Question about LG RH1999H DVD Recorder/HDD Recorder
My LG Hdd/DVD recorder(RH-2252) cann't support Arabic subtitle and show subtitle by the unknown font.
SOURCE: Recording problem with LG RH266 Recorder..
Just bought unit. Had same problem.Tried lots of different types of disks with no luck. Tried to play already written +R disk. Worked OK. Then took out and replaced with blank -R. Came up with new screen asking me if I wanted to initialize disk. Answered yes and it took about 20 seconds. Then tried to DUB from HDD to DVD again. This time it came up with the dubbing menu, I hadn't seen before, and worked.
Hardly ideal, but the trick was to get it to recognise it as a blank and initialize. Currently burning my first disk. Didnt realise about 'FAST' mode, so taking ages.
Posted on Apr 19, 2008
SOURCE: Can't get rid of subtitles on HDD recording. Must
I have a toshiba RD-88 DTKB dvd/hdd recorder, when i record on hdd subtitles are on when playback,tried everything to rectify ?
Posted on Jul 30, 2009
SOURCE: LG HDD DVD recorder RH7521W is not able to read
Mine had a similar problem. I assumed there might be some dust on the laser. I used an air compressor and pointed it at the DVD slot as it was opening and closing to blow some air around inside the unit (and hopefully dislodge any dust). It worked. The discs that would not play before did play after. I didn't have the air compressor nozzle too close to the opening as I didn't want to dislodge anything I wasn't supposed to. If it was dust on the laser, you might be able to clean it in other ways, such as removing the cover and using a cotton tip (take power off first!). That would have been my approach if I didn't have an air compressor.
Posted on Feb 02, 2010
SOURCE: Stop Substitles on a LG RHT497H 160G dvd recorder?
I have the LG DVD recorder DRT389H which has the same problem. You can't switch off the subtitles during timer recording from the Electronic Programme Guide. The only way I could stop this was to go to the main set-up menu then select the A icon. Select DTV Subtitle and choose a language that the TV programme isn't broadcast in. I chose Gaelic. The only disadvantage is that this stops any subtitles being recorded so you can't access them later.
Posted on Jun 13, 2010
SOURCE: LG HDD DVD Recorder remote control not working with LG TV
I have a rh 265 remote and lg tv. It stopped controlling the tv. I hold the tv power button down on remote then pushed 1 at the same time. It reset it to work with my tv.
Posted on Jul 24, 2010
I need to update the software of my LG DV532how can i acieve that?
You dont need to update your software of your dvd,you just need to make sure your dvd usb supports arabic or just do this, Search your movie in google with SUBTITLE ex.Superman subtitle, then if you found your language download it, usually it is a .zip file when you download it ex Superman subtitle.zip you will need to extract that using winrar or any extract tool, after extracting the file should end with .srt ex. superman subtitle.srt, if it is, make a folder in your usb then copy the movie and subtitle in it (make sure the movies name and subtitle name are the same ex. superman.mp4 and superman.srt) then play it.
Mar 06, 2016 | LG Televison & Video
Hello, I'm trying to display Arabic srt subtitles ...
If you have Arabic lang. in your windows, and you have the movie (.avi) and the subtitle (.srt) in the same folder with exactly the same name for both 2 files, and you use VLC as media player .. then:
1-Download (Subtitle Edit 2.9.3) software .. it's free!.
2-after setup .. open the subtitle (.srt file ) and adjust "defult file encoding" (same window-left side) to: UNICODE
4- Save (from file tab).
5- You can also adjust the time (later or earlier).
In case you have any questions, my e-mail:
06october1973@gmail.com
Enjoy..Regards
Ahmed Hosny [Egypt]
May 21, 2010 | Pioneer DV-350 DVD Player
Subtitles appearing on screen in recording mode on LG RHT497H
You are confusing subtitles with closed captioning (CC).
Nov 19, 2017 | LG RH177 DVD Recorder/HDD Recorder
Dec 26, 2009 | LG RH177 DVD Recorder/HDD Recorder
Can I copy vcr tapes with the LG RH 1999H dvd/hdd recorder?
I use the av2 input in the front of the recorder to copy my vcr tapes to the hard drive
Apr 27, 2009 | LG RH1999H DVD Recorder/HDD Recorder
DEAR SIR my LG rh-2252 dvd recorder has problem.it turn on,but just show in display box:hello and a few minute later :please wait please wait please waite. but it does nt work.no voice,no picture
some dvd recorders take a while to come on if you turn it on with no disc in and wait for it to load up also check that the cables are all in correctly and you are on the correct channel it should show a start up screen also try changing the channel through the dvd recorder if this does not work and you have read through the manual contact the manufacturer or supplier
Nov 29, 2008 | Televison & Video
Dodgy DVD burner
After completion of recording in the DVD, you have to finalised the DVD then after u can read with other devices
Jun 02, 2008 | LG RH1999H DVD Recorder/HDD Recorder
May 29, 2008 | LG DE9523P DVD Player
No sound from LG HDD DVD recorder
Same Problem here, have not done anything yet, but I am convinced that it is due to blown Capacitors in the Power Supply......
Apr 25, 2008 | LG RH-4820 DVD Recorder
LG RH1999H DVD Recorder/HDD Recorder Logo
256 people viewed this question
Computer Repairing
Computer Repairing
