Question about Brother 1034D Serger Sewing Machine
Brother 1034d presser foot lift arm not working
The little plastic piece has fallen off and I don't know what direction to try and put it back.
  • J. Baker Jan 13, 2013
    It is the little plastic piece that actually raises the presser foot. It is at the end of the long rod at the end of the lever.
JeremySew
  • 65 Answers
SOURCE: need presser foot holder
Here are the parts you need:
Brother Sewing Machine Presser Feet & Shanks
Posted on Jan 05, 2009
SOURCE: threading brother 1034D
on u tube the show you step by step how to thread the Brother 1034d.
Posted on Apr 06, 2009
SOURCE: visual inside brother 1034d overlock
kindly go to http://www.retrevo.com/support/Brother-1034D-manual/id/19095dj686/t/2/
you will finde manual for your machine
Posted on Aug 20, 2009
  • 3 Answers
SOURCE: Brother 1034D
I had the same problem with the blue thread- it would sew and inch then pop- mine worked wihtout breaking after I re threaded in this order: green, blue, red then yellow
Posted on Sep 17, 2009
  • 1116 Answers
SOURCE: How do you thread the brother 1034D serger? A
You can download a free manual at the Brother website http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_1034D_ENES_178.PDF
Posted on Mar 16, 2010
My Brother 1034D Serger presser foot lifter just spins. I had read that its just glued into a little plastic piece. Has anyone had this same problem and if so did you just glue it back? Did it wor
I had the same problem a while back and ask here. I was told to take it to a tech. Not the answer I was looking for. I did some searching and found a diagram then knew what I needed. Here is my reply...
I just replaced mine. wasn't hard at all. I couldn't find just the plastic part, had to buy the whole thing. First it is called a Presser foot shaft assembly, part #xb0876001. You can buy it from Sew4Less.com and it cost me 25.57 with shipping. You will have to remove the front cover and take out the two screws holding the bar in. You will also need to remove the lifter bar and end panel to get the bar out. Insert your new part and replace the covers and lifter bar. This is how I fixed mine. Hope it helps.
Jan 14, 2015 | Brother 1034D Serger Sewing Machine
The presser foot on the brother xl-5130 has fallen off
please send me a picture and I will gladly assist you with all the help you may need ;)
Nov 20, 2013 | Brother XL-5130 Mechanical Sewing Machine
Threading a needle
1. Turn handwheel toward you 2. Raise presser foot up 3. Pull thread from spool and pull taut under each tension disk. It's important to "feel" the "click" if you are new to threading machine 4.Make sure after all tension disks threaded that you put thread behind the slot in back of your needle. It's a little groove to hold thread securely. 5. Pull thread toward you 6. Thread needle eye front to back 7. Pick up thread under gently pull taut in front of you 8. Lower presser foot and turn handwheel toward you. A loop will form under the needle where needle thread has picked up the bobbin thread. Carefully take both threads that have made a single loop and pull toward you 9. Put threads under presser foot just lift put threads under and pull 5 -6 inches thread BACK and UNDER that presser foot Done! Hope this helps, my friend! Jimmy
Mar 30, 2012 | Sewing Machines
I have a Bernina Bernette serger 004D/004 and the presser foot has fallen off the machine can I fix this myself?
The presser foot is a 2 piece thing, remove the foot, then remove the top bit that the foot attaches to (the shank). Look at the bottom of the shank while pressing the little lever or button on the back of it, you will see how the foot attaches to the shank.
Oct 18, 2011 | Bernina Bernette 75
Thread in bobbin keeps getting caught. I'm doing something wrong putting it in.
Hello
The bobbin case is not properly installed.
Remove the bobbin case and make sure the thread from the bobbin is feeding from the spool in a clock wise direction and through the guide on the side of the bobbin case.
Raise the needle to it's highest position and this will move the shuttle to it's proper position.
Lift the lever on the back of the bobbin case, with the arm on the case pointing toward the ceiling and slip into the shuttle.
Bend your head down and you will see the shuttle has a slot for the arm to fit into.
Once you get the feel for this you will not have to bend down for a bird's eye view!
Always thread a sewing machine with the presser foot up. Make sure the threading sequence is correct and the thread has not slipped out of the take up lever.
Hold onto the top thead end and lower then raise the needle to pull up the bobbin thread. Pull both threads under the presser foot and to the back of the machine.
You should now be able to sew without any issues.
You can get a manual from Brother (free download). Refer to the maintenance section for cleaning and removal of the shuttle parts for lubrication, if required for the model you are using.
Aug 01, 2011 | Brother LS-2125 Mechanical Sewing Machine
My bobbin keeps bunching up. I've changed the tension to 2, taken the bobbin case out, used a different bobbin....I don't know what to do. My machine is a month old and I've used it, maybe 4...
Put the tension back up to about 5. Rethread the machine entirely, and make sure you have the pressure foot in the up position when you rethread. If your getting bunching on the bottom, it's probably your top thread that's bunching up. After you rethread, put a small piece of fabric under the pressure foot, lower the pressure foot, and turn the handwheel in the forward direction and watch the thread as it comes around the bobbin case. If it goes around smoothly, try it with the foot control. If it hangs up as it goes around the bobbin case, you might have a burr on the black plastic bobbin case. Take it out, check for any burrs, sand them down, and try again.
May 07, 2011 | Brother SE350 Mechanical Sewing Machine
I cant figure out how to install the buttonhole foot
Do you just need to attach it to the machine? Or are you having trouble using the foot itself?
It attaches the same way the other feet attach. Remove any foot that may still be attached to the machine. On the buttonhole foot look for the small silver pin that sits on the sliding piece with the small red line marks on it. Lift up your presser foot lever and attach the buttonhole foot's silver pin the same way you would attach any other foot.
As far as using the foot itself place your button on the back sliding piece snuggly till it fits in without falling out, adjust as needed. Pull the bottonhole lever down (it's located on the machine opposite the side of the presser foot lever) so that it rests behind the first lever on the buttonhole foot (small plastic piece raised on the left hand side of the foot that doesn't move). Slide the feed dog switch on the back of your machine so the feed dogs go down. Select your stitch and go. The machine automatically stops when done.
Hope this helps!
Feb 11, 2011 | Brother CS6000i Computerized Sewing...
Presser foot stopped working I turned
Did you connect your machine then press the foot control before you lowered you presser foot? I have a CS6000 and that is what E1 means on my machine. You did not put your model number in so I don't know. You can look in your manual or go online to www.brother-usa.com and look it up for your machine. Try unplugging and plugging it in again, but put your presser foot down then step on your foot pedal.
Oct 04, 2010 | Brother Sewing Machines
My 1034D Brother Serger foot raiser lever on
mine just did the same thing - i opened it up (you have to remove the light) and it's a small plastic piece that seems to be just glued into place to lift the pressure foot when it rotates... a bit disappointing - i will try glueing it back but i don't know if it will last for long. i am very disappointed!!!
Feb 24, 2009 | Brother 1034D Mechanical Sewing Machine
Brother 1034D Serger Sewing Machine Logo
116 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
