Question about Dishwashers
Takes several attempt and several minutes to start the dishwasher...all keypad, no dial. The lights come on and then shut off automatically..
There appears to be a short in the control panel, I've only had this machine for 1 1/2 years.
  • 17,130 Answers
Possible that there is moisture within the control panel and which could result in malfunctioning of the board. Remove the board and use a hair dryer to warm off the moisture within ,cool off and reset checking all connectors and links. If this wont work then it can be due to faults within the board or the touch pad which could be damaged.
Posted on Jan 12, 2013
SOURCE: jenn air diswasher mod # JDB1100AWS
disassemble front door to get to the latch. Check if the latch is properly in place, sometimes the metal cylinder that hold it in place, slips out of position.
Posted on May 19, 2009
  • 6 Answers
SOURCE: Dishwasher KUDC25CH; Control Panel is not working
WASH THE DISHES URESELF U LAZY ****!!! :)
Posted on Oct 17, 2009
Macmarkus
  • 2605 Answers
SOURCE: Dishwasher will not shut off automatically
Hello, This sounds like a very common problem with Bosch dishwashers unfortunately, that is based on your description it likely has a faulty heater relay. The "1" is actually an error code identifying a heating fault. The issue with Bosch dishwasher`s most times lye`s within`the electronic timer/control, specifically the heater relay solder joint. ( a faulty flow switch, ntc or heater can also cause this error code "1", but not very probable ). I`d first suggest calling in an authorized bosch servicer, however If you feel capable there`s a way to visually inspect the control. It will require you to remove the control from the unit and then remove the control from it`s plastic housing and look for a burnt solder contact on the printed circuit board. This will be one of the pins from the heater relay, hence the unit sit`s and takes forever top finish ( because it can`t heat to advance or until canceled ) trying to heat the water. **Further to this, if you or someone you know is proficient at soldering, a lot of times it can be remedied by simply repairing the solder...although Bosch recommend`s replacing the control and I don`t pretend to speak on there behalf nor do I profess to know better. This is just my experience (it work`s) and my opinion (why buy new if one can repair ?)** **Please disconnect the power before attempting any service to the dishwasher. If you do not feel comfortable attempting this service, call a local pro, preferably one familiar with Bosch/Thermador/Gaggenau, to service your machine.** Hope this answer`s your question, let me know if I can assist you further. Thank`s for visiting "fixya" for your repair inquiries. Please take a moment and rate this solution and leave a testimony. Good luck. macmarkus :)
Posted on Apr 12, 2010
  • 3247 Answers
SOURCE: I can't get the control panel to reset. The
II might need the actual model number. However, you can go to page 9 on this manual and check if the flashing options can fix the problem. I am assuming you have already tried to turn the power off and back on.
The ohter thing to try is the reset sequence. Within 6-7 secs press High Temp/ Heat Dry/ High Temp/ Heat Dry/ High Temp/ Heat Dry. All lights should light up, press Start button to exit.
Posted on Jun 24, 2011
SOURCE: maytag quiet series legacy 300
their is power to the dishwasher but the control panel does not light up and the machine will not start or run
Posted on Jun 30, 2011
Frigidaire dishwasher stops in mid cycle
two things to look at : water level sensor ? seems I once had a machine that the water inlet valve never totally shut off and it overfilled basin this shut machine off on a spill sensor fault but took several minutes to do this , Also the door closed switch , seems they do get finicky as time goes on and even thought door stays closed the movement of machine opens the door switch up (not the door) this also takes several minutes to occur
Sep 02, 2015 | Frigidaire Dishwashers
The control lock light is on and the machine wont start
You should be able to toggle off the Control Panel Lock by pressing and holding the Energy Saver Dry pad for 4+ seconds. If the light doesn't go off, try shifting your finger position on the touch pad. I have a few appliances where the angle pressure has to be just right for a "press and hold" to be recognized.
If several attempts fail, the keypad, wiring or the main board aren't communicating properly. Please check the model number of the dishwasher; there are several KUDS01FLSS models. Go to http://www.kitchenaid.com/customer-service/manuals/ and enter the model to get the parts list. Some parts are available from Appliance Parts Pro: http://www.appliancepartspros.com/search.aspx?model=kuds01flss . The user interface is here: http://www.appliancepartspros.com/whirlpool-user-interface-8270168-ap3085303.html .
I hope this helps.
Nov 19, 2014 | KitchenAid 24 in. KUDS01FLSS Built-In...
Whirlpool quiet partners II normal light flashing
CHECKING KEYPAD OPERATION
A rapidly blinking LED over one of the keys of the keypad (or sometimes a "dead" keypad/console)
To determine if the control or keypad is faulty, do the following test:
1. Unplug dishwasher or disconnect power.
2. Open the dishwasher door.
3. Open console and disconnect the keypad ribbon connection from the control (at P1).
Make sure all other connections are made.
4. Put console back together. Do not close the dishwasher door.
5. Plug in dishwasher or reconnect power.
6. Wait 5 seconds.
7. Close dishwasher door.
8. Monitor the control's response:
If the control is OK (no longer sees shorts with the keypad unplugged),
it will respond by turning on a Drain Motor for 2 minutes.
Check and/or replace the keypad if the control responds OK.
If the control is not OK (still sees shorts with the keypad unplugged),
then the drain motor will NOT respond and will remain off.
If no response, replace the control.
Dec 18, 2013 | KitchenAid 24 in. KUDI02IR Built-in...
Dishwasher won't start
its the timer in the dial replace it and it will work fine yes its worth fixing
Dec 03, 2012 | Kenmore Dishwashers
Dishwasher starts then pauses and drains.
Fixed! I had the issue where the cycle would start, the KUDS30IXBL8 would hum 4-5 times and then drain. Plastic folk pieces jammed in the disposer. These instructions took a few minutes (only 5 screws and a couple clips) to figure out how to take it apart, and it only took 60 seconds to put back together. How To Repair Dishwashers KitchenAid Repair Chopper Replacement
Apr 25, 2012 | KitchenAid Dishwashers
I have a Frigidaire model#PLD4555RFCO the er code and the washing and drying and clean and S lights are on and blinking on the display. have any ideas what the problem is?
Hi
"Er Clean S" is a common error with Frigidaire which means shorted keypad. The issue is with the touchpad/keypad that should be replaced. However, before replacing the keypad you can unplug it and take it apart completely and use a hair dryer to blow some warm air on the keypad assembly to blow the moisture off. Hope this helps...please post back for further assistance.
Daniel
Aug 27, 2011 | Frigidaire Professional Series 24 in....
I have a GE QuietPower3 dishwasher... the normal wash, heated dry, hot wash and hot start buttons are all flashing... can you tell me what is going on please?
try this, I was researching and found that this solution worked. While all the lights are blinking, close the dishwasher door and let the machine run through the cycles. This actually happens pretty fast. Then it will stop and quiet down and all the blinking lights will shut off. Then just press the buttons you want and hit start and the machine will start. The time it takes for the blinking light to shut off is about 1 to 2 minutes. It worked for me.
Aug 09, 2009 | GE Dishwashers
Security light
Bad contacts in the ignition lock cylinder.
Mar 28, 2009 | 1999 Buick Century
Dishwasher cycle "holds'
hi there,
check the keypad. it has a ribbon cable that plugs into the control board. it may be loose.
Sep 23, 2008 | Maytag 24 in. MDB7600A Jetclean® II...
Electrolux gas single oven
due to safety feature you should have oven door closed,turn dial to 1,ignite then turn to 5or 6 hold it in for a few seconds and release.this should solve your problem
Jul 27, 2008 | Electrolux EOG6330 Gas Single Oven
Dishwashers Logo
47 people viewed this question
Top Dishwashers Experts
