Question about ASUS BLACK 15INCH WSXGA+ CORE2 DUO PROCESSORS T7700 2.4 GHZ,800 FSB,4MB L2 ... PC Notebook
Opening memory cover VX2s
How do you open the cover to access the memory modules on a VX2s laptop. There is a scre but even with this undone the cover does not move.
  • 144 Answers
Have you tried unscrewing the screw then getting a flat headed screwdriver and using it to lever up the cover?
Posted on Jan 22, 2009
Asus vx2s cmos battery location?
This may help, just mute the volume and watch, it a general idea: http://www.youtube.com/watch?v=U0gpFMF5R0c
Dec 23, 2012 | ASUS (VX2S-A1B) PC Notebook
I need Help Installing additional ram on my compaq presario cq56. I have an addition 2g of ram i would like to install on my laptop and i dont know where to begin please help???
Power down your laptop and remove A/C adapter and battery. Be sure to ground yourself to prevent static electricity transfer. Small panel in the middle of bottom of laptop. Remove screws and laptop RAM is right there. Be sure your RAM matches as far values and doesn't exceed maximum size supported. There should tabs that hold the RAM in. Replace pieces of RAM. Computer should recognize the new hardware and acknowledge it when you power it up. Hope that helps..
Jul 15, 2011 | Compaq Presario CQ56-115DX Laptop
Asus lamborghini vx2s AMT problem, ME Error shows in red on the boot beginning. How can I fix that matter?
ME Error primary cause on otherwise fully worked system caused by unpopulated RAM slot 0. Systems with Intel AMT must have slot0 populated, because ME Engine use small part of it for running itself. Just rearrange your memory modules to fix this problem.
Feb 20, 2011 | ASUS Lamborghini VX2S-B1B Notebook
I have a sony vaio once I turn the computer on the start up window wont come out... It's just a blank screen what should I do...?
Hello Sir, Hi, common problems associated with blank screen are as follows, I need you to check this out. 1. poor contact connection on the memory. under you laptop, you will find the access panel to the memory module, usually with screw, remove the panel cover, and remove the memory module, clean the terminals using any dry clean cloth/rug, or an eraser. 2. bad battery means no power, charge your laptop and after 10 minute. turn on. 3. still no success, remove the hard drive by opening access panel to hard drive. power on. 4. if you reach this part, problem now is on the system board. find a reputable repair center for Sony.
Nov 06, 2010 | Computers & Internet
Have an acer 5315 model icl50 and want to add 1 gb memory, is there a way to know the exact match for memory module without opening back cover
Hello there!
You would most likely look for a DDR2 667MHz PC2-5300 RAM Memory Module.BTW, it should be a 200-pin Non-parity un-buffered & precisely 1.8volts.
Hope this helps.
Mar 06, 2010 | Acer Aspire 5315 Notebook
Where is ram memory ?
Ram memory is on the underside behide a small opening requiring you to remove 2 screws. You remove the door and they are laying under that.
Aug 08, 2009 | Toshiba Satellite 1005-S157 Notebook
Can't Find 2nd ram to upgrade memory
Sometimes Laptops will have 1 slot internal and 1 slot on the bottom side thats readily accessible via a removable plate.
You'll be perfectly find with the 1GB internal and adding the 2GB to replace the 1GB stick on the bottom side.
Also Windows XP and VISTA 32bit can only address and use about 3.25GB of ram anyway.
Recently Microsoft released a patch that's kind of tricking consumers, People calling and complaining so much to MS and PC manufacturers about not seeing all their ram when they installed 4GB so they Released a fix that shows it as 4GB but still the 32bit OS cant use the extra over 3GB
Apr 22, 2009 | Computers & Internet
How to get into ram slot?
That should be covered in your laptop manual. If you don't have manaul go to this link. from here you need to know your OS
should take you to manuals.
http://support.asus.com/download/download.aspx?SLanguage=en-us I found this Version E4452
good luck. PS most extra ram is on the bottom of your laptop you have to remove a screw and cover then install the ram. check the manual first....
Mar 15, 2009 | ASUS Lamborghini VX2S-B1Y Notebook
VGN-SZ330P laptop stays on opening VAIO screen after two beeps
Just hold down the F1 key after the two beeps and the computer should continue to boot up as normal
Dec 19, 2008 | Sony VAIO VGN-SZ330P/B Notebook
Help please!
Power unit off. Disconnect AC power. Remove battery. Remove the memory cover screw, memory cover and the memory modules. Peel back mylar from JOPEN1 solder pad. Short JOPEN1 solder pads for 30 seconds. Replace mylar. Replace memory modules. Replace battery. Power up unit. If all is well, replace memory cover and screw.
Feb 22, 2008 | Toshiba Satellite A135-S2276 Notebook
ASUS BLACK 15INCH WSXGA+ CORE2 DUO PROCESSORS T7700 2.4 GHZ,800 FSB,4MB L2 ... PC Notebook Logo
70 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
