Question about Kroy K 4350 Printer
K4350 300dpi, Windows 7, Bartender 8.01 build 2160, USB to Serial Converter, COM3 9600,8,n,1, Flow Control - any setting. 7/16" flat (1/4"dia.) Heat Shrink. After I print a label, the printer beeps an
I have to toggle power to print another... I've played with serial port settings and nothing seems to help. Not sure which brand the USB to RS-232 converter is. It's a semi-opaque bluish green molded plastic with white semi-opaque plastic thumb screws, if that helps. The printer prints labels on Heat Shrink fine, just one at a time due to the errors. Major hassle and not conducive to light duty production line I'm trying to set this up for. Any suggestions? Any help would be greatly appreciated. Thanks
  • Doug Stensrud Feb 05, 2013
    Thank you for the replies. Setting the document properties button to "Continuous" solved the problem.
    Problem Solver:
  • 15 Answers
Your Bartender software is probably set to print individual labels with a gap between them. Reset the software (document properties button) to Continuous label supply, and it should work. Still having problems? We're Hanover Technical Sales, a Kroy Support Site and Distributor. Give us a call at 757-357-2677 and we'll help you get to the bottom of it.
Posted on Feb 05, 2013
4 Suggested Answers
SOURCE: Need help with Kroy K4350 Printer.
It's definitely a fried pixel on the print head. There are several causes.
1) Running the print head too hot (i.e. at max heat).
2) re-using the ribbon can place dirt and/or static at the printhead.
3) Using un-flattened heat shrink will also cause premature failure of the printhead.
We have been selling the K4350 for a few years and always tell customers to use tubing that's as flat as possible. We specialize in printing on heat shrink, so feel free to call us. We'll even buy back your Kroy printer if you want to upgrade to a higher output printer
http://www.buyheatshrink.com
Posted on Jan 15, 2009
Donz Responz
  • 15 Answers
SOURCE: Kroy K4350 Gap Sensor Problems
Your problem is too complex to solve in one pass on this or any other forum. Give me a call at 800-304-9043 and I'll walk you thru it. I'm Don from Hanover Technical Sales. www.EmpowerCompany.com hanover@visi.net
Posted on Apr 24, 2009
  • 144 Answers
SOURCE: the label design software does
perhaps you should get the full version as trial versions are usually useless when comes to proper applications
Posted on Nov 23, 2010
Have a solar 2160 wire feed welder but do not seem to have any heat control.can't weld sheet metal,just way to hot.
The capacitor(s) may be open. or resistor has failed. It is also possible heat selector is fused to the one setting.
Nov 20, 2012 | Welding Tools
My computer that has PSW2.0 crashed. It had Windows XP. I have a new HP computer with Windows 7. What do I have to do to make it work on my new computer?
From Singerco.com FAQs: Q. My computer only has USB ports. Can you recommend a Serial (nine pin) to USB converter cable that will work with the Professional Sew Ware™ 2.00a? A. We have found that the PSW works best on newer computers when the USB serial adapter cable has not only compatible drivers for the Windows operating system but also a FTDI chip. We have found this FTDI chip in the cable which is listed below:
CUSB-232A available from Computerplug.com and Cablesalesusa.com.
Any USB to serial adapter with an FTDI chip will work. These cables will work for Windows XP, VISTA, and 7.
Sep 23, 2010 | Singer Professional Sew Ware Options 2.0...
I am trying to install the Singer professional Sew-Ware software on my new computer that us running Windows 7, I had to purchase a Serial to USB cord which I attached and installed the cord. When running...
Singer.com's FAQs provide the following:
Sep 22, 2010 | Singer Professional Sew Ware Options 2.0...
Can't hear playback. Windows Vista - Playback device says usb Audio Codec
here is what ION is telling people (short version) this is for vista or win7
1. Visit www.ionaudio.com/ezvc to download the latest EZ Converter software.
2. install new software if needed,
3. connect ION Audio USB. make sure its ON (if it has a switch)
Setup Procedure
1. Start then Control Panel.
2. double-click Hardware and Sound.
3. double-click Sound.
4. At top select Playback tab. choose the audio output device.
Don’t chose “speakers-usb audio codec” (that’s your ION) don’t chose modem
5. click Set Default.
6. select Recording tab at top of Sound Control Panel. choose "Microphone – USB Audio Codec" as the default device. (that’s the ION)
7. Click Set Default.
8. click Properties. select Advanced tab
9. set the Default Format setting to 2-channel, 16 bit 44100 Hz (CD Quality).
10. Un-check the two boxes under Exclusive Mode. Click Apply
11. select Levels tab from the top of the Sound Control Panel.
12. Set the level slider to 4. Click Apply, click OK to close the window.
Have everything set up and running, if you have to call this number for help.
401-658-3743 ext. 1405
Jun 25, 2010 | ION Audio iTTUSB Turntable
Installed usb to db26F converter to use printer
Ok reinstall as Administrator, use "Compatibility mode" for install and the run .exe, also run software as Administrator. too. Often these devices, USB - Serial Ports are NO GOOD for a printer. Either install a real Serial Port. or get a new printer. Windows 7 will NOT help either, it doesn't like older equipment.
Mar 24, 2010 | HP LaserJet 1100 Printer
Oh and what do i
TORQUE VALUE CHART
7/16" dia. 50 to 60 lb-ft
12mm dia. 70 to 80 lb-ft
1/2" dia. 80 to 90 lb-ft
5/8" dia. 110 to 125 lb-ft
*Use this chart to get correct torque values for each size wheel stud. I hope this helps and don't forget to rate my answer.
Feb 01, 2009 | 2002 Chevrolet Malibu
SiPix Pocket A6 Printer Windows Vista Driver.
SiPix never had a Vista driver. Most new computers, like mine, do not have serial ports. Here is how I got my A6 working with Vista --
1. Purchase a serial to USB converter cable. (I got mine on Ebay for about $4.00.) Plug one end into the serial cable that came with the A6 and the other end into a USB port on the computer. Vista automatically picked up and installed the converter cable. In Device Manager, it shows up under Ports and gives it a com port number. Right click on the device and click on Properties. Click on the Port Settings tab and change Bits Per Second to 115200, Data Bits to 8, Parity to None, Stop Bits to 2, and Flow Control to Hardware per your A6 Owner's Manual. Click OK.
2. Now go to Printers in the Control Panel. Click to add a printer. Follow on screen prompts. Whe asked what port the printer is on, highlight whatever port the USB converter cable was assigned to. (In my case, Com 4.) When asked for the driver, direct it to the CD Drive where you have the A6 driver disk. Direct it to the Windows 2000 driver. If you try to use the XP driver, it will tell you it is the wrong OS. The 2000 driver will install. Your A6 should now be installed and show up in your list of printers.
My A6 now prints from any program or the internet using Windows Vista.
Aug 17, 2008 | SiPix Pocket Printer Thermal
Reqd Software for BF-810
Go to
this page at Softpedia.com
and follow the link to download a free copy of the driver for the BafoTech BF-810.
Mar 17, 2008 | BafoTech BAFO BF-810 Serial Adapter
293 people viewed this question
Top Kroy Office Equipment & Supplies Experts
Donz Responz
Donz Responz
Level 1 Expert
Norman  J Weimar Jr
Norman J Weimar Jr
Tom Chichester
Are you a Kroy Office Equipment and Supply Expert? Answer questions, earn points and help others
