Question about Samsung Washing Machines
No err appears and not spinning, changed the circuit board still not spinning
  • Samsung Master
  • 17,130 Answers
Have you checked the motor separately, have you checked the process cycle of machine, if this does proceed then it can be related to mechanical issues of motor or shaft jamming, faulty door switch, faulty connections, faulty water level pressure sensors.
Posted on Jan 12, 2013
Sports art model 1050L give me err 1 how I can fix this problem? Thanks
Reason number 1:
Explanation for ERR1 1. Motor doesn't operate; ERR1 appears. 1-1. Explanation: Drive board has not sent power to the motor, so the motor doesn't operate; the optic sensor signal hasn't returned to the display board. This is caused by either a bad mcb or a faulty motor.
Reason number 2;
Reason for ERR1 2. Motor operates; ERR1 appears 2-1. Explanation: The motor operates; the optic sensor signal didn't reach the display board CPU; ERR 1 appears. In this case the issue is more than likely a faulty speed sensor or a there is dirt, lint or other debris blocking the speed sensor from reading the disc.
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Dec 19, 2015 | ART Exercise & Fitness
Sports art model 1050L err 1 how fixed ?
Reason number 1:
Reason number 2;
I'm getting a r16 error on my D90
The "r16" in the display is not an error code. It is simply informing you of the number of exposures that can be held in the camera's internal high speed memory before shooting would have to stop while the D90 transfers the pictures to the memory card. If you held the shutter release, you could watch the r16 value decilne by one for each exposure (r15, r14, r13, etc.).
Page 256 of the D90 User's manual indeed shows the Err error code, and defines it as a "Camera Malfunction", "Release shutter. If error persists or appears frequently, consult Nikon-authorized service representative." The "err" error code is a generic error. The camera has detected a problem, but it doesn't know exacly what, similiar to the fEE code. The "err" code could be camera / lens contacts or it could be a circuit board or even shutter failure. You've already tried the common contact cleaning fix (that never seems to solve the problem) without any luck, so you might have to call Nikon Support and arrange for service.
Jan 31, 2013 | Nikon D90 Digital Camera with 18-105mm...
I have a wep p7-500 line printer .this printer give a err -48v circuit * see manual
its related to PPC Board... replace ppc board...need to repair PPC Board..
Jan 06, 2011 | Printronix Line Matrix P5005B Printer
What is ERR 1 Ec?
The "ERR 1EC" is a SERVICE ERROR CONDITION that usually indicates a faulty color "printhead assembly" or faulty "main board PCB assembly" [PCB = Printed Circuit Board].
Nov 06, 2009 | Epson Stylus Photo 915 InkJet Printer
My coffee maker reads err rr 2 and then err 4
Probably, the unit is short circuited from water flooding over the electrical boards. :(
Nov 05, 2009 | Kitchen Appliances - Others
E030 err on statrt
• Total copy counter (open circuit)
• DC controller PCB (faulty)
Feb 06, 2009 | Canon NP 6050 Copier
Re: KitchenAid Coffee Pot
I had a similar problem with Err 1, Err2, and Err 4. To resolve Err 1, if you have room, remove the coffee filter and coffee, pour more "warm" not hot water into reservoir. If you have 4 cups cold water add 5 cups warm. Then start coffee maker and let it run thru. Then drain coffee pot and start over to make coffee with tepid water. Err 1 indicates the coffee maker temp sensor is too cold from room temp or water temp.
Err 2 is a result of cleaning. First question "Did you remove the charcoal filter?" The charcoal filter can be removed form the filter stick by prying two tabs away gently and removing the filter for removal. The filters can be purchased @ www.Kitchenaid.com
One pot run thru with descaler can loosen scale and make sensor go "blind". Just run a full pot of clean plain water thru one maybe two times. A pot solution should be a solution of 1/4 pot WHITE vinegar, 3/4 pot clean cool water. Run this thru once, then two clean pots of fresh water as if you brewed a pot of coffee. NEVER USE CLR WITHOUT RUNNING NO LESS THAN THREE CLEAN WATER POTS THRU MAKER!!!! This is so you can continue to enjoy drinking coffee, nothing like a cup cleaning you out!
Err 4 is simple, you have a stuck button. Unplug maker and gently press each button making sure they aren't stuck in.
Jul 20, 2008 | KitchenAid KCM511OB 10-Cup Coffee Maker
My washer doesn't spin
check the drain motor working or not , if it is working change the power circuit board
Jan 07, 2008 | Malber P21 Front Load Washer
Washing Machines Logo
19 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
