Question about Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher
Fridgidaire/electrolux dishwasher model FDBB2040FC3 control panel
"hi temp wash" and "air dry" lights blinking continually. Will not respond to "cancel" or anything else. Dishwasher not working at all. Is this the control panel? If it is, how much to replace and have it repaired? The appliance is 4 years old..
aborcass
  • 2651 Answers
SOURCE: Just had a power outage, dishwasher is dead
althought e breakers apear to be on physcally turning them off and then back on especcially after power flashes(the breaker might of partially tripped, and needs to be reset(possible)
Posted on Mar 16, 2008
huuum
  • 750 Answers
SOURCE: Problem starting fridgidaire model FDB1050REC2
hello kwill8
welcome to Fixya.
You said, You just installed the dishwasher and the only cycle it will go through is the rinse cycle. When You turn the dial to any of the other cycles:pots&pans, normal, light wash and upper rack, the start button as well as the heat dry button and the high temp button do not work. only button that will light up when pressed is the delay button. How can you fix this?
Is this your model FDB1050REC2This is a brand new model and you said you just installed it!
If it is brand new!
You do not have to fix it.
You have a full years warranty, parts and labor!let them fix it no cost to you.
The first thing they will do, . You can do your self!
Go to the breaker and turn it off for 5 minutes and then on again. This should reset the system and this usually is the end to most bad starts!
try it!
Huuum
Posted on Oct 03, 2008
SOURCE: Frigidaire Dishwasher (model FDB1050REB0) Wash Light Flashing
Well, I've got a different problem. I need a control module!!!
BUT!
The flashing WASH light appears to indicate the door latch (switch) is not fully engaged. I proved that I mine which works, just doesn't pump out/drain water. If I unlatch the door and then press START, the WASH light blinks.
*WARNING* 120V ELECTRICAL CURRENT! ONLY ATTEMPT THIS IS YOU KNOW WHAT YOU ARE DOING!
The switch is located behind the control panel (5 screws from the inside.) The Hot (Black) AND Neutral (White) wires comes from the electrical input and pass through the switch. You can do a simple continuity check with the power disengaged to test the path through the switch and into the control module (pins 3 & 9m black and white).
Now... anyone have a Control Module (working) they want to give/sell to me so I don't have to go buy a new dishwasher? I just replaced the drain valve on mine :( If you do, you can send me a note vidioteic (at) gmail (dot) com
Happy Washing!
Posted on Mar 28, 2009
  • 6 Answers
SOURCE: frigidaire pld4375rfc2 dishwasher
don't buy this manufactors products the are not weel made!
Posted on Sep 28, 2009
SOURCE: Flashing "Washing" light on my frigidaire 1000 series dishwasher
Possible solution. I had the same problem of "washing" light flashing last year and now today. Warranty has been expired for awhile, so no harm in trying. What worked for my situation was removing the six screws for the back of the plastic control cover. Take of the plastic cover. There are are two connectors to the HANDLE with white and black wires. To be safe I would shut off the ciruit to the dishwasher. Safety first. Carefully disconnect and inspect the contacts inside the connectors. Do not insert any metal objects if you left the power on. I believe that the moisture from the dishwasher can degrade the connectivity. I cleaned the contacts with q-tips and re-installed. Be careful to not bend the contacts. If you had sound, you could hear my dishwasher running. Total cost is about three cents. I believe that the connectors do not full close when corroded, which prevents the completion of the circuit to the controlls. The flashing light indicates that the door is open, when in fact it is closed. Hopefully this will help someone. Semper Fi
Posted on Feb 06, 2010
Normal wash light is blinking but, won't start
Hello friend, thank you for your post!
From the information you have provided regarding the heated dry and washing lights blinking on your Electrolux dishwasher it sounds like it could be a possible problem within your control board. I would recommend resetting your appliance which you can by flipping the household circuit breaker in the off position for roughly ten minutes. If you continue to receive the blinking lights I would reach out to a professional to come and diagnose your appliance. I hope this helps. -Matt
Aug 12, 2014 | Electrolux Dishwashers
Kenmore Dishwasher Model 665.16719000 pushpad buttons lights flashing and won't work.
Press "high temp wash, heated dry, High temp wash, heated dry, high temp wash, heated dry, high temp wash, heated dry, high temp wash"
All the lights will go solid at which point you press cancel to reset the board.
**NOTE** if you don't have a "heated dry" button, use the "air dry" or "energy saver dry" button instead.
Apr 03, 2014 | Kenmore Dishwashers
My KUDS011JBSO undercounter dishwasher is blinking the normal wash light. What do I need to look for to fix this?
Hi
If light is blinking then it may be an issue with heater circuit, door switch or the thermal fuse, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry or High Temp Wash-Heated Dry-High Temp Wash-Heated Dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the thermal fuse located on the control or the door switch that is bad and should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Aug 31, 2011 | KitchenAid Dishwashers
Blinking lights, unresponsive
I went to the Maytag site looking for a manual. None existed for my model, but I looked up won't start under the FAQs. The advice said to push the cancel button twice. My model doesn't have one, so I just started at the left side of the control panel and pushed each button twice. pushing the dry button twice made the lights stop blinking. i pushed the wash button and the unit started.
May 08, 2009 | Dishwashers
Kenmore 665 15899
To reset and run diagnosis on the model 15899100 Kenmore Dishwasher you need to press the following buttons on your front panel. Hi Temp, Air Dry, Hi temp, Air Dry. The sears service technician just left my house and used these codes to reset and run diag on my washer.
Hope this helps
Jan 05, 2009 | Kenmore 15899 Built-in Dishwasher
Two blinking lights on top
lights on my asko dishwasher start blinking into the cycle
Nov 18, 2008 | Dishwashers
Blinking Clean Light
  • Close dishwasher door
  • press "Hi-Temp Wash"
  • press "Energy Saver Dry"
run the 'normal' cycle without the hi temp feature
Nov 16, 2008 | KitchenAid 24 in. KUDI01FL - Multiple...
Clean light keeps blinking and I can't start a new cycle
Puppa, clear the fault by pressing the keys in this order: high temp scrb--air dry--high temp scrub--air dry. Or, depending on your model..Sani rinse--air dry--sani rinse--air dry. The dishwasher will enter the service mode. Let it do it's thing or advance it through it by pressing the start key. The fault came from the board not sensing a rise in the water temp. Make sure to run the hot water before starting the dishwasher. The heating element runs through the nuetral side of the door switch so make sure the d/w is level and the door switches are all making. The element itself could be at fault. Catriver...post back
Apr 01, 2007 | Kenmore 24 in. 15932 Built-in Dishwasher
Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher Logo
35 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Garth Jackson
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
