Question about Superheadz Clap Digital Camera
My Clap digital camera just blinks the light and no pictures are taken. The light blinks when it's off and when it's on. HOW DO I FIX IT???
The light just blinks whenever I try to take a picture. It blinks when it is on or off. No pictures are on the MicroSD card, and I've tried changing MicroSD cards. It still doesn't work. HELP!? What's wrong with it? Do I need to buy a new one? :/
Every image taken with my Samsung D1070 is overexposed.
Hi there:
Some symptoms of a defective CCD include distorted images or abnormal colors, scratchy purple lines, blank or black pictures, and/or black videos with good sound being recorded on the camera's flash card.
A CCD problem would explain the lines on your pictures and the lines on the LCD (since the CCD is used to feed the live image). CCD (Charge Coupled Device) is one of the two main types of image sensors used in digital cameras.
When a picture is taken, the CCD is struck by light coming through the camera's lens. Each of the thousands or millions of tiny pixels that make up the CCD convert this light into electrons. The number of electrons, usually described as the pixel's accumulated charge, is measured, then converted to a digital value. This last step occurs outside the CCD, in a camera component called an analog-to-digital converter.
In order to correct this issue, the repair facility needs to replace the CCD. This is not something you may do on your own; check this article for additional details:Bad CCDs. This, isn't a good new, but hope helps to solve it.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Aug 16, 2012 | Samsung Cameras
Intermittent blanking on pictures displayed
There's nothing wrong. The blinking areas are blown-out highlights. These are the portions of your picture that the camera thinks are overexposed.
While viewing the picture, press cursor-up/down to cycle through the different views of your picture.
May 06, 2012 | Nikon D40x Digital Camera
My Olympus Stylus 6000 has a red flash indicator blinking when turn on. When try to take picture, it sounds two beeps but no picture will be taken. What seems to be the problem?
Just to let you know I have got the same problem and I didn't find the answer. May be the flash light bulb is broken after an impact or so. Only thing I can think of...good luck! Sx
Jul 21, 2011 | Olympus Stylus Tough6000 Protective Clear...
Recently my Canon camera stopped taking pictures. It will take a picture if the flash isn't needed or of you turn the flash off; however, if the flash is needed, the orange flash light will come on...
If your camera is under warranty bring it to the nearest Canon Agency to have it check and repair. Most of the time the problem is mechanical and only the qualified technician can fix it.
Jun 19, 2011 | Canon Cameras
When I turn on my camera, it shows a black screen, so I'll take a picture anyways and its black.. no picture ..is it fixable or should I throw it away? Next to where the flash goes off..there is a...
Is the lens protector opening in the front of the lens???
If it is and things are still black then throw it out... it will cost more then it is worth to fix...
Lens Errorfix for Digital Camera
heatman101
May 26, 2011 | Fuji FinePix F460 Digital Camera
I try to take a picture in AF mode while the confirmation light in the viewfinder blinks, a picture cannot be taken, but in MF mode picture taken correctly what is the problem?..
It's attempting to tell you that AF has failed. I'd expect low light, low contrast, reflective subject like a mirror or chrome. A solid colour wall with no contrast will also cause a AF failure. Auto Focus relies on contrast. Switching to manual mode shuts off the system and you can take a picture with nothing in focus.
Nov 24, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Canon flash does not work
The flash has to charge in between shots, so if you are not waiting long enough it won't charge and wont take the shot.
If you are waiting, Im not really sure...
Jul 13, 2009 | Canon PowerShot A610 Digital Camera
I wanna take a picture but i dont know how to make the camara wait 10 sec before it takes the picture
Self-timer shooting:
This function lets you take pictures using the self-timer.
Fix the camera securely on a tripod for self-timer shooting. This function is useful for taking
pictures when you want to be included in the photograph.
1 Select [ON], and press Z.
2 Press the shutter button fully to
take the picture.
• Pressing the shutter button halfway
locks the focus and exposure.
• The self-timer lamp lights for
approximately 10 seconds, then starts
blinking. After blinking for approximately
2 seconds, the picture is taken.
• To stop shooting while in n mode,
press the shutter button fully again.
• To cancel the self-timer, press Z.
• The self-timer mode is automatically canceled after one shot.
Note:
• If sequential shooting is attempted in self-timer mode, the camera shoots 5
frames at most regardless of the setting.
Hope my info fixes your problem,
Thanx for using fixya,
cheers.
Sep 26, 2008 | Olympus Camedia D-595 Digital Camera
Pictures taken at night yellowihs an dreddish
In photo editing programs there are Hue settings where you can easily fix that problem. There are off course night lens filters but not for amateur cameras.
Apr 10, 2008 | Polaroid A500 Digital Camera
Terrible over exposure..
i just got a new camera the dimagne x50
and i brang it out today and it was working fine it didnt drop or anything
i took a picture then turned it off then i turned it on agian and when it was on the camera format the light kept on blinking yellow for the longest time and wouldnt let me take a picture so i tried the video format and it worked so im just wondering why the video format is working and not the camera ?
has this happened to you? is there any way of fixing it?
Mar 14, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Superheadz Clap Digital Camera Logo
41 people viewed this question
Top Superheadz Cameras Experts
Are you a Superheadz Camera Expert? Answer questions, earn points and help others
