Question about Shark S3601 PROFESSIONAL STEAM MOP
Where to buyshark mop O ring
Where can i buy O ring or what size is it
How can I extend the hose so I don't have to bend so far down when I vacuum. I am tall
You could try wearing the cleaner like a backpack...
I live in a small town and there are at least two businesses here where I could buy vacuum cleaner hose by the metre.
I have also seen purpose-made 1 metre hose extensions.
It isn't always easy but I have repaired and replaced hoses, changed ends and generally managed to use surplus and discarded hoses rather than buy new.
I suggest you approach the sort of business that supplies vacuum cleaners and washers and suchlike to other businesses rather than a high street type shop.
Feb 25, 2015 | Miele Olympus S2120 Canister Vacuum...
Can't find ORECK filter #AT2PK, been waiting for months for the ORECK store to get them. WHY!!!!!!!!!!!
They discontinued it. Just go to any aquarium and buy a carbon filter pad and cut it to size. They sell big sizes for under $10 and just stick it in your Oreck Air 5 air purifier. Works just as well and cheaper!!
Aug 27, 2013 | Oreck Air Purifiers
How do i take the Shark S3601 apart?
Water is spilling from the hook upconnection to the carpet slider.
Solution: It needs to replace an O ring in the junction.
Question is: How do I remove the junction?
Dec 30, 2012 | Shark S3601 PROFESSIONAL STEAM MOP
I have 4 GS6000 two of them are printing 1/8 or 1/4 bigger than the size shows in PhotoShop. Does anyone have any idea why?
First make sure there really is no invisible spacing around the images that are loaded to ONYX, Colorburst, whichever you use.
Is the media you are printing being fed to a take-up-reel, and are you using a tension bar? These all are likely causes. This problem is printer side I'm positive. I have 2 Epson GS6000 printers myself, and this happens often where after printing for a few days the sizes might start increasing.
You may need to go to the printer settings:
PAPER SETUP - PAPER FEED ADJUST - LINE FEED ADJUST
*It will then print some measuring lines that in my case are always close to 19 1/2 inches.
*You will also see on the display a option to adjust numbers
*If the sizes on both marks aren't exact 19 1/2 inches each, you need to add or subtract that amount, and then convert it to millimeters. This is the number you need to enter into the printer.
Press Enter on the printer to submit.
The next test print you do should be exact size you need.
Nov 14, 2012 | Epson Stylus Pro GS6000 Printer
I have been looking to buy an air purifier and people keep telling me to get a HEPA. What does this mean?
HEPA is a type of air purifier. It stands for high-efficiency particulate air. To qualify as a HEPA filter by government standards the filter must remove 99.7% of all particles larger than 0.3 micrometers from the air. The following site lists the top 10 HEPA purifiers available online - http://www.air-purifiers-america.com/AP101_top10.asp.
Jul 12, 2012 | 3M "Replacement Filter, 11 7/8 x 18 3/4"
It just quit!! I have changed the fuse but am not sure what size so it may need a fuse of a different size Would love to just have it refurbished
Call Vollara (the new name of EcoQuest) at 800-989-2299. Use number 16618 as your dealer referral number, and ask customer service to tell you your options. If they can't help you (some machines have been refused service because of illegal eBay sales, dealer fraud, etc.) we may be able to advise you further. fredandmb@frontier.com
Jan 30, 2011 | Ecoquest Fresh Air Air Purifier
I was standing at the the second letter of the alphabet looking for the ring at the middle of the river at the end of the lake the end of the day the ring was found before you.
i love you...
I- first clue L- 2nd letter of the word aLphabet O- ring V- middle letter of the word riVer E- end of the word lakE Y- end of the word daY O- ring U- last clue
Aug 13, 2010 | IQAir Dental Pro Air Purifier
I HAVE A RAINSOFT UV AIR FILTER IN MY AIR DUCT WHERE DO I GET REPLACEMENT BULBS, AND WHAT IS THE PROPER BULB AND SIZE?
Cleanwater also has them. Clean them with rubbing alcohol, do not let your fingers touch the bulbs. And check your 24V ac adapter. If it starts going you will get a power light but the other lights will come and go. I have one and the bulbs are nearing the end of life, not a cheap fix.
http://www.cleanwaterstore.com/O1002250-p-clearwater-tech-parts.html
Jan 02, 2010 | Air Purifiers
Unit does not work even tho blue light shows its on
The bad news is that Sharper Image filed for bankruptcy this year closing all their stores. There unable to honor the warranties on the units and even recalled all Ionic Breeze units.
Here is a link as to what happened to the company:
http://www.aircleaners.com/sharperimage.phtml
You can still get parts for Ionic Breeze at this link:
http://www.airpurifierrepair.com/ProductDetails.aspx?ID=0&ProductId=473&gclid=CKfhotf9_JYCFRxNagodHR10Yg
It could just need some new plates for it.
Nov 17, 2008 | Sharper Image Ionic Breeze 3.0 Air...
Shark S3601 PROFESSIONAL STEAM MOP Logo
Top Shark Air Purifiers Experts
Lawrence Oravetz
David Payne
David Payne
Are you a Shark Air Purifier Expert? Answer questions, earn points and help others
