Question about Bowflex Tc5000 Climber Treadclimber Treadmill Bow Flex Tread Climber Tc-5000
After two minutes tc 5000 stops with an error message
After two minutes treadclimber stops with an error message
5 Suggested Answers
rockfixya
  • 679 Answers
SOURCE: Bowflex Treadclimber tc 1000 turns off
Problem could be low colant, water pump, fan not kicking on (bad sen or bad fan motor) radiator dirty,
so the Treadclimber not working properly.
I hope this helps u
Thanks for using FixYa.
Posted on Jan 30, 2009
SOURCE: bowflex tc 1000 treadclimber
TC1000 from Bowflex, works okay for 15 mins then the speed surges ahead and stops dead with error E1
Posted on Jan 12, 2010
maxtreadmill
  • 832 Answers
SOURCE: Bowflex TC 1000 treadclimber causing power surges
You are not on a dedicated circuit the amp draw must be significant thus pulling down the voltage causing your grief. Find a and outlet that is not on the same circuit your electronic units maybe in another part of the house. Or put in a new circuit if you have a vacant in the breaker box, but that need a qualified electricians to do the job$$$$$
Posted on Jul 19, 2010
ercupa190
  • 12223 Answers
SOURCE: my treadclimber 5000 treadils stops runing when I get step on the right one
Recalibrate the machine if speed is not registering, belts stop turning or the display readout shows an "err, LS, OS" on the face. Calibrate the Bowflex TreadClimber 5300 by plugging it in. Stand on the foot platforms, or floor mat. Do not stand on the walking belt. Insert the safety key. Press the "start" key when "CAL/PRSS/STRT" shows on the readout. If readout fails to show the "CAL/PRSS/STRT" symbol, turn off machine and turn it back on. Press "ENTER" and then "DOWN SPEED" at the same time until "CAL/PRSS/STRT" shows up on the display. Belts will start and stop during the calibration; do not be alarmed. Do not make any adjustments or interrupt the display of numbers as the unit goes through the calibrations. When the machine is finished calibrating, the readout will display "CAL...PASS" and you can press the "POWER" key to get out of the calibration section
sincerely.
Posted on Nov 28, 2011
Tread climber starts up and shuts down in a few seconds. Starts clicking
Bowflex Treadclimber Shuts down - Questions - Fixya
www.fixya.com > Forum > Treadmills > Bowflex > Bowflex Treadclimber
Bowflex Treadclimber, shuts down related issues. ... After a few times of shutting down due to the heat. Ad ... It shuts down about 60 seconds after it starts.
Customer Reviews: Bowflex TC3000 Treadclimber
www.amazon.com/Bowflex...Treadclimber/.../B000B...
Amazon.com, Inc.The second time I used it I slowed down the speed and worked on getting the ... After researching the TreadClimber for over a year (the cost was a big factor .... We were never able to make the treadles go up and down more that a few inches. ..... a great workout However it continually shut offs while working out and Bowflex ...
Comments for Bowflex TreadClimber Problems
www.treadmilltalk.com/bowflex-treadclimber-user-comments-comments....
Oct 30, 2013 - NOTE: My comment about Bowflex Treadclimbers is also one I left in another area. ... seems like no one sprung the extra few bucks to pay for someone to put the ... In my case , after the initial startup, the machine stops EVERY time at ...nearly spine snapping shutdown at exactly 32 minutes after starting. 5.
[PDF]Bowflex® TreadClimber® 1000, 3000 & 5000 - Nautilus
download.dfxi.com/.../SM/Bowflex/BFX_TC135_SM_RevA_web.pdf
Jan 27, 2016 | Bowflex TreadClimber TC10
What is the problem with treadclimber malfunction 84 u 1.1?
Try to run the treadmill @ 10kph. W/o using it. If the problem comes up. The problem is only the speed sensor..
and if the treadmill is in normal condition with out someone using it. @ 10kph. The problem is only lack of lubrication. You need to lubricate the treadmill before you using it. To prevent the motor from breakdown.
Jun 09, 2014 | Bowflex Treadclimber
Why does my Bowflex TC5000 cut out?
If you're running the machine on a dedicated circuit then your unit is drawing too much current. This can be caused by friction and drag. Solution: Lube deck/belt. If problem persists, replace deck/belt. If you ignore this fix this will blow your controller. .
Apr 29, 2014 | Bowflex Tc5000 Climber Treadclimber...
My bowflex treadclimber tc 20 is putting out error codes H03,H13,H24 whats wrong
I have the exact problem. My machine is 3 days old. I am also getting this H03, H13, H24 error. I called the 1-800 number for the Treadclimber TC20 and they informed me that a handful of machines were sent out with a bad control board. I am waiting for a replacement board.
Apr 14, 2012 | Bowflex Treadclimber
After approx. 30 min. of walking on full speed it
I had this happen on our machine after about 5 years of use. I just recalibrated it and it appears to be working fine now. See the manual for information on the steps needed to take in order to do this.
Jul 11, 2009 | Bowflex Treadclimber
Bowflex tc 1000 treadclimber
Jun 28, 2009 | Bowflex TC1000 Treadclimber
I hope this helps u
Jan 29, 2009 | Bowflex Treadclimber
Bowflex Treadclimber tc 1000 turning off
Napa 8300 silicone. Spray on each walk deck under the belts. just a quick shot from front to back in a fluid motion. test unit and see if it still shuts down.
Bowflex Tc5000 Climber Treadclimber Treadmill Bow Flex Tread Climber Tc-5000 Logo
19 people viewed this question
Top Bowflex Exercise & Fitness Experts
Howard
Howard
Glenn Mayer
Glenn Mayer
ka4iup
ka4iup
Are you a Bowflex Exercise and Fitnes Expert? Answer questions, earn points and help others
