Question about Magic Chef 9815 Electric Single Oven
I'm getting a random beeping and F1 error.
Another individual had the same issue and the solution was that a control board was required. What is a control board?
  • Anonymous Jun 17, 2008
    I'm getting a random beeping and F7 error.
  • 76 Answers
F1 code is a error message between the keypad/user interface and the control board located just behind the keypad. Replacing the keypad will usually fix this problem.
Posted on Jul 06, 2007
SOURCE:
F1 code GE profile convection self clean wall oven (95?) oven beeps F1 code oven works when it is on bake etc. when touch key are pressed it goes off but starts to beep again
Hi
F1 Error indicates a bad control board and the control board (electronic control) should be replaced to solve this issue. Hope this helps...please post back for further assistance.
Daniel
Sep 19, 2011 | Ovens
Oven will be off f1 comes up and beeping have to turn it off at breaker to use turn breaker on and have to turn oven on low setting to use range if oven is not on then f1 and beeping oven does not get as...
Hi
Thanks for using FixYa. F1 error indicates that the control board (ERC) has gone bad and the electronic range control (ERC) should be replaced to resolve the issue. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 25, 2010 | Ovens
F1 error . we turned off breaker. left it off. turned back on and beeping starts again. we have turned off the breaker
Hi
Thanks
Rylee
Aug 22, 2010 | GE Profile JT955 Electric Double Oven
Our JennAir W131W oven starts beeping and shows F1 on the temp window.
Hi
Thanks
Rylee
Aug 22, 2010 | Jenn-Air Ovens
Error code F1 flashes and beeps on control panel
Hi
Error code F1 means a faulty keypad or connection problem with the keypad. You will need to check the connections of the keypad with the main board. Pressing Start/Cancel key may temporariliy resolve the issue, however, to resolve the issue you might need to change the keypad if the wiring to the keypad seems ok.
1. Disconnect power to oven.
2. Gain access to the back of the clock (electronic range control or ERC).
3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
4. Make sure everything is clear and will not short out when power is turned back on.
5. Turn power back on to stove.
6. Watch for the F1 and listen for the beep.
If it still shows as F1 then you'll need to replace the keypad.
Hope it helps...
Daniel
Aug 13, 2010 | Magic Chef Ovens
I have a Dacor ECS130 and when we turn it off the F1 code comes up and it beeps forever. i tried uplugging the membrane switch from the control/clock module (with the power off) and there is no F1...
Hi
Thanks for using FixYa. Error F1 in your Dacor Oven indicates element relay circuit failure. To resolve this issue the control board should be replaced as it has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 26, 2010 | Ovens
Power to the control panel appears to be lost at random times. Then sooner or later it beeps and can be reset. All will be well -- until the next time when the same thing happens.
HI. The beeping is an indication of a major control issue. This issue involves the internal control board. The logic chips are failing at this time. Due to the fact that the error continues to be an issue, even after the reset is initiated, This will require the replacement of the electronic control board. Once replaced, the issue will be solved.
Replace the ERC or Clock
Oct 20, 2009 | Ovens
Error on display F1 & E1 Stove will not start
HI. This is a safety flip flop error code, caused by damaged circuitry within the electronic control board. This will require you to have the control replaced asap. This will correct the issue.
Part number (for white control) #3196971
Part Number (for black control) #3196970
Oct 19, 2009 | Ovens
Help our frigidare double oven is locked and we cannot get the chicken out....it keeps beeping and showing an f1 symbol
Press Clear/Off to stop the beeping... then press clear/off again. If it doesn't unlock - wait about 15 minutes for it to cool down.
The F1 error means the EOC (Electronic Oven Control) board has a failure - and thought there was a run-away temperature condition.
It should allow itself to unlock after a few minutes of cool-down.
For additional help in finding a replacement part - a Model # will be required.
Thanks for using FixYa!!
Jun 26, 2009 | Frigidaire Ovens
F1 error will not reset. unpluged for hours and still f1 and beep
HI. this is an unfortunate Electronic oven control failure. This will require you to replace the entire control Board in this unit. it has failed.
F-1---{Electronic oven control failure}--{replace EOC/CLOCK}
Jun 12, 2009 | Frigidaire Ovens
Magic Chef 9815 Electric Single Oven Logo
168 people viewed this question
Top Magic Chef Ovens Experts
Thomas F. Schneider
Steve Allison
Steve Allison
Are you a Magic Chef Oven Expert? Answer questions, earn points and help others
