Question about HP Computers & Internet
Reseting Bios password for HP Compaq dx6100(MT) PC
  • 423 Answers
SOURCE: i installed network driver of hp compaq dx7380 mt but it not instal
hi ^^
well firstly you have to download "your uninstaller2008" then delete any driver you have installed
secondly go to this website http://www.touslesdrivers.com/index.php?v_page=29 clic on " lancer la detection " wait a minute and you will have a list of you latest drivers for your pc " and its free"
if you have any trouble contact me at yami_cazanova@hotmail.com
Posted on May 29, 2009
nicoleFIXIT
  • 154 Answers
SOURCE: don't reset password BIOS HP DC7100
If you cannot access the machine after if has been powered up, it is still possible to get past the BIOS password. The BIOS password is stored in CMOS memory that is maintained while the PC is powered off by a small battery, which is attached to the motherboard.
Open the CPU casing locate the CMOS battery in motherboard and remove this battery, all CMOS information (including the BIOS password) will be lost. You will need to re-enter the correct CMOS setup information to use the machine. The machines owner or user will most likely be alarmed when it is discovered that the BIOS password has been deleted.
On some motherboards, the battery is soldered to the motherboard, making it difficult to remove. If this is the case, you have another alternative. Somewhere on the motherboard you should find a jumper that will clear the BIOS password. If you have the motherboard documentation, you will know where that jumper is. If not, the jumper may be labeled on the motherboard. If you are not fortunate enough for either of these to be the case, you may be able to guess which jumper is the correct jumper.
This jumper is usually standing alone near the battery. If you cannot locate this jumper, you might short both of the points where the battery connects to the motherboard.
If all else fails, you may have to clear the BIOS password by resetting the RTC (Real Time Clock) IC (Integrated Circuit) on your motherboard.
Many RTC's require an external battery. If your RTC is one of this type, you can clear the BIOS password just by unsocketing the RTC and reseating it. Good luck!
Posted on Oct 04, 2009
SOURCE: how to update Bios in HP Compaq DX6120 MT?
OK well ya have to go to the manufacturers web site here http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=12454&prodSeriesId=402168&prodNameId=402170&swEnvOID=1093&swLang=13&mode=2&taskId=135&swItem=PSG_I22640-107317
Download to say your desktop etc, You then must make a Bootable Floppy disk, with the BIOS file on it. Then using the BIOS manager you run it, you are asked for BIOS name, after which, the software will write the BIOS file to the chip, when it is finished reboot and all should be good. There is more info at that web site too.
Posted on Jan 26, 2010
SOURCE: my hp compaq dx6100 mt wont start and red light appear on start button
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous. Most times the problemis with the memory or Video Card. Count the Blinking Lights or Beeps and takenote of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.Maybe your memory is bad or the memory slot is bad.Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Posted on May 25, 2012
bronk50
  • 27725 Answers
SOURCE: i cant get windows 7 sound and graphics drivers for hp compaq dc5100 mt
http://download.cnet.com/nvidia-graphics-driver-windows/3000-2108_4-10630932.html
http://download.cnet.com/nvidia-graphics-driver-windows/3000-2108_4-10630939.html
http://download.cnet.com/Realtek-AC-97-Driver-Windows-Vista-Windows-7/3000-2120_4-10962344.html
http://download.cnet.com/2000-20_4.html
if these drivers are not right
on the home page you should see a search tab just type in what you are looking for
IE: motherboard name vga also sound drivers
hope it helps
Posted on Jun 18, 2012
How to update bios? what is the latest firmware?
Be careful with these on-line updates, because after restart you'll get a black screen. Try to discover what exactly you have inside, board name, revisions .... Than ask HP what to do?
PC Servis Kompjutera Kod FONTANE Popravka Odrzavanje Laptop Racunara
Feb 03, 2014 | HP Compaq dx6100 PC Desktop
Bios does not show onboard audio devices
hi, check out the following link, it has a lot of useful information.
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?lang=en&cc=us&contentType=SupportManual&prodTypeId=12454&prodSeriesId=402168
Regards
Dec 21, 2012 | HP Compaq dx6100 PC Desktop
Hp6100 pc FI probalme
my adsl not accpt password or username
Mar 28, 2011 | HP Compaq dx6100 PC Desktop
Dear Sir, kindly provide hp compaq dx6100 mt mother board manual (catlog) tks rgds
You need to open your pc and identify the mother board type. as they will differ from pc to pc.
Jan 29, 2011 | Computers & Internet
Unable to start by showing error as the CD-ROM is missing
Go to your BIOS setup and check to see that your CDROM is properly configured. Save and reboot. Good luck
Sep 12, 2010 | HP Compaq dx6100 PC Desktop
Give me password for compaq evo n600c
You can remove your bios password by reseting your CMOS battery or jamper. You need to open your notebook remove first the battery and all screw at the back of your notebook. You can see there a CMOS battery together with the CMOS jamper. Just read it you can read CLRSCR which means clear cmos, just pull it with in 10 seconds and insert it back. Now you are done to reset bios.
Mar 03, 2010 | HP Compaq Evo Notebook N600c
How to update Bios in HP Compaq DX6120 MT?
Jan 26, 2010 | HP Compaq dx6100 PC Desktop
Booting error
This is One of the Known Issues on Hp Products...
There are Updates Released by Hp for Most of the Model facing this issue...
The Products for which the Solution (drivers) have been Released so far in the DX series are...
  • HP Compaq dx6100 Microtower PC
  • HP Compaq dx6100 Slim Tower PC
  • HP Compaq dx6120 Microtower PC
  • HP Compaq dx6120 Slim Tower Desktop PC
  • HP Compaq dx6128 Microtower PC
  • HP Compaq dx7200 Microtower PC
  • HP Compaq dx7200 Slim Tower PC
  • HP Compaq dx7208 Microtower PC
  • HP Compaq dx7300 Microtower PC
  • HP Compaq dx7300 Slim Tower PC
  • Your Product is not listed.
    You got to Report with the HP and they Will update you once they have a Driver for you,
    However what you can do is try and run BIOS update if Possible.(it may not be Possible in a Boot issue though).
    Jul 17, 2008 | HP Compaq Business Desktop dx2200 - P4 524...
    Computers & Internet Logo
    329 people viewed this question
    Top HP Computers & Internet Experts
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
