Question about Vehicle Parts & Accessories
Where is a manual for Viper rpn 7153v car starter?
Recently purchases a standard car that has a viper car starter in it. I have no idea how to work this system and looking for any directions or help. Thanks
  • 50 Answers
SOURCE: Viper SST 7701. I replaced
Try to relearn the tach by cranking the car and holding the valet switch(small black push button) until the LED lights solid.The try it again
Posted on Aug 14, 2009
  • 12 Answers
SOURCE: No install instructions
email me at face2face11@bellsouth.net and i will give them to you. i 've been doing install professionally for 10 yrs and have access to directechs (DEI technician website)
Posted on Jan 22, 2009
  • 53 Answers
SOURCE: Viper 5701 remote programming
1st you need to enter the remote into progamming Hold the Function button until the remote gives a long beep and LED light comes on the remote a (it takes about 8 sec.) Then press and hold the remote start buttom until the remote beeps 3 times and LED lights up. Now your ready to program the remote
One of the door has to be open . Insert the key - turn the key to the On position then press the button on the antenna once and then press it again and hold it
You hear a chirp and then you press the lock button on the remote and then you hear a second chirp to recieve confirmation and then release the button and the turn off the key .
Remote should be program
Posted on Jul 12, 2009
SOURCE: Can you lock the viper 5301 keypad?
Yes.
Press and hold Function (f) for 12 seconds.
Press and hold Lock for 2 seconds
(The keypad will light up)
If the green light by the lock button shows keypad lock on/off (no light).
Press lock- green light comes on.
Press and hold f for 2 seconds
Command entered
Press and hold f or wait 30 seconds for it to time out and the amber light turn off.
Posted on Nov 18, 2009
SOURCE: Keyless Entry doesn't unlock my doors anymore
Did you get help? My problem is similar but not as bad. My viper550ESP no longer remotely unlocks the doors (well very, very occasionally it does). That is the only problem.
Posted on Nov 25, 2009
Camry 2002 Remote Starter Conflicts Car Starter
You need to call Viper and talk to their tech support. It sounds like the viper is actually disabling the starter. If you have all of your paperwork from the alarm system there should be a book that can help walk you through the reprogramming mode. Maybe your key fob is not synced to the alarm system. I have a clifford alarm which is still a viper. I have to press the star button 3 times in a row if I want my car to start remotely. hope this helps some.
Nov 09, 2013 | 2002 Toyota Camry
How do you unplug or remove viper remote system
You just need to remove the two connected to the starter wire (ignition switch), and connect the car side of the two together. Then the ignition switch will control the starter again, without interferance.
Mar 26, 2011 | Directed Electronics 479V Remote Gen 2...
How do i get the lock and unlock on the screen to work on a viper 479v remoet
The two-way remote responds when in range. Also, the system that it is programmed to must be a two-way unit. If this remote was purchased and programmed to an alarm/remote starter, the alarm/remote starter must be capable of two-way communication.
Jan 25, 2011 | Directed Electronics 479V Remote Gen 2...
Just bought a`used truck that came with a Viper RPN 479VPC remote. Is this just a car alarm or is this a remote start also? Any help? Little blue remote with car diagram on screen...has lock, unlock, aux,...
That remote can work with both a security system, and a combo unit security/starter.
Best bet is to take the vehicle and remote to your local Viper dealer and they can look the car over and tell you what was installed and help you learn how to use it.
Jan 16, 2011 | Directed Electronics 479V Remote Gen 2...
I need instructions on how to use my viper 5101 remorte starter
go to www.directed.com this is the manufacturer of the viper remote starters, there you should be able to download instructions.
Here is how you program the viper 5101 remote.
Programming the Viper Remote Starter 5101
Unlock the doors before starting
Push and hold f button for 8-10 seconds until amber light is on solid
Push Remote start button for about 4 seconds till amber light flashes 3 times
Put key in IGN to the on position but don
Dec 30, 2010 | 5101 LE 1 Way Car Remote Starter System
VIPER 160XVL remote start stopped working
sounds like the unit has lost power. i can't tell you where the relay is located for that device but it may have failed.
Oct 19, 2009 | Viper 160XVL Viper 160XVL Remote Start...
Viper Remote Start, Jeep Grande Cherokee, Going crazy!
no - unfortunately "any mechanic" does not have the training to troubleshoot an alarm system, and a dealership does not work on anything aftermarket.
Your best bet is to visit DEI (Directed Electronics Inc.) website and find an authorized dealer near you... most likely a car audio shop.
Best Buy usually hires newbies as installers and they dont have much experience... Look for an independant shop.
CLICK HERE to go to the Viper Site. (Find a Store is at the top of the page)
The brain module cannot be repaired - the ignition and starter relays are integrated on the controller board. Since it is 2 years old - there may not be a replacement part available.
Good Luck!!
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 06, 2009 | Viper Security and Remote Start System...
Car won't stay running after using Viper 150ESP car starter
you may have hurt the alternator when jumping check that
Apr 07, 2009 | Remote Start System
Vehicle Parts & Accessories Logo
2,690 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
