Question about General SG24GHP Surface Grinder Honda GX390 Series 13 HP gasoline engine
Timing marks for the balancing shaft for gx390 Honda engine
How to set timing
have to pull the cover and flywheel..
May 06, 2015 | 13 HP Engine GX390 OHV Horizontal Shaft
I just bought my first car 1998 honda accord did a complete tune up but it vibrates when idle but run smooth.
some hondas have a counter balance shaft on lower part of the engine (marks should be lined up when replacing timing belt ) someone may have replaced timing belt and missed aligned them
Feb 28, 2015 | 1998 Honda Accord
My balance shaft belt broke while I was driving. It stripped some of the teeth off the timing belt and Im pretty sure it jumped time. I need a diagram to show the timing marks and how to get it back in...
see diagrams from autozone.com. Cam sprocket has an "UP" label, but also 2 scribes on the sides to align to upper head surface. The critical part of the job is keeping tension on the side of the belt that is opposite from the tensioner as the tensioner is released onto the belt. The timing marks must be aligned when the job is done.
4256a1c.gif To install:
  1. Install the camshaft timing sprocket so that the UP mark is up and the TDC marks are parallel to the cylinder head gasket surface. Install the key and tighten the bolt to 27 ft. lbs. (37 Nm).
  2. Install the crankshaft sprocket so that the TDC mark aligns with the pointer on the oil pump. Install the spacers with their concave surfaces facing in. Install the key. If equipped, install the TDC sensor assembly back into position before installing the timing belt.
  3. Install and tension the timing belt. Use a 6 x 1.0 mm x 25 mm bolt threaded through the cam belt tensioner plate to temporarily hold the tensioner.
  4. Temporarily install the crankshaft pulley and rotate the crankshaft counterclockwise 5-6 turns to be sure the belt is properly seated.
  5. Set the No. 1 piston at TDC for its compression stroke.
WARNING If any binding is felt when adjusting the timing belt tension by turning the crankshaft, STOP turning the engine, because the pistons may be hitting the valves.
  1. Rotate the crankshaft counterclockwise so that the camshaft pulley moves only 3 teeth beyond its TDC mark.
  2. Loosen, then retighten the temporary cam belt tensioner bolt.
  3. If the rear balance shaft sprocket/gear case assembly was removed, perform the following:
    1. If the rear balance shaft was moved, rotate the balance shaft until the 6 x 1.0mm x 100 mm bolt can be installed into the maintenance hole to the scribed line.
    2. Align the notch of the balance shaft sprocket edge with the pointer on the gear case. Install the rear balance shaft sprocket/gear case assembly using a new O-ring coated with fresh engine oil. The balance shaft sprocket should be installed in the TDC position. The pointer on the gear should align with the pointer on the oil pump housing plate.
    3. Tighten the mounting bolts to 18 ft. lbs. (25 Nm).
  4. If the front balance shaft sprocket was removed, perform the following:
    1. Install a suitable and sturdy screw driver or drift through the maintenance hole in the shaft behind the sprocket to hold the front balance shaft.
    2. Install the front balance shaft sprocket and mounting nut. Torque the nut to 22 ft. lbs. (29 Nm).
  5. Make sure the balance shafts and crankshaft are in the TDC position.
  6. Remove the crankshaft pulley, and if removed, install the balance shaft belt drive sprocket.
  7. Install the balance shaft belt, making sure the balance shafts and sprockets are still in the TDC position.
  8. If removed, install the balance shaft belt tensioner and tension the balance shaft belt.
  9. Loosen, then retighten the tensioner adjusting nut to 33 ft. lbs. (45 Nm).
  10. Remove the 6 x 1.0mm x 100mm rear balance shaft holding bolt.
  11. Temporarily install the crankshaft pulley and rotate the crankshaft 2 revolutions counterclockwise, stopping at TDC.
WARNING If any resistance is felt, stop immediately and determine the cause.
  1. Recheck that all of the TDC marks align for both the camshaft and balance shafts.
  2. Loosen, then retighten the tensioner adjusting nut to 33 ft. lbs. (45 Nm).
  3. Remove the 6 x 1.0 mm x 25 mm bolt used to secure the camshaft timing belt tensioner.
  4. Remove the crankshaft pulley and install the lower cover.
  5. Install the crankshaft pulley, lubricate the bolt threads and both sides of the crankshaft pulley bolt with fresh engine oil and tighten the crankshaft pulley bolt to 181 ft. lbs. (245 Nm). Do Not use an impact wrench.
See Figures 19 and 20
              Fig. Fig. 19: Holding the rear timing balancer shaft-4-cylinder Odyssey
            Fig. Fig. 20: Aligning the front timing balancer shaft-4-cylinder Odyssey
            1. Install the upper timing cover and the valve cover. Be sure the seals are properly seated.
            2. Install the side engine mount. Tighten the through-bolt to 47 ft. lbs. (64 Nm). Tighten the mount nut and bolt to 40 ft. lbs. (55 Nm) each.
            3. Remove the floor jack.
            4. Install and tension the alternator belt.
            5. Install the power steering pump and tension its belt.
            6. Install the splash shields.
            7. Reconnect the positive and negative battery cables. Enter the radio security code.
            8. Check engine operation.
            Sep 20, 2010 | Honda Odyssey Cars & Trucks
            How do u change the timing belt on a 1990 4 cylinder honda accord?
            Disconnect the wire harness at the distributor.Remove the spark plug closest to the drivers side front tire. Place the palm of your hand over the valve covers empty spark plug hole and have a helper crank the motor over until air pressure pushes past your the palm of your hand. Next, look at the cam shaft wheel and note the direction that the arrow is pointing, the arrow should be pointing straight up IN RELATION TO THE ENGINE not the earth. If it is not, you will need to manually rotate the engine till the cam wheel is infact pointing straight up. Next, Jack up the front of the car and support it with jack stand and remove the front drivers side tire.Next, support the weight of the engine with a floor jack remove the motor mount closest to the drivers side tire To remove it you will need a deep 17mm socket on a heavy duty breaker bar. Next, loosen and remove the power steering belt and alternator belts. To loosen and remove the belts you will need a 10mm wrench and a 12mm wrench. And also a 14mm or 15mm wrench. Next, use a 19mm socket AND an air powered IMPACT wrench to remove the bolt holding on the crank shaft pulley. Next, remove the crankshaft pulley. Next, use a 10mm wrench and/or 10mm socket and remove the bolts holding the plastic engine side cover. Next, loosen the 14mm or 15mm bolt which secures the 2 belt tension wheels. Next, LOOSEN the 10mm bolt that is on the balance shaft tensioner. The balance shaft is the cogged wheel with a small timing mark dot on the side of the wheel. Next, loosen the 10mm bolt on the timing belt tensioner. It's obvious what wheel is the timing belt tensioner. Next, remove the 12mm bolt on the back side of the block (near the balance shaft) a little bit of oil will drip out, this 12mm bolt will allow a long bolt to be inserted into a recessed channel of the balance shaft. This recessed channel is needed to lock the balance shaft in place. A bolt from the air conditioner works great for locking the balance shaft in place. You're basically just pushing the bolt in a hole to keep the balance shaft from spinning.890a27a.jpg Next, remove both the balance shaft belt and timing belt. Then reverse the procedure to complete the new belt installation. EXTREMELY IMPORTANT!!!!!!!!! PLEASE NOTE, the oil pump wheel furthest to the left (closest to the radiator), has a timing mark on the flat face side of the wheel, that timing mark has to be pointing directly to the 9:o'clock position in relation to the engine. The cam wheel has an arrow on the side of one of the "spokes" ...make sure it is pointing straight up in relation to the engine...straight away from the crank shaft. Put the crank wheel on with the arrow pointing straight up to the center of the cam wheel.
            Jun 28, 2010 | 1990 Honda Accord
            Balance shaft alinement marks on honda 2.3 litre engine
            set it to top dead center. there's an access hole to put a 4" or 100mm pin to keep the balance shaft from moving when replacing a timing belt. The other marks are at the cam and crankshaft pulleys.
            Or remove #1 cylinder spark plug, put a wooden rod against the piston, when it is at the top of it's travel and goes neither up or down, it is at top dead center. The balance shaft locking pin can then be inserted.
            Jul 12, 2010 | 1998 Honda Accord
            Set harmonic balancer to top dead centre,set cams to timing marks,engine will not start but turns over. Hyundai Terracan 2002
            hi from uk assume you have renewed c/belt and balance shaft timing belt? if so? and sure your timing marks on cams and the c/shaftcog are correct ? the oil pump also correctly aligned with marks? and the balance shaft gear also has time marking ? want to run thro how and which marks you have aligned and at TDC No1 all belt/s have to be aligned ??
            Dec 27, 2009 | Hyundai Sonata Cars & Trucks
            I am trying to set the timing mark on a 1996 honda accord with a 2.2L 16 valve. The cam and crank mark are okay. The only one I am concerned with is for the oil pump and the balancer. I heard that to set...
            get a book i dont thing you have a clue whats going on here . you set the crank shaft and the came shaft marks on a 2.2 thats it . if you go to mitchell repair manuals you can buy a manual for $9.99 . may save you a big head ach
            Oct 28, 2009 | 1996 Honda Accord
            I need to replace my timing belt on my hyundia elantra 2003 with 1997 cc engine
            Dear Friend
            Removal: Support engine: remove -engine mounting, auxiliary drive belt, water pump pulley, crankshaft pully bots & crankshaft pully, timing belt covers....turn crankshaft to TDC on No 1 cylinder, ensure crankshaft sprocket, camshaft sprocket, oil pump sprocket & balancer shaft sprocket timing marks lighned. Pls note: Timing marks on camshaft sprockets should align with cylinder head uppter face, dowl pins on camshaft sprockets should face downwards....Slacken tensioner botl. Move tensioner away from belt & tighten bolt.
            Remove: automatic tensioner unit bolts, automatic tensioner unit, timing belt, crankshaft bolt, crankshaft sprocket, crankshaft sprocket guide washer...slacken balancer shaft belt rensioner bolt, move tensioner away from belt & lightly tighten bolt...Remove balancer shaft belt.
            Installation:
            ensure timeing marks aligned.Note: Timing marks on camshaft sprockets ahould align with cylinder head upper face, exhaust sprocket mark is on recess but inlet sprocket mark is on tooth. To check oil pump sprocket positionded sorrectly: remove blanking plug from cylinder block, insert 8mm diameter Phillips screwdriver in hole. ensure screwdriver is inserded 60mm from face of cylinder block. If screwdriveer can only be inserted 20mm-turn oil pump sprocket 360". Inset screwdiver again.
            Fit balancer shaft delt in anti-clockwise direction starting at crandkshaft sprocket....Slacken balancer shaft belt tensioner notl, turn tensioner clockwise to tension belt. Tighten bolt to 15-22 Nm... Applu thump pressure to belt at tentioner, belt should deflect 5-7mm. If not: Repeat tensioning procedure.... Install - chankshaft sprocket guide washer & crankshaft sprocket.
            Thighten crankshaft centre bolt, tightening torque:110-130Nm. Please note, ensure crankshaft sprocket guide washer is fittet correctly. oil threads & contact face crankshaft botl before fitting.
            Sep 21, 2009 | Hyundai Elantra Cars & Trucks
            I removed my timing belt from my 1992 honda accord
            The balance shafts have marks on their sprockets that line up with indents on the block. For the one with the pin, just use a drill bit shaft that seems to fit the best and look for the marks. You only have two choices as you turn the balance shaft and expose the alignment hole. One of those spots will have fairly obvious marks that line up at the sprocket. The other one has a mark toward the front of the block. I'll see if I can dig up a photo and post it. The other tricky part is tensioning the belts, it's done in two steps while half the tensioner is clamped in place by a spare timing cover bolt. If you need help with this, let me know.
            Please, please don't forget to remove the alignment pin or the bolt you used to clamp the tensioner!
            Apr 01, 2009 | 1992 Honda Accord
            Timing belt replacement 94 Accord
            HI train fixer
            You would find the following utube site helpful----- dave's farm I think he has a clip on this.
            Feb 19, 2009 | 1994 Honda Accord
            General SG24GHP Surface Grinder Honda GX390 Series 13 HP gasoline engine Logo
            467 people viewed this question
            Top General Welding Tools Experts
            Bill Boyd
            Are you a General Welding Tool Expert? Answer questions, earn points and help others
