Micronalarm beeping mains power connection failure
  • 7,627 Answers
In what? A bit vague? Can you be more specific?
Posted on Jan 12, 2013
Mfc 7360 unable to print 7a
Error code 7A
A synchronized signal of the main motor cannot be detected.
Turn the power off and then back on again.
1 Flat cable connection failure of main motor
Check the flat cable connection of the main
motor and reconnect them.
2 Main motor failure Replace the main motor.
3 Low voltage power supply PCB failure
Replace the low voltage power supply PCB ASSY.
4 Main PCB failure Replace the main PCB ASSY.
Jan 14, 2015 | Brother MFC 7360N - Multifunction fax /...
What are the dell beep codes for dell inspiron m5010
Table 3-1. POST Beep Codes
Beep CodesErrorProbable Causes
1Memory refresh failure.Defective system board.
2Error occurred in first 64 KB of main memory.Faulty DIMM or defective system board.
3Read or write error occurred in first 64 KB of main memory.Faulty DIMM.
4Timer on system board malfunctioned.Defective system board.
5Microprocessor error.Defective microprocesor.
6Gate A20 failure.Defective system board.
7Microprocessor-execption interrupt error.Defective microprocessor.
8Video memory read/write error.Missing or faulty video adapter.
9ROM checksum value does not match value encoded in system BIOS.Corrupted system BIOS program or defective system BIOS chip.
10NVRAM shutdown register read/write error.Defective system board.
11Cache memory error.Defective microprocessor or cache card.
1-2Video adapter failure.Faulty video adapter.
1-3No monitor connected.Loose video cable connection or defective video cable.
Jun 17, 2014 | Dell Inspiron 15 Laptop Computer- Intel...
Startup 6 beeps
Probable Causes
Error
Beep Codes
Faulty DIMM.
5
Gate A20 failure.
6
7
8
9
10
Cache memory error.
11
12
Loose video cable connection or defective video cable.Faulty video adapter.
13
May 15, 2013 | Samsung NP-148 NP-150 N148 N150 N128 N145...
Long beep at startup
Probable Causes
Error
Beep Codes
Faulty DIMM.
5
Gate A20 failure.
6
7
8
9
10
Cache memory error.
11
12
13
14
May 09, 2013 | Lenovo 3000 N100 CoreDT2080 VB PC Notebook
Dell 4 beeps
POST Beep Codes
How to fix Dell BIOS 8 beep error.
Probable Causes
Error
Beep Codes
Faulty DIMM.
5
Gate A20 failure.
6
7
8
9
10
Cache memory error.
11
12
13
14
May 09, 2013 | Dell Inspiron 1018 Notebook
I get a blank screen and 4 beeps what's the problem?
This could happen when the RAM contact is not proper, may be due to dust. Remove the memory modules from DIMM slot, clean it (no moisture please) and reinsert it. This could mostly solve your issue.
Please come back and rate my solution if it turns helpful for you or also if you need more clarifications. Thnx
Apr 01, 2010 | Fujitsu LifeBook A6110 PC Notebook
Dell Optiplex 725 Beeps at me at me at start up w/o complete start up. Screen Black. As if something is loose? Battery in Motherboard? Did something short out?
POST Beep Codes: OptiPlex GXi If the monitor cannot display error messages during the POST, the system may emit a series of beeps that identifies the problem or that can help you identify a faulty component or assembly. The following table lists the beep codes that may be generated during the POST. Most beep codes indicate a fatal error that prevents the system from completing the boot routine until the indicated condition is corrected.
Beep Code Error Probable Causes 1-3 Monitor not detected Disconnected or faulty monitor 1-1-3 NVRAM write/read failure Defective system board 1-1-4 BIOS checksum failure Faulty BIOS or defective system board 1-2-1 Programmable interval-timer failure Defective system board 1-2-2 DMA initialization failure Defective system board 1-2-3 DMA page register write/read failure Defective system board 1-3-1 Main-memory refresh verification failure Faulty or improperly seated DIMM or defective system board 1-3-2 No memory installed No memory installed or faulty or improperly seated DIMM 1-3-3 Chip or data line failure in the first 64 KB of main memory Faulty or improperly seated DIMM 1-3-4 Odd/even logic failure in the first 64 KB of main memory Faulty or improperly seated DIMM 1-4-1 Address line failure in the first 64 KB of main memory Faulty or improperly seated DIMM 1-4-2 Parity failure in the first 64 KB of main memory Faulty or improperly seated DIMM 2-1-1 through 2-4-4 Bit failure in the first 64 KB of main memory Faulty or improperly seated DIMM 3-1-1 Slave DMA-register failure Defective system board 3-1-2 Master DMA-register failure Defective system board 3-1-3 Master interrupt-mask register failure Defective system board 3-1-4 Slave interrupt-mask register failure Defective system board 3-2-4 Keyboard-controller test failure Faulty keyboard controller (defective system board) 3-3-4 Screen initialization failure Faulty video subsystem (defective system board) 3-4-1 Screen-retrace test failure Faulty video subsystem (defective system board) 3-4-2 Search for video ROM failed Faulty video subsystem (defective system board) 4-2-1 No timer tick Defective system board 4-2-2 Shutdown failure Defective system board 4-2-3 Gate A20 failure Defective system board 4-2-4 Unexpected interrupt in protected mode Defective system board 4-3-1 Memory failure above address 0FFFFh Faulty or improperly seated DIMM 4-3-3 Timer-chip counter 2 failure Defective system board 4-3-4 Time-of-day clock stopped Bad battery or defective system board 4-4-1 Serial-port test failure Faulty I/O chip (defective system board) 4-4-2 Parallel-port test failure Faulty I/O chip (defective system board) 4-4-3 Math coprocessor failure Faulty microprocessor chip or system board 4-4-4 Cache test failure Defective microprocessor or system board
Mar 30, 2010 | Dell OptiPlex 330 Desktop Desktop Computer...
Powers on but no activity from hardware, and no warning beeps
yes it can be a power supply prbl change the pwr sply and if it steel dosent start take out the ram-s see if it beeps if not put back the ram-s and leave it powered up for 5-10 mins and touch the chipset if its burning hot its only the main bord , if its not hot and its AMD its the main b. or the processor or both it its intel its the main bord.
Jan 04, 2010 | HP Pavilion a1140n (PX774AA) PC Desktop
Mohterboard beeps 1 time every couple of seconds. Won't boot.
this problem is useually the result of a hard part failure like the memory cards
Sep 17, 2009 | Computers & Internet
4 seconds long beep
I think that either you have a bad power supply or it is not connected properly. I suppose it could also not be supplying enough power.
Try disconnecting all of the connections to the Motherboard and reconnecting them. Make sure they seat properly. Try a new power supply. You can get a good one from Newegg.com
Jan 26, 2008 | ASUS Intel 850 Chipset P4T-E (P4T-E/WOA)...
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
