Question about GE 169053169077 Blender
My blades dont work they are broken, i also need the part
Why won't the blades turn?
One or both of the drivers are broken, check the clutch on the top of the motor and the other one on the bottom of the beaker. You will find something there worn out or broken.
May 24, 2015 | Blenders
Broken blade housing
I have the whole blender. White with a red glass pitcher. I have only used it twice. For ice. What would you pay for the whole blender? You would then have a back up of it all. Works fine. Just too heavy for me.
Jun 18, 2013 | Jenn-Air JBL800 Work Top Blender
Where can I find a blade & gasket for my Juicelady JL 600 Blender?
i have a blade and gasket that i am willing to sell. my base is broken so I have no need for it now.
email me at mimitascoe@gmail.com
May 28, 2011 | Juicelady JL600 Professional Work Top...
My kitchenaid blender does not whizz around when it is put together> the couplking spins when the glass part is off that is, when it has nothing on it> the coupling does not look used or...
There are really only two reasons why the blades won't spin, either the coupler is broken, or the blade unit is damaged. Check the picture of the blade unit here: Check pictures of the coupler here: Hopefully it should be obvious whether the coupler is ok, if it is, are both wings on the wingnut under the blade unit?
Feb 16, 2011 | KitchenAid KSB3 Classic Work Top Blender
Blade won't spin
Check the blade with it off the base and make sure that it spins freely. Check the spindle on the base and see if it feels hard to turn. If the spindle turns too easy , then the connection inside the base is broken and needs replacing.
May 02, 2010 | Blenders
Need white base that blade sits on.
I'm going to super glue the crack that is causing mine to leak.
Jul 28, 2009 | Back to Basics Smoothie Elite Work Top...
Drive gear is slipping. Motor turns but the blade fails to turn
sounds like a shear pin either on the motor or the blade assembly. If you put the blender on low without the cannister on top touch the gear on top of the unit and see if the gear slips or stops. Use a pencil or something..Not your finger. If it stoops then the pin is broken at the motor. If not, it is broken at the blade unit.
Hope this helps
Kurt
Mar 17, 2009 | Back to Basics Smoothie Jr. B Work Top...
Leaking fron the blade assembly
HELLO
there are two possible solutions
1 change seal or 2 change seal and blades in order to improve the life or your blender.
bye
j roman.
Mar 07, 2009 | VillaWare 5785 Smoothee Bar Work Top...
VILLA WARE 5767
my blender jar is broken. I need to replace it
Aug 05, 2007 | VillaWare 5787 Double Smoothee Work Top...
GE 169053169077 Blender Logo
15 people viewed this question
Top GE Blenders Experts
Pamela Leach
Pamela Leach
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a GE Blender Expert? Answer questions, earn points and help others
