HP Compaq Presario Media Center SR1750NX (EL445AA) PC Desktop Logo
Patricia Jennewein Posted on Jan 12, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Our compaq presario sr2011wm will not come on, the green light comes on but fan not running, there is a lot of dust on fans
Ricky brashear
Level 2:
Sergeant:
  • Expert 176 Answers
  • Posted on Jan 12, 2013
Ricky brashear
Expert
Level 2:
Sergeant:
Answers
176
Questions
0
Helped
89502
Points
529
I would remove power and blow out the dust in the fan and then power it back up but i am gussing you have bad power supply. these are easy to replace and you can get the power supply model number and order one online
good luck
5 Related Answers
Chuck68
Ganesan Chandraiah
  • 42 Answers
  • Posted on Jan 25, 2009
SOURCE: It will boot up to the windows screen and freezes.
If your computer was able to boot up but unable to load the Windows, the most common cause would be the recently intstalled software or Windows update.
To remove this, follow these steps. Skip Step 1 if it is not relevant.
Step 1: Removing recently added hardware
Use the steps in this section to disconnect any recently added hardware and test for the error.
NOTE: If a new internal device (sound card, hard drive, or other) was added to the computer before the error message started to occur, you have to remove it before continuing.
  1. Turn off the PC and unplug the power cord.
  2. Disconnect the mouse, and any other peripherals attached (Printer, scanner, webcam, zip drive, phone cord, network cable and other devices). Leave only the keyboard and monitor cable attached.
  3. Press and hold the power button on the front of the PC. Release after 10 seconds.
  4. Plug the power cord back in.
  5. Turn on the computer.
  6. The computer displays the We apologize for the inconvenience... message. Allow the timer to count down from 30 to 0.
  7. If the computer successfully starts to the Windows desktop and does not restart to the error message, connect one device and wait until Windows recognizes it.
  8. To find if a device is causing the error, continue connecting the devices, one at a time, restarting the computer each time, until the device that is causing the error is found.
NOTE: If this does not solve the issue try to do a system restore BUT it will delete all your files and programs you install by yourself after the system. You will be able to use the pc as a new pc.
Anonymous
  • 52 Answers
  • Posted on Apr 15, 2009
SOURCE: HP Compaq Presario SR1820NX will not turn on
i worked for hp and compaq it is well known issue to reslove this issue
1#turn off the computer and uplug the power cable from the computer and then hold the power button for 20 second then turn on the computer and the momment you back to desktop screen
go to download driver from hp site and here is the web site http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=pv-43507-1&lc=en&dlc=en&cc=ca&lang=en&os=228&product=1841849 and restart the computer .
pankaj_dic
pankaj rautela
  • 1252 Answers
  • Posted on Sep 17, 2009
SOURCE: Compaq Presario SR1650NX will only
DO one thing remove the RAM from the slot , then insert it again, then check
Anonymous
  • Posted on Jan 26, 2010
SOURCE: green light comes on and the fan but monitor will not
Does it display on your monitor "No Input Signal"? If so it could very well be your motherboard. Same thing happened to me. :(
Anonymous
  • 31 Answers
  • Posted on Feb 12, 2010
SOURCE: Black Screen Compaq Presario
Do you see the BIOS splash screen or anything?
Try booting into safe mode by pressing F* as soon as you power on the computer. If the monitor works, then it is a bad driver. Roll back to a previous restore point, boot to last known good coonfiguration. Last Known good configuration is available from the same as the safe mode screen.
If this is helpful, please comment and rate. Have any other questions, please let me know.
Oz
Won't start but CPU fan vibrates but will not go full blast. Intermittant
It appears you have a faulty CPU fan and it is causing the CPU to overheat and shut down.
I suggest you replace the CPU fan. remove any dust from the heatsink and put new heatsink compound on the CPU/heatsink.
3answers
I have a problem with my compaq presario cq60 due to overheating atimes the laptop turns off automatically when it gets too hot with is the problem
check the underneath of the laptop, there should be several access panels, remove these and look for fans, clear them of any dust you can see, the main fan should be blowing through a heatsink (lots of small fins) try to get to the part between the fan and heatsink as sometimes you can get a lot of dust build up there.
Compaq presario C 700 fan runs non stop
Make sure the air vents are clear when it is operating, also use a can of compressed air to blow out the dust from the vents and fan. This should make it cool more efficiently and the fan shouldnt run as much afterward.
Compaq presario sr2011wm desktop push power on button and the computer won't come on. tried unplugin powercord and waiting for ten seconds and still didn't come on and I've tried removin and restalling...
the psu is bad.
the test is easy , one jumper wire prove PSU bad.
if its fan is dead, (and all fans )
jump pins 16 to 17 (power on pin jumped to ground 17)
connector pulled, turns it on.
see here. and why
http://www.pcdied.com/power.html#Jumper
Changed the CPU fan and now the monitor won't turn on. Power light stays green, and harddrive light stays yellow. Fan is running.
its not problem of fan. re-insert your ram. even if doesnt come then problem with ur motherboard chipset. if in blore call 9972888885
Same problem for me.CD-Rom doesn't work either
There could be a number of problems such as:
Your PSU is toasted. (Power supply unit)
Your Motherboard is fried.
Your Ram is fried.
Your power button is loose from the contacts (or the wire is loose).
Your Motherboard, Your Drives, and/or Devices are unplugged in one way or another.
And/or more
Fan runs but no boot
your motherboard is the problem. you should get it checked out at a local computer store.
2answers
Preasrio CPU fan is noisy and goes on A LOT
It's not your ram. What it means is that the system probably has inhaled too much household dust and is having trouble breathing. That is not a joke. The system has fans, and the fans are responsible for moving fresh air and unfortunately dust into the enclosure, and exhausting the heat. If the air is choked off, the heat builds up. If it gets to the point that the fan runs constant, the processor will slow down to compensate and avoid further overheating. That will make the computer slow. If you feel handy, you might get yourself one of those cans of compressed inert gas they sell at the major chains, unplug the computer and take it outdoors, remove the cover, and commence to cloudmaking. If you don't feel like that is for you, you can take it to a servicer, but it's gonna cost you a little more.
Pc fan runs too much
Normal fans should always run this keeps the cpu cool!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Will not come on
Does it run through the memory test, or begin to post?
Try pressing F8 repeatedly at startup to enter the OS options page and if you boot that far, choose last known good configuration. Otherwise, you may have some kind of hardware or driver conflict, a failing hard drive or even a failing power supply, despite the lights and fans. Finally it could be the result of malware installed on the system.
Here's a great article for general startup troubleshooting.
Here's a link to your system's support page and Here's HP's version for xp.
Here's a MS startup troubleshooter for xp.
Here's a link to my recommended malware removal protocols if you get it booted and that seems like the direction to go.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
