Question about Exercise & Fitness
Sportcraft tx 390 treadmill will not start no power on top displays
No power on top displays red light on beside motor
  • 15 Answers
SOURCE: TX 4.9 sportcraft treadmill
Info from PDF files located on Sportcrafts website under manuals.
E3 – No speed sensor reading. Unit shuts down. This is the most difficult repair diagnose. The speed
sensor is connected to the frame of the treadmill near the drive pulley on the front roller. There is a
small magnet on the side of the pulley wheel. The sensor tip must be no more than 5mm from the
magnet. If for any reason the distance is greater than 5mm the treadmill will shutdown
Adjust or replace speed sensor.
Treadmill: Speed Sensor Replacement
1. Make sure your treadmill is unplugged before you begin.
2. Remove the motor cover located in the front of your treadmill, it is held on by a few screws.
3. Locate your speed sensor; it is the small T shaped part with a red and black wire coming from it.
4. Remove the 2 screws in the speed sensor and remove the old sensor.
5. Place the adjustment holder on the frame with the open holes facing the pulley wheel, the prongs facing
up and way from the pulley wheel. Insert the screws but don’t tighten fully.
6. Now place the speed sensor over the prongs with the square part facing the pulley wheel and the red and
black wire to the far right.
7. Plug the treadmill back in and slide the speed sensor until it is 5mm from the magnet inside the pulley
wheel, you may have to do this several times until you can position it so it no longer shuts down. Use 2
nickels to figure out the spacing. The width of 2 nickels is 5mm.
8. Once you find the correct position tighten the screws all the way; being careful not to touch any of the other electronics
9. Place the motor cover back on and enjoy your machine.
Posted on Oct 17, 2009
SOURCE: Sportcraft TX 2.5 treadmill - error code 3 - stops
Sorry I dont have the solution but I have the same problem.
Read somewhere that Sportcraft control boards had
a design flaw.
Posted on Dec 20, 2009
SOURCE: My sportcraft tx 2.5 treadmill does not have the safety key
any round magnet that will fit in the hole will work.
Testimonial: "Thanks a lot..This really helped"
SOURCE: Can I fix my Sportcraft TX400 Treadmill ?
adjusting the belt
Posted on Jun 19, 2010
SOURCE: Treadmill stops after 7 seconds
you have a broken spinner. Take hte motor cover off and look on the opposite side of the motor. there will be a partof the spinner wheel there. I have yet to find a way to short cirut the connectors nor a replacement wheel.
Posted on Jan 08, 2011
Starting Problem
see the video attached. LUBE too the rollers bearing front +back and test the drive belt motor, and replace if necessary.
God bless you
Jul 22, 2013 | Sportcraft Tx2.5 Tx 2.5 Treadmill Motor...
Tx 5.o rc sportcraft treadmill varies in speed with or w/o load.
1) adjust the speed sensor, see the diagram attached, test for open or faulty. clean it very well. tight the connector very well
2) LUBE the treadmills very important . do it with silicone or wax. Read your onwer manual for verification.
Jun 03, 2013 | Sportcraft Tx5.0 Tx 5.0 Rc Treadmill Motor...
Sportcraft tx 2.5 banging noise
where is the noise coming from? the deck, motor compartment, etc?
Jun 16, 2012 | Sportcraft Exercise & Fitness
I have a sportcraft tx 2.5 and was cleaning it and some water got into the housing where the motor and circuit board is located. Now all I get is the number 7 on the display and it won't run.
Dear Sir:
1) Please unplug the machine
2) Put with air gum machine, and pass in all board and circuit for heating.NOT OVERHEATING.
3) Wait for 24 hours. if you have some infrared lamps, will be better.NOT OVER EXPOSED.
4) Turn ON the machine, and proof, if the problem remain, the board is faulty. and replace.
5) However try to RUN the software calibration for better diagnose, troubleshooting, and fix it. see the block diagram attached.
God bless you
Jun 09, 2012 | Sportcraft Tx2.5 Tx 2.5 Treadmill Motor...
My Sportcraft TX-400 Treadmill shuts off after 7 seconds
Dear sIR:
This by lack of LUBE, in your schedule maintenance DECK BELT. maybe the belt is worn.
2) Lube the roller bearing.
3) Align the belt see the diagrams
4) Test the input voltage motor, if there are voltage motor, the motor need repair.
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
Now you can RUN the software calibration for diagnose, troubleshooting. See my personal TIPS for HELPs too.
sincerely. God bless you
May 06, 2012 | Sportcraft TX 400 Walking Belt
Location of speed sensor for sportcraft tx 400 treadmill
Look for 2 small wires molded together that come from the vicinity of the front roller, or the front of the motor. Those are the wires to the sensor. They may be routed under the frame and may only visible when the bottom panel is removed.
Jan 23, 2012 | Sportcraft Exercise & Fitness
Exercise & Fitness Logo
161 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
