Question about Ultra Buick Park Avenue Series 03-05 Brake Rotors Rear
Some of my steering wheel controls do not work such as heat adjustment temp. down (up adjustment works) and volume up and down doesn't work any advice?, also my display for my climate control is out but it works other than that
    Genius:
  • 1,669 Answers
The wires or contacts on the wires are corroded or worn out. Since they are mostly in the steering column wiring harness you may have major problems, but first check the connector from this harness to the main fuse box for a loose connection. It may be as simple as that to fix...I hope!
Posted on Jan 12, 2013
  • 2 more comments
  • Tiffany Closson-Johnson
    Thanks!
    where would the main fuse box be located
  • Leigh Perlmutter
    Leigh Perlmutter Jan 12, 2013
    There are 2 one in the engine compartment and another under the left side of the dashboard.
  • Leigh Perlmutter
    You are most welcome.
Radio volume control on 2007 Subaru Tribeca does not work, but remote volume control on steering wheel works. Any suggestions on repairs?
Radio volume control on 2008 Subaru Tribeca does not ...
www.fixya.com/.../t25735073-radio_volume_control_2008_subaru_trib...
Jun 7, 2015 - Radio volume control on 2008 Subaru Tribeca does not work, but remote volume control on steering wheel works. ... does not... Replace the volume control(rheostat) inside the radio. .... Oct 09, 2014 ' 2007 Subaru B9 Tribeca.
Nov 04, 2013 | 2007 Subaru B9 Tribeca
Horn & Cruise control doesn't work
The clock spring has gone bad. You will have to remove the steering wheel to gain access to the clock spring (used to be called the turn sig. switch) But if you are going to perform this repair make sure you dis-connect the battery before you began because you could set off the air bag in the steering wheel
Mar 09, 2013 | 2001 Oldsmobile Aurora
Cruise control not working
The adjustment of the brake light switch or it could be bad. the brake lights can work fine and the part of the switch that works the cruise doesn't The swiches that control it from the steering wheel can losse connection in a part called the clock spring. Vacume connections can effect the cruise but yours is likly cables less therefore doesn't work the cruize.
Oct 09, 2012 | 2005 Chevrolet Equinox
2001 Town and Country Steering Wheel Radio Volume Switch Broke
The circuit for the switch goes through the clock spring contact is the likely cause of the switch not working, it is not connected to the wiring harness in the steering column that goes to the radio.
Sep 19, 2012 | 2001 Chrysler Town & Country
Heat stays on even when temp is cool and compressor doesn't work
Have a professional diagnose the communication between the main control board, and the timer.
Aug 14, 2012 | Frigidaire FAH125P2T Air Conditioner
MKS Steering Wheel Audio controls
My MKS had this exact problem earlier this year. I took it in and they ordered and replaced the buttons. It worked fine for about three months and now is starting to act up again. Have you gotten any definitive answers?
Apr 02, 2012 | 2009 Lincoln MKS
Engine cuts out when steering wheel tilt is adjusted. Also, cruise control not working.
For the cruise control, check the fuses under the steering wheel. As for the engine cutting out, don't adjust the steering wheel while driving.
Apr 16, 2011 | 1994 Mazda MPV
Air will not change from floor to dash to deforst outlets
Hi wayner, There is a cable that need to be adjusted that is under the steering wheel. look under there and you will see 2 cable that can be adjusted. These cable open and close the air blend doors.
Mar 28, 2009 | 2000 Hyundai Accent
Ultra Buick Park Avenue Series 03-05 Brake Rotors Rear Logo
Top Ultra Computers & Internet Experts
Gareth Cockram
Gareth Cockram
CheckitRight
CheckitRight
ed_coyle
ed_coyle
Are you an Ultra Computer and Internet Expert? Answer questions, earn points and help others
