Question about Hotpoint HSWP1000M 3.5 Cu. Ft. Capacity Extraction Ribbed Basket White
Hotpoint hswp1000m washer cycle fills with water for large capacity but when it goes to rinse it won't fill anymore than low capacity of water?
What's causing the rinse cycle to not fill water beyond low when I've used the large capacity to wash?
  • Hotpoint Master
  • 17,130 Answers
It can be due to a faulty water level sensor which evidently is a pressure switch. If the diaphragm is damaged it will require a larger water level to achieve the said pressure to shut the inlet valve in all the cycles.
Posted on Jan 12, 2013
  • 619 Answers
SOURCE: Hotpoint Aquarius WD420 5+5Kg
The water level vacuum switch are not working , check hose might lose.
Posted on Jan 05, 2008
  • 10 Answers
SOURCE: wf340 hotpoint washer
it will be to do with the pressure switch it may be faulty, but more often than not there is a blockage in the pressure chamber which is located at the bottom of the outer drum, check the chamber and the tube that goes up to the pressure switch to see if they are blocked if they are clear of obstruction then test the pressure switch,to do this unclip the pressure switch from the side of the machine but dont take the wires off once off pull the tube off that goes down to the pressure chamber once off blow in to the nossle on the pressure switch, you should hear it click and then when you release it should click again, if it doet click twice then that is your problem, hope that helps.
Posted on Feb 22, 2008
sidthedog
  • 4 Answers
SOURCE: Hotpoint Aquarius wd440 washer/dryer wont pump out water HELP!
hold the start button for 5 seconds this should clear previous program. then select drain on your dial. press start as normal and machine will drain. if this does not work the only other remedy is with help, making sure the end of the drain hose is higher than drum at all times take machine outside, lean it back at 45 degrees agaist a wall with a towel or similar covering lid to stop scratching . working from underneath loosen the large jubillee clip that connects the drum to pump drain hose to the drum. As the drum is overfull there is no recepticle large enough to fit under so just let water just flow away. Dry every thing off. make sure you don't loose ping pong ball in filter and make sure filter is clear. refitting is reverse of removal
Posted on Apr 20, 2008
FitzOriginal
  • 842 Answers
SOURCE: hotpoint washing machine
I really need more information here, but hopefully the following covers manty of the possible scenarios.
Do you hear a motor spinning during the time the drum should be turning?
If you hear a motor spinning inside the machine then there is a good chance that the drive belt has simply come off. You may be able to just take the lid off michine (My article http://www.fixya.com/support/t1543617-door_seal covers how to do this), hook the belt over the small spindle on the motor and then put it on the big wheel on the back of the drum by placing it over one side of the wheel and spinning the drum to draw it around the rest of the wheel.
Now, if this is the case, you are going to have to ask yourself why it came off. Sometimes this will happen if you had a very heavy load in the machine and the spin cycle threw the machine all over the place, so what was the machine doing on the last occasion it DID work?. Sometimes, the belt comes off because the drum bearings are worn out and there is movement in the drum. To check for this, open the front door of the machine, put your fingers on the drum on the inside and try to lift the front of the drum upwards a little. Bear in mind that there is an outer drum, with the drum that spins inside it and what you are feeling for is the inner drum moving inside the outer one, this will be obvious and "Clonky" if it is worn out. You are not looking to see of the whole drum assembly rocks smoothly inside the chassis, It is supposed to do this. If your bearings are worn out and this has caused the belt to come off, it may well be accompanied by a small, but worsening leak from the back of the machine as the water slowly leaks more and more through the bearing. I'm aftaid that if this is the case, then, depending on the age of the machine it may be time to scrap it. Certainly a bearing replacement is possible as a DIY job, but it is a real pain and not for the faint hearted.
So then, on to the scenario where you CANNOT hear a motor running during the wash cycle when the drum should be turning. This is probably the motor faulting out. Once again, a few checks: does it NEVER run, or will it still spin the washing? Your motor will have up to 4 electrical windings inside it, One for the standard turning motion when there is water in the drum during a wash and up to 3 more that kick in at various stages of the spin as it gets faster and faster. If it still spins, but will not wash, then it is almost certainly a burned out winding in the motor and you have to replace the whole motor. This will cost you (as a rule of thumb) about 25-40% of the cost of the machine when you bought it.
If the belt is on but the motor does nothing at all on any cycle, there might be a loose connection on the back of the motor (A plastic connector block with around 6 wires clips into the back of the motor, check it is firmly in place). Or, the brushes in the motor may be worn out. You can get separate replaceable brushes for most motors. If you can replace an altenator on your car, you can replace a motor on your washing machine, the principle is exactly the same. If you get to the point of taking the motor out, give it a good physical inspection, looking for burn evidence on the wires of the winding, water drip damage AND have a good sniff at it. If you smell that horrible burned wire and plastic smell, you know that the motor is going in the bin.
Posted on Feb 15, 2009
MrJuanDerful
SOURCE: Agitator Not Working
My Hotpoint VBXR1090B top loading washing machine quit spinning during the rinse cycle and also quit agitating. The water filled up and drained just fine --no leaks.
Here's how I fixed it in 5-minutes.
Tools:
  1. Putty knife
  2. Nut driver - I used a multi-purpose screwdriver without any heads attached.
Procedure:
  1. Unplug washer from the electrical outlet for safety
  2. Release two spring clips holding the front panel on: Insert a putty knife 5" in from the side between the top and the front panel. Pull the front panel forwards.
  3. Unscrew 2 screws holding the top down.
  4. Lift top - it's somewhat hinged in the rear with three tabs inserted in control panel.
  5. The little red tab at the end of the lid switch should be between the lip of the opening and the top; not sitting on top of the lip as mine was.  It's thin enough steel to push it with your bare hands.
  6. Make sure when the lid closes it actually causes the switch to turn on. You should hear a click.
  7. Put everthing back together. Plug washer back in. Put your tools away.
  8. Voilà. Done. Easy.  Even a woman or a ****** could do it.
Posted on Apr 26, 2009
Washer fills with water during spin cycle
Go to repairclinic.com and have model number ready. They have videos how to check it
Mar 02, 2015 | Samsung WA422PRHDWR 4.2 cu. ft Large...
Ge wprb8050d
when it stops filling
you fill it with a jug of water to the right level
then see what happens
if it goes past rinse
have a look at the water valve it needs to be changed
Jan 21, 2014 | Washing Machines
Kenmore Model 21082000 won't fill during wash cycle
Try checking the lid switch. Sometimes the switch goes bad or the stem breakes and when the lid shuts it will not activate the switch. Usually located on the right side of the dryer. When the lid closes it will allow water to.fill. Washers are easy to fix and the part is cheap. Get it from amazon dont pay the crazy price your dealer wants. Trust me, i just fixed my mothers...
Feb 16, 2013 | Kenmore Calypso
Maytag_lse7804ace: washer won't fill with water. If I fill it by hand, the cycle works fine (until it gets to the rinse cycle, when it won't fill again).
Hello John,
The most probable reason the washer is not filling is because of a blown fuse that is part of the lid switch asm. By UNPLUGGING THE WASHER and removing the 2 INNER screws on the the control panel and the control panel can be rotated down to see the fuse in the lid switch asm. Here is where the fuse is on the switch asm. its circled in red 11_4_2011_1_39_54_am.jpg
Nov 03, 2011 | Washing Machines
My maytag mtw5600tq1 washer won't hold water. Its
Its sounds like you have a siphon going on, this happens when the drain hose it too low during fill and as the water enters the unit it exits through the drain hose. To stop this the drain hose needs to be higher than the tub itself, meaning: raise the drain hose behind the washer to about control panel area. This will or should stop the siphon effect and allow the water to remain in the tub. If the drain hose is low this siphon will start again.
I hope this helps
Aug 26, 2011 | Maytag Washing Machines
Hi...my washer goes through cycles and then stops at "light" . It won't go through rinse and spin. Help
Make sure your cold water tape is turned on and the screen in the water valve is not plugged up, it may be trying to fill with cold water and cant get any, try filling the washer with cold water on a "wash" cycle to confirm it it fills with "cold" then just the rince cycle ion the timer may be faulty and would need to be replaced
Aug 25, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
The level of water in the rinse cycle is extremely low to the point that the clothes are not rinsed. Why is there such a large differential between the level of water in the wash and rinse cycle? How can...
Low water pressure or bad inlet valve, or clogged screens in fill hoses, check flow with hoses disconected these will be the causes! check hot and cold fills than check warm, any differnt all setting work?
Aug 23, 2011 | Estate ETW4400VQ Top Load Washer
Hotpoint HSWP1000M 3.5 Cu. Ft. Capacity Extraction Ribbed Basket White Logo
176 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
