Question about Taco 265-1 / 563-2 Combination Analog 24 Hour Clock Timer/Temperature
Dont know how to operate the Taco Clock Timer 265
2 Suggested Answers
SOURCE: manual for taco clock timer 265
I was having the same problem and came accross these instructions. The following link is a PDF file. The first page relates to an analog timer and the following pages relate to a more advanced digital one. Good luck.
http://www.taco-hvac.com/uploads/FileLibrary/102-067.pdf
Posted on Sep 03, 2009
Are there instructions on line on how to set the ACE 265 timer? If there are, please give me a link. Thank you.
Copy following link for instructions how to set analog timer:
http://waterheatertimer.org/How-to-set-timers.html
Also decide if you want to use timer or use built-in thermostat operation:
http://waterheatertimer.org/Water-heater-recirculation-system.html
Add a comment and describe timer in detail so correct identification can be made
Jul 13, 2013 | Taco 265-1 / 563-2 Combination Analog 24...
Clock does not rotate
If clock does not rotate, then check if outlet has power. Check for loose wires.
If clock rotated before and stopped working, then clock motor might have gone bad.
Replacement clock: Taco timer uses the FM1 timer module.
Voltage and timer information appear on back of timer.
Open following links to identify timer and model number:
http://waterheatertimer.org/images/FM1-5-image.gif
http://www.intermatic.com/products/ec%204%20layer/mechanical%20time%20switches/modular%20din%20rail%20timers/fm1%20series%20-%2024%20hour%20and%207%20day.aspx
For example Taco timer module is 24 hour, and 120Volts, and doesn't have battery back-up.
-If timer has on-off-timer switch, then model number is FM1STUZH-120U
-If timer does not have on-off-timer switch, then model number is FM1STUZ-120U
More resources:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#FM1
Sep 17, 2011 | Taco 265-1 / 563-2 Combination Analog 24...
Where is the on switch, for constant hot water located?
Question posted under Taco digi timer control
http://waterheatertimer.org/images/Digi-dial-image.jpg
http://waterheatertimer.org/images/Taco-265-3-timer-600.jpg
Taco must have stock of old digi timers because that timer is discontinued.
It's a good timer. It's just been replaced by less attractive, more complicated digital timer with fewer buttons.
The manual switch for this timer is located at top and is denoted by 'hand' symbol.
Press left side for ON and right side for OFF.
Aug 23, 2011 | Taco 265-3 Digital 7 Day Programmable...
Have a taco 24 hr timer on water heater of home we purchased. pls descvribe how to set it to circulate the water just twice a day for a couple of hrs. thx, mg
Your question is very big because recirculation systems have a lot of parts and options.
Please open following link for re-circulation system resources that show pictures of how the system works. After reading information, add a comment with more questions.
The page shows two different types of Taco timers. One timer is programmable and the other timer is called analog timer where the timer dial rotates just like a clock. Small pins located on dial face are set inward or outward. As the dial rotates, the pins move a tiny on-off lever that turns the pump on-off. The pump can also be set to operate thermostatically. You choose either timed operation or thermostatic operation using slide-switch located under timer dial.
Look at, and read information on link above. Try some things on your timer so you are familiar. And then add a comment with specific description of your Taco timer, and include what you have done so far.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 11, 2011 | Taco 265-1 / 563-2 Combination Analog 24...
My Taco Time Clock 265 Analog is not working. I overloaded the circuits last week and the GFI outlet 'died'. I have replaced that outlet, but the time clock is not operating. Help, I long for immediate hot...
Yes it should be easy to replace.
The manual appears on following link:
http://www.taco-hvac.com/uploads/FileLibrary/102-067A.pdf
'Analog' timer has dial face that rotates as time passes, the 'digital' timer has programming buttons.
The manual seems very straightforward.
Turn power off, connect wires, set timer.
Of course what seems simple to experts who do wiring each day, may not seem simple to person asking question. So add a comment with specific detailed question if you need help.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
Mar 02, 2011 | Taco 265-1 / 563-2 Combination Analog 24...
I bought a new house and the water heater has a circulating pump with a Taco 265 timer. No instruction manual so I can't figure out how to set the timer. You wouldn't happen to have a little instruction...
Maim website:
Main website Search for Taco 265-1 gives link to manuals:
http://www.taco-hvac.com/search.html?gsearch=Taco-265-1&action=results&cb_products=YES&cb_filelibrary=YES&cb_news=YES&search_type=all_terms
Direct link to pdf manual:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} http://www.taco-hvac.com/uploads/FileLibrary/102-067.pdf
Instructions show series of actions to set digital program
Press h key ...
Press m key...
Press Day key...
Press Prog. key to enter...
Sep 10, 2010 | Taco 265-1 / 563-2 Combination Analog 24...
Manual for taco clock timer 265
Mar 11, 2009 | Taco 265-1 / 563-2 Combination Analog 24...
Taco   265-1 / 563-2 Combination Analog 24 Hour Clock Timer/Temperature Logo
29 people viewed this question
Top Taco Hardware & Accessories Experts
deton8 von Splosion
Gene Haynes
Are you a Taco Hardware and Accessory Expert? Answer questions, earn points and help others
