Question about Antec LanBoy Air Blue
Where can I fine Antec LanBoy Air Yellow replacement parts
5.25" side rails
HOW TO FIX ANTEC AR-352
Unfortunately, there are not many parts available off the shelf to repair these. It would be simpler to get a power supply with a greater wattage rating than the one you have now.
Dec 06, 2016 | Antec Computers & Internet
How do i mount my 650 laser sight to my bone collector rifle.
Red Laser Sight 650nm Weaver rail mount - Gamo USA
www.gamousa.com > Optics > Airgun Lasers and Lights
650nm Red Laser Sight with Weaver style rail mount.
Gamo airgun accessories, spare parts and products ' Gamo ...
www.gamousa.com/category.aspx?catID=4
Air Rifle Scope Mounts/Rails. Air Rifle Scope Mounts/Rails. Air Rifle Sights. Replaceable sights for air rifles. Air Rifle Spare Parts. Replaceable parts for air rifles.
Dec 25, 2015 | Laser Optics
Computer solid yellow light
you need to take it to a tech shop so there can see what the problem of that yellow light i think the yellow light maybe the protection light or wat go and see the technician guys...
Oct 20, 2013 | Antec Computers & Internet
Schematic atx diagram
I give up! Why would you need a schematic for a computer power supply? I've been in the computer business for over 30 years and have never needed a power supply schematic. Just curious!
Sep 18, 2013 | Antec BP350 350-Watt Power Supply
I have an older FR350 nailer. The coil return spring broke. I have the replacement and want to fix it. Do I have to take the whole nail guid assembly off to replace this part!
The best way to replace the spring is to remove the rails entirely. Take closeup photos of the gun from all sides with your digital camera or camera phone to help you with placement of all screws. You will need small clamp, small vicegrips and paperclip or piece of soft wire with small hook bent on one end to temp hold spring in place. With rails in hand check if pusher will slide out front of rails (some rails have a small casting preventing pusher from coming out front ~ remove tailpiece and slide out back ). Locate small screw /nut holding spring in place (keep this side of rails facing you). With new spring in place slide pusher into rails until you can catch the eye of the spring with bent wire at front of rails. While holding wire with vicegrip pull back pusher a few inches and clamp in place with c-clamp. Pull or let in bent wire to align eye of spring to attachment hole and install screw (you can leave bent wire in eye and just break off later. With screw attached break off wire and install rails to gun. Check sliding action of pusher before installing bolts at rear of rails. The pusher on some porter cable guns have plastic sliders that easily break with normal use and should be replaced as needed. Good luck.
Feb 08, 2011 | Porter Cable Air Tools & Compressors
I need rails for my antec computer case
http://www.fadfusion.com/selection.php?product_item_number=10020800638
Might not be the exact model for yours but a basic search on this site will provide your given its model
Mar 27, 2010 | Antec Soho File Server SX1040B-II Black...
Yes I need to replace a sound board,But know how to get into the computer, how do I open side to place board in? Its an Antec 500 I think
lay it on its side and there should be two or three screws on the back. unscrew those and the side should just pop right out.hope this helps
~good luck
Jul 15, 2009 | Antec SmartPower SP-500 (ASKU37152)...
Antec Phantom 500 burned out
u can buy a ps tester on ebay to make sure all rails are ok 5 bucks for it easy to use great tool to have dont have to be bunrt to have bad rail i seen it
Jan 09, 2008 | Antec Phantom 500 (PHANTOM500) 500-Watt...
Antec LanBoy Air Blue Logo
283 people viewed this question
Top Antec Computers & Internet Experts
Steven Wander
Steven Wander
Dimitar Todorov
Julie Endres
Are you an Antec Computer and Internet Expert? Answer questions, earn points and help others
