Question about HP LaserJet 9040n Printer
HP laserjet 9040n fail to print, i try out from the LAN cable, all are fine. How can i get it connected?
  • 191 Answers
Download from here
then find the printer in setup .
ifu not find.
then check printer ipadrses.
and set subnet mask and gate way both are same in computer and network printer.
Posted on Jan 22, 2009
In hp 9040 printer print come out but when i have touched it with hand it erased
The fuser unit is not working. if you can rub the toner of net the fuser in not heating up and is probably faulty and needs to be replaced.
bets would be to replace the following
maintenance kit C9152-69004
Dec 27, 2013 | HP LaserJet 9040n Printer
HP laserjet 3055 toner is fine but print blank pages except the test page,. Copies fine too from the glass
Try the following
1. Ensure that the driver is not currupted and is compatible with your operating system.
2. Try changing the connecting cable.
3. Try connecting the device thru both the ports (one by one) USB & LAN. (The driver will have to be loaded for each port).
3. Connect device to a different PC.
4. Download fresh driver compatible to your operating system from HP Support.
5. Perform a NVRM re-set (all stored data will be lost). (refer my solutions available on this forum).
Best wishes
Feb 18, 2011 | HP LaserJet 3055 All-In-One Printer
79 service 9208
I'm sure that by now you power cycled the printer.
Print something from a different application. If you are trying to print a Word document and it is getting the 79 error, try printing something from your email. If that works try the failing app again. If it still fails you might have to reinstall the software. Try a different cable from printer to PC. If you can, try a parallel cable instead of a LAN cable. If you are using a JetDirect, remove it and try a cold reset.
Mar 11, 2010 | HP LaserJet 4050 Printer
I have connected my printer, but there is one symbol showing red. sometimes it can print the test page once, but only once when you try again there is no signal
you r printer usb or network . ok printer driver uninstall first and remove the usb cable after one restart system .Now install printer driver .printer driver Search your printer usb or lan at the time u connect usb .than working fine
Dec 01, 2009 | HP LaserJet P2015 Printer
It is lan printer could not connect give printer failed error from one pc only
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
Mar 20, 2009 | HP LaserJet 1200 Printer
Laserjet 2300d hasstopped printing to a HP Jetdirect 170x suddenly
parallel cable connected?
omg this? "old centronix")
IEEE 1284 standard
parallel-zw1hxsxncju1x1hxxv3nm1gz-1-0.jpg RTM yet? check the manual carefully
The HP JetDirect 300X provides connectivity to 10Base-T and
100Base-TX networks. The HP JetDirect 170X provides
connectivity to 10Base-T ne
tworks. The HP JetDirect EX Plus
provides connectivity to 10Base-T and 10Base2 networks.
HP JetDirect 170X (J3258B):
Bidirectional parallel port (IEEE 1284).
Network port (Ethernet): RJ-45 (10Base-T).
Test button (sends print server configuration page).??????????
2 LEDs on front indicate LAN activity/status
Mar 06, 2017 | HP Jetdirect 170x Print Server
Driver Installation
hi friend
u have to do this
1.plge in ur usb printer cable on usb port not on ur printer
3 put ur printer cd in ur cd rom drive
4install ur printer software
5 in between the installtion ask to u power on ur printer then u have to on ur printer
5 completing the printer installtion
try to print
& thnx uing fixya
Apr 01, 2008 | HP LaserJet 9040n Printer
Try connecting this printer to a different network wall point in the building. If still no change then move back to original wall point and try changing the connection at the Switch end in the comms room.
If still having problems then try pinging the printer to see if it gives time out or execessively high pings. Got a PC on the network and in windows open a "command" prompt and type ping -t XXX.XXX.XXX.XXX where the address of the printer should be place of the x's.
If linux open a console and type the same thing ping -t XXX.XXX.XXX.XXX.
Please dont forget to rate!
Feb 28, 2008 | HP LaserJet 9040n Printer
HP LASERJET 9040n not r4esponding
ok man in system how many printer are installed if u have two printer intalled u have to set ur laser pariner as a defolt printer then after try to print in your network ur laser printer is a defolt printer so try it
Feb 26, 2008 | HP LaserJet 9040n Printer
Flaws at top of each page when printing
Replace toner cartridge drum is scratched
(Possibly by staple going threw machine if that what each of the five marks look like, all those removed staples always seem to end up in printers)
You can pull it out (I think right top cover opens and cartridge pulls up and to the right)  then .. turn it over and gently pull back cover see drum has same marks as you see on paper, you can gently rotate drum by using gear on edge do not force it only turns easy one way, Do not touch drum surface very delicate and sensitive. Normal disposable item buy a New cartridge here is HP part number for your model  HP C8543X (HP 43X) Toner Cart.
Oct 19, 2007 | HP LaserJet 9040n Printer
HP LaserJet 9040n Printer Logo
88 people viewed this question
Ben Johnson
