sync music’ box then sync your iphone it will sync correctly It is a problem that got to do with the Voice Memos although its not limited to voice memos if the problem persists try unchecking the sync voice memo
Sep 01, 2009 | Apple iPhone Smartphone
Cell Phones Logo
1,249 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
