Question about Tablets & eReaders
Difference between HDD and SATA
Difference between these two devices.
    Guru:
  • 170 Answers
Buying a new SATA hard drive is confusing if you don't understand the differences between the various drive types. Which hard drive should you buy?
SATA Hard Drives (Serial ATA) are the most popular drives being sold today. Alongside them in the store however you will also find boxes labeled Parallel ATA or SCSI. So what are the differences between these hard drives and which one should you purchase? Your decision is dictated by what your computer can accept. Check with your computer's manufacturer to see which drive style you can use. Most newer computers purchased within the last two years accept SATA connections. If your computer cannot accept one of the newer SATA hard drives you can purchase SATA adaptor cards that plug into an empty expansion slot on your computer's motherboard. You can purchase SCSI adaptors as well, so follow these tips to guide your decision.
SATA vs PATA: Serial ATA vs. Parallel ATA Drives SATA hard drives have many benefits over their older cousin, the Parallel ATA drive. Chief among these differences are:
  • SATA hard drives are faster and perform much better than traditional ATA drives and are better for high bandwidth applications such as video editing and multiplayer gaming.
  • SATA drives use a smaller, cheaper cable to connect to the computer's motherboard. These cables can also be up to three feet in length compared to eighteen inches with Parallel ATA cables.
  • SATA hard drives can be hot swappable, meaning that they can be disconnected and reconnected without powering down the computer. There are limits to this of course. You should never disconnect your boot drive while the computer is operating.
  • SATA cables are easier to plug in without damaging the delicate connecting pins on the drive.
  • SATA hard drives are significantly faster than external USB hard drives.
SCSI Hard Drives SCSI hard drives are the elders of the storage world. SCSI is one of the oldest specifications but it is also the fastest and thus has been widely used in network servers and other high speed, high bandwidth applications. Unfortunately this high speed storage has also meant much higher costs. SCSI drives were once standard in all Macintosh computers but have since been replaced by the cheaper SATA based hard drives.
  • SCSI drives are also hot swappable, similar to the SATA drives.
  • Some varieties of SCSI can be used with SATA
  • SCSI drives are often set up in a mirroring arrangment to allow for instant, continuous backups of the hard drives.
  • SCSI drives are still the most expensive drives on the consumer market.
Your basic rule of thumb should be to purchase a drive that is designed to work with your computer's motherboard. Try to avoid using SCSI adaptors or SATA adaptors unless absolutely necessary as the whole point of using a specific kind of hard drive is to get the most speed and storage for the money.
Thanks alot,
Sanjeev Kumar
Posted on Jan 22, 2009
    Sergeant:
  • 191 Answers
HDD :hard disk drive
we can coonect hdd to mothr bord with IDE or SATA connnector.
IDE gives low spped and SATA is beterthan as the relevant to speed.
Wwhy is my tablet froze to EFI MODE
I figured it out. If you did by accident loaded EFI shell and your pc then restarts and crashes sortly after selecting safe mode settings (as if it wishes to load) but a faint blue screen appears then it restarts and same problem.
I am using an XP Home edition package to a H71M-DGS motherboard but this should not matter so longs as you haven't formatted your HD.
Solution: If to reset CMOs manually or in BIOS load default settings does not solve your problem, and even trying a different SATA port :P. Then look at your SATA configurations. I found that the default setting was ADCH then set it to IDE and that should allow boot to your oldish HDD. Hope this solutions helps some may not be the solution for all.
Sep 15, 2017 | Tablets & eReaders
No internal drive appear during booting
Try changing the SATA / IDE mode in the Bios. Make sure the BIOS is seeing the hard-drive.
May 31, 2013 | Motion Computing M1300 Tablet PC
I dropped my panasonic tough book C-484HHUEM when working on it
Yes it is VERY likely the harddrive that is damaged given the symptoms that you are reporting, most especially if the drive was in use when the drop occurred or if it was onto a hard surface. I recommend just purchasing a new 2.5" 320gb sata drive off of ebay (asking to make sure it is compatible with your system) as they only cost $65, and self disassembling. Instructions for disassembly can be found here:
http://www.laohu.co.uk/r4/hdd/cf-r4-hdd.html
otherwise you can take the computer into a shop and pay them to fix it.
Oct 29, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
I am trying to Downgrade an ASUS R1F from Vista Pro to XP Pro. How do I get the tablet to boot from the CD
Hi, if you have computer knowledge, the easiest thing to do is to take the laptop sata hard drive out and connect it to your computer with your sata cables and power and boot your computer up and the laptop drive will be a slave drive then. Now you can back it up if you want and then format it.
Now turn your computer off and put the hard drive back in your laptop. Because there in no Operating system the laptop will ask for a boot device. Now you will be able to boot from your xp cd.
I don't know why but I have found most laptops and computers with vista don't like to boot from a cd and over ride the boot options and go directly into vista which makes it hard for people who want to down grade to XP.
Why someone would want Vista beats me.
You can also load up into bios and change your boot options in there. If not already set as first boot device to be you cdrom/dvd you can change it to be. But like I said most of the time with Vista it doesn't matter! Vista will still boot first. But it is worth trying.
Sep 26, 2009 | ASUS R1F Tablet PC
O*oooooo7b(0*f7a21524,0*c0000034,0*00000000,0*00000000)
If you can install Windows Vista and only XP not work for sure this is the solution :
SATA operation mode is AHCI
To change this :
Open BIOS
Look for SATA Operation Mode or somethin equivalent and change-it to IDE or Compatibility Mode.
Jul 19, 2009 | Compaq tc4400 Tablet PC
Set up did not find any hard disk drivers installed on computer
Your notebook has SATA hdd. Got into the bios (keep pressing F2 key on startup) then in the bios screen find HDD and press enter. Select IDE mode. Press f10 to save changes and exit. When this is done install XP.
Alternatively connect external usb floppy drive and unzip sata drivers into that. When booting from xp cd press f6 to load drivers.Follow onscreen instructions to load drivers and continue xp installation.
Please let me know if issue not solved for futher ts steps.
thanx
May 28, 2009 | Fujitsu LIFEBOOK P1510D Tablet PC
Installation of windows xp to toshiba satellite 1695CDT
10gb of RAM is not enough for Windows XP. You need to upgrade your HDD to about atleast 40 GB HDD Minimal... I'd recommend a new PC if you can get that to work out, but I understand the tuff economical times.. If you need any mroe help ..throw me an email at joey@joeysitservices.com I'll give you some bootable tools that may help!
Apr 16, 2009 | Toshiba (K000680310) for Satellite...
I have a lifebook t2440 i tired to put windows xp home editon it went to setup and started sherching for a pervious operating system and it came back and said no hard disk drive found.what versions of...
That happens because the BIOS uses a SATA controller that is not included in Windows XP install disk.
Usually you can solve the problem going to BIOS settings and changing SATA/RAID settings.Check your BIOS settings, and disable SATA RAID mode.This is done in different ways depending on the BIOS.
On HP/Compaq computers for example you press F2 on startup to enter BIOS, then disable SATA mode on bios settings.
On other makes the procedure can be slightly different.
Another way to fix the problem, is by creating your own XP setup disk with SATA drivers included, see:
Resolving "Setup did not find any hard disk drives" during Windows .
Jan 16, 2009 | Fujitsu LifeBook T4220 Tablet PC
Non System disk
a) remove any external devices and reboot.
or
b) boot from Windows XP setup-cd into rescue-terminal, execute: fdisk /mbr
or
c) do a hdd self-test in bios (restart, press F10, tools --> hdd self-test option --> notebookharddrive) to check the integrity of your harddrive
Sep 21, 2008 | Compaq tc4400 Tablet PC
Installing windows without DVD
The hard disk is not recognized from USB because of SATA drivers not present on XP setup disk.
Mar 17, 2008 | Toshiba Portege M205-S810 Tablet PC
Tablets & eReaders Logo
2,548 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
