The door on our Omega front load washing machine has been forced open when in the lock position. It is not broken. How do you release the lock so that the door is activated as closed
The start button is not activating because the door latch has been pulled open before the machine allowed its release. We need to reset the latch lock as it is not broken so the machine recognises that the door is shut.
  • dyard248
    dyard248 Jan 13, 2013
    Tool: We cut a piece a wire about 10 inches long from a wire clothes hanger. On one end we bent 1/2 inch of the wire in a 90 degree angle with needle nose pliers. On the other end of wire we put another bend at least three inches.(this end will be your handle end) Process of using homemade tool to release latch: Make sure washing machine is on a wash cycle. Use flash light to locate latch in the locking catch. Insert the small bend of the tool into the locking catch. Then hook onto the latch and pull out --apply a small amount of pressure -- about three lbs of pressure) Then at the same time you are pulling, press in on the door release button (the little white button above the latch hole where you now have the wire inserted). As your are pulling with little pressure on the latch, hold the little white button in and press the start /stop button. You should hear the door lock. Let machine start working. (about ten seconds) Now push start/stop button again and you should hear door lock release. Your lock catch should give away. This worked for us.
  • Washing Mach... Master
  • 17,130 Answers
Please check this link for tips: door lock
Posted on Jan 12, 2013
SOURCE: Door locked open
Posted on Feb 19, 2007
Kimi
  • 277 Answers
SOURCE: Door latch is in "LOCKED" position however the door is open!
It is possible that you have a problem with the door?s sensor, maybe it?s turned off or maybe some water fell on it. This is the reason why the micro controller interpret that the door is still open, and that?s why the washing procedure does not start. You have to find the manual and determine where is the location of the sensor and then see in what state it is (Turned off, wet, or damaged)
Posted on Jul 12, 2007
the dr
  • 447 Answers
SOURCE: help needed indesit washing machine
well it would help to know brand/model#
Posted on Oct 03, 2007
SOURCE: Broken front door
you need to buy a new 'handle'. to open the door for the time being, disconnect power and then use a coat hangar to pull the latch towards you, ie. outwards
Posted on Jun 09, 2008
SOURCE: FRONT LOADER DOOR LOCK WONT OPEN OR JAMMED
On a Bosch wfmc3200uc there is a green plastic string, similar to fishing line, located behind the round panel on the front of the machine. It is attached to the top right of the round black piece. Just give a slight tug this will release the lock.
Posted on Oct 21, 2008
LG 1056QD front load washer door will not open. It's locked. I have tried forcing it open but didnt work. Any suggestions please?
sensor is not fully trip to open position check the sensor there must be a broken plastic thats prevent the sensor in open position the sensor is located inside the machine behind the door
Oct 26, 2013 | LG F1402FDS6 Front Load Washer
Door will not open. Have tried emergency lock release on p. 29. Still does not open. Have unplugged for 1 hr. Does not open.
emergency lock as in the release mechanism inside the access door on the lower right corner of the face of the washer? try pushing in on the door with force will doing this
Jan 20, 2011 | Bosch Axxis+ WFR 2460 Front Load Washer
I have a front louder newer model samsung washing machine. The door was forced opened during cycle and now the lock is still in the locked position and I cannot reclose the door or get the locked to unlock...
The machine has to reset to bringg tthe lock to release, check the link to the lock settings to make the program complete the cycle and release the lock. Do not force it as you end up damaging.
Sep 01, 2010 | Samsung WF206ANS Front Load Washer
How do i open the door on hotpoint WD440, latch is broken?
Remove the top cover, and release the door catch from inside the washer, you will probably need a screwdriver or similar to do do this.
You will need to replace the door catch and spring, and possibly the door lock, as it may break when you force the door open.
Please rate my solution.
Thanks.
Nov 06, 2009 | Hotpoint Aquarius WD640 Front Load...
Lg washing machine wm-1460fhd door locked wont open
We have a WM-1480FHD, with the door stuck shut. It appears the door release mechanism in the actual door has broken, so when you pull the lver part, the catch is not released. You need to get a very flat knife,insert between the door and the front of the machine, right in the middle behind the release handle and push the hook towards the right side of the machine.Once open, you can check the release mechanism in the actual door. Ours is broken, so need to sort out how to repair/replace it next!
Jun 10, 2009 | LG WM-1480FHD Front Load Washer
Fixing broken door lock of Indesit W123X washing Machine
no easy way to open
disconnect from mains
take top off. feel down the front to where the door lock is and see if you can feel the door peg sticking thro the door interlock. force this with your fingers and with luck the door will open
if can't do this way, break handle off and lever peg with a small screwdriver
you can buy a handle kit complete. fitting this is not difficult - split the door and all will be revealed advise you make a carefull note of where springs go etc before you start stripping it down or take a few fotos if you have a digicam
Jul 10, 2008 | Indesit W 123 Front Load Washer
WASHING MACHINE awm 8163
The door will never open unless the timer is in the off position. Sometimes there is an additional time delay before it will release. If someone tried to force the door they probably bent the latch release. It needs to be replaced.
May 23, 2008 | Frigidaire GLTR1670A Front Load Washer
WF100 door wont open
The interlock has jammed, first try gently pushing the door frame on the latch side of the door and then hit the outer door frame with your fist, not too hard but a reasonable bang this may release the door, if this works spray a lubricant into the latch hole in the panel, open and close the door a few times before reusing, if this fails then you have to force the door open, the best way is to remove the lid and manouver the door lock from the inside, either the lock or the latck will eventually break, this is unavoidable, then replace the interlock and any other broken part.
Regards
Advisor
Nov 17, 2007 | Hotpoint Aquarius WF000 Front Load Washer
LG 1480fhd
Try first to unplug the power cable and see if it allow you to open the door. In case it will not help, you have to raise the top of the washer to get to the switch and release it manually (The switch is inside the washing machine main housing near the door frame). Good luck
Sep 03, 2007 | LG WM-1480FHD Front Load Washer
Hotpoint Ultima extra WD72
There are 3 possibilities 1 altough the water as drianed the pressure switch as not released due to blocake in the filter, or the interlock has jammed on the closed position which means it will have to forced open or the last fault could be the power board has gone.
Feb 28, 2007 | Hotpoint Ultima WD72 Front Load...
Washing Machines Logo
64 people viewed this question
Top Washing Machines Experts
