I have a 2001 color rear video projector model no kp-43t75 every time I turn it on it blinks 4time and shuts off no sound no picture can u help me
  • Bryair McCann Jan 12, 2013
    well still working on my tv not sure i checked for bolges and there is none and the fuses and there good HEY SONNY BERRY CAN U EMAIL ME THANKS
  • 8,617 Answers
When the 4 blinks happens its indicating the Vertical deflection has stopped thats. usually caused by the Vertical out IC1509 (LA78045) and Verticak Buffer Q5A51 (2SC3311A) If you need further assistance let me know.
Posted on Jan 12, 2013
    hey is bryair again is there any way you can email me or find me on fb
taran_2005
  • 10515 Answers
SOURCE: I have a Sony KP-43T75
HI,
A 4 flash shutdown is a vertical stop condition, meaning that the vertical deflection circuit is shutting down.You need to purchase the service manual from :-
http://www.tradebit.com/filedetail.php/5018366-sony-kp-43t75-kp-48s75-color
Once you have the manual, check the plus and minus 15 volt supplies on the G board. They are fused and the fuses are the easiest place to check them. If the fuses are blown, I would be thinking a bad convergence IC, as that is a common failure on these sets.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 12, 2010
Orbixx
  • 133 Answers
SOURCE: No power
It sounds like the backlight or an inverter board on the television may have failed. Check your warranty status on the television to see if you can get it repaired by the manufacturer for free.
Posted on Sep 06, 2007
welcomejee
  • 10594 Answers
SOURCE: SONY-LED BLINKS 10 TIMES
OK, 10 times is HV protection (High Voltage) and problem can be in D board and Q8013, Q8014 can be shorted along with R8051 open.
also IC8005 can be damaged.
All above parts on D board.
I would recommend to get related service manual for proper diagnose of problem in TV.
Good luck.
Posted on Dec 17, 2008
toddthetvmd
  • 101 Answers
SOURCE: good morning, i have a 50
You might have a bad lamp. RCA DLP projection That is the most comon problem with them. CRT rear projection, Red,Green,and Blue tubes.If it is the silver one w/the black speaker grill. Chass # _ _ _222 ?
Has 222 in the number.Can be several problems. Many things go wrong in those. Horz. Output,Flyback,And bad soldering are the most common problems w/those. Recomend staying away from RCA. Not the same company they once were.
Posted on Jan 01, 2010
ladywinn
  • 5138 Answers
SOURCE: i have a rear projection
From what you have said , Replace both of your STK ICs they are big black ICs will have part number on them example STK392-110
Go by the number printed on them if they are 110s use the 180s they are better ICs Mats has them for $10.95 each 1-800-628-1118
Also go to this website/use Google Encompass Parts Distrubtion
1-800-638-3328 sometimes they will have free service manuals you can print out.
Another thing you need to CK pico fuses they will look like resistors only they are green or yellow 5amp/ 6amp fuses Look in front of ICs and some are located behind ICs.
Posted on Mar 17, 2010
I have a Sony color rear video projector model number KP-43T75 and can find the bad spots in mother board
Unless you have alot of test equipment and alot of patience, it might just pay to put in a new one seeing you have it out already.
Jan 12, 2013 | Televison & Video
I have a Sony color rear video projector model# KP-43T75 it's blinking for time won't stop I checked for the Bolges on the black piece there is none and it turns on no sound or picture and shuts it se
First let me say that you did good checking for bad capacitors that might have bulges. They can fail with no outward signs though. You have to use a special meter to check them. Second that light means:
Vertical deflection stopped. Possible causes: +- 15V is not supplied. (D board), IC8003 is faulty. (A board) Symptoms of the problem: TV has entered standby state after horizontal raster, Vertical deflection pulse is stopped, Power line is shorted or power supply is stopped.
Your best course of action would be a new power supply board.
My sony kp-51ws510 color rear video projector tv when i turn it on it stays on for abt five seconds and then turns off and also the timer and standby light is flashing red
this model did have problems with bad picture tubes---screen goes bright red,green,blue and set shuts down.
set also does this to protect itself---when fails look to see if specific sequence of blinks
Apr 17, 2012 | Televison & Video
KP-57WS520 Sony Projector - No picture
5 times blinks shows incorrect white balance (AKB) error. TV needs Screen Volts (G2) adjustment.
Take off lower front panel, find Focus Block that has 6 control knobs, adjust Screen volts of each CRT (red-green-blue) and problem will be solved.
Be Careful while working in TV.
Let me know if you have further question.
Thanks.
Dec 09, 2009 | Sony KP-57WS520 57" Rear Projection...
Sony KP-43T75 color repair
This link has the instructions on how to fix this problem and other similar problems. You have nothing to lose, so I recommend that you try it.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
This works with the two other colors, blue and green also. Not all models of Sony Projection TVs have the red, green, and blue pots in the same order as the picture that is listed on this link, so you may want to google search for your model's service manual. The service manual can also help you be able to remove the cover for your particular model of TV. I was able to find the service manual for my model, and sure enough, the order of the pots are reversed on mine, so I would have been adjusting the wrong color. Read all of the comments on this link too, because you can find other helpful tips and may even find someone with the same model of TV as you that gives more specific instructions for your model.
You may also find your model's service manual here:
http://esupport.sony.com/US/perl/index.pl
I hope this helps you!
Fare well. :)
Iconoclast
Jun 27, 2009 | Sony KP-51HW40 51" Rear Projection...
My Sony Color Rear Video Projector Model # KP-51WS500
Go to this Blog. It "should " solve the problem.
Really, Really simple, do it your self solution !!
Instructions and pictures included :D
This blog covers many makes and models with many issues solved, just with that one solution
Give it a try, it's free and simple :D
Hope the blog helps you.
Jean
Feb 25, 2009 | Sony KP-51WS500 51" Rear Projection...
Sony Color Rear Video Projector - KP 57hw40 / Mfg. February 2002
i have the same problem picture is blue/green with blue and green arched horizontal lines
no picture at all only sound then tv shuts off after 5-10 seconds and then a bright blue flash in the center of the screen
have tried adjusting the voltage screws didnt do anything
Jul 13, 2008 | Sony KP-57HW40 57" Rear Projection...
Sony tv blinks 30+ times or once, no picture/no sound, then shuts off
sounds like a problem in the stand by power supply as the Set is not blinking any code indicating its in protective shut down. I would assume its one of the low voltage regulators that has shorted. You would need a service manual to actually troubleshoot the start up and stanby voltages. Let me know if you would like a link where to purchase the manual. I will post a link that provide free tech assistance to help diagnose and repair your set when you get a manual.
Mar 27, 2008 | Televison & Video
Tv went blank
Does the timer/stand-by light blink at all? If so, count how many times it does. It will usually be in intervals. If it isn't blinking, and you have nothing on the screen, you might have a problem with the "G" Board, part # A1316499A.
C-Dog
Dec 16, 2007 | Sony KP-61V90 61" Rear Projection...
Televison & Video Logo
102 people viewed this question
Top Televison & Video Experts
Electro Med Services...
