Question about Maytag MAH6700AWW Neptune Front-Load Washer
How can I drain my machine
Door will not unlock and machine is not draining
    New Friend:
Unplug & plug the machine. Then hit the Draine cycle. This has worked for us in the past.
Posted on Jan 12, 2013
Whirlpool Duet washer does not indicate end of cycle and unlock door
Most times this problem can be caused by a blocked tube to the pressure switch,..
Mar 03, 2014 | Whirlpool Washing Machines
Wash machine will not complete spinnging cycle & door will not unlock?HELP!!!!!!!!!!!!!!!!!!!!!!!!!
Hi.
Door does not unlock because there is water inside the machine.
Before unlocking you need to disconnect power. With power off remove trim at the base and access the drain pump filter. Open the housing and collect water. Also check the drain hose at the back.
The fault is usually either drain problem or defective door latch. I resumed here the full troubleshooting : If you have no spin there may be different reasons behind the problem. Before advancing to spin
Regards.
Ginko.
Mar 07, 2011 | Maytag High-Efficiency 2.4 cu. ft....
Amana tandem 7300 stopped ,door is locked wash light is beeping
Door won't unlock
Did all of the water drain out of the washer during the spin? Select DRAIN & SPIN to remove any water remaining in the washer. The washer door will unlock at the end of the drain.
Is the door locked and is the "Add Garment" light on? Press START/PAUSE once. The door will unlock.
Nov 28, 2010 | Amana Washing Machines
My maytag washer mah-24 have a "nd" msg. which mean "not draining" and now i cannot open the door to take the clothes out. pls. help.
Unlocking the door:
Turn on the washer, but don't start any wash cycles. After a few minutes, the door should unlock itself.
Troubleshooting the "nd" message:
"nd" means "no drain". Empty the (now unlocked) washer and fill the wash tub with just enough water to see a bit of water at the bottom of the tub. Run a drain cycle and check a) if it drains and b) if there are any unusual noises while it is draining. If either event occurs during the drain cycle, the drain pump may have to be repaired/replaced.
Nov 25, 2010 | Maytag MAH2400A Front Load Washer
Cnt get door unlocked on washer
If water is in machine drop drain hose to floor level to drain off door should now open..good luck
Sep 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I get an error code: F dU and my washer won't drain properly
I too, had the same issue with the door not opening. My solution was to unplug the power cord and then plug it back in and press the green button's as if to start a cycle and while it starts putting water into the washer I put my knee and weight into the door lock area and held pressure from my knee and press the red stop button until the lights went out, and I took my knee off the door lock area and opened the door!!! No taking off the lower panel.
If this works for you too please email me email4millers@cinci.rr.com.
Nov 07, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Door will not unlock need to get clothes out
whooaaa put down the ha\mmer, it wont open if theres too much water in unit. there is a manual release, but you have to remove the lower service panel to reach it.after removing the panel youll need to stick your hand up along side the front panel right hand side. the lowest ponit of the door latch/lock assy has a quarter sized handle that youll need to pull to relesae the door mechinism., WARNING if there is water visble through the door and you open it you will get wet...before trying the manual release option turn off the water supply and set the machine for drain/spin cycle and see if the drain pump turns on to release enough water to opne the door on its own,if the drain pumps only humms and doenst drain, then theres the issue you have something stuck in the drain pump. in which casse youll need to remove the lower panel and free the clog anyway.
Oct 12, 2008 | Kenmore Elite 45986 Front Load Washer
Door on washer will not open
Select Drain/Spin to remove any water remaining in the washer. The washer door wil unlock at the end of the spin.The washer door will not unlock if the unit has not drained.
Nov 09, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Maytag MAH6700AWW Neptune Front-Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
