Hoover Elite 920 doesn't work if 'cold' is select, but if I swap the pipes around and select 'hot', it starts up
When washing machine temp is set to cold, the cycle will not start. If it is set to hot, it starts fine but stops in the deep rinse cycle (needs to be manually moved past this point when it stops).
  • 209 Answers
SOURCE: Hoover elite 930 top loader washing machine
I am a recently retired appliance engineer of 20 years start with checking the other solenoid, the conditioner one, it may be that that is not working, and double check the cold one, remove the two wires and check for a circuit, it may be actually filing up initially with hot water without realising it, always work with safety remove the plug before removing panels etc if i have helped rate me please
Posted on Sep 09, 2007
SOURCE: hoover 600mb 6.0 kg top load washing machine (not as below)
Machine unbalanced or belt is worn maybe
Posted on Apr 04, 2008
SOURCE: hoover 750L top loader washing machine
I had this problem. I alternated the hot and cold water valves (changing over the wiring) and then hot tap then dribbled instead of the cold. Replacement part i believe is around $35AU
Posted on Jan 03, 2009
beltronic205
  • 1467 Answers
SOURCE: We have a Hoover select 1500 washing machine. It
Could be but also could be rinse water valve not operating due to faulty solonoid. it does a final rinse / softner before spinning if valve faulty then no spin advance....
Posted on Nov 11, 2009
  • 72 Answers
SOURCE: My fisher and paykel smartdrive 058 which has a
i am pretty sure its the main board, the easiest way to solve the problem is replace a the main board with a secondhand board, as well as obtaining a bag of spare parts, out a good working machine with faulty seals. You may have faulty seals if the machine is dormant for 3 years. I advise people never use washing powder in their washing machines, just use liquid detergent like Cold Power. the washing powder cakes up in the machine and when harden can be very abrasive and destroy the seals.
Posted on Dec 07, 2011
Hoover elite washing machine
FIXYA has no idea of any parts for hoover machine . contact hoover direct
Oct 23, 2017 | Washing Machines
Hoover elite 920 will not fill with water
It sounds like a cold water inlet valve is no working
and needs to be replaced
Nov 19, 2013 | Hoover Washing Machines
Whirlpool model WTW5310VQO
i've found problems with the temp. switch on this washer part number W10184148 and it's around 40 dollars,also on the rinse cycle the washer only uses cold water.what happens when you use just the hot?i had a lady that her water would start to fill and then the water would stop and the pipes in the house would start making a banging sound.if you order the part from http://www.repairclinic.com/PartDetail/Switch/W10184148/1468990 repair clinic and if this isn't your problem which i think it is from how you discribe it you can send the part back and get your money back for up to a year.good luck with your washer and next time you buy something and it doesn't work right get right on it
Mar 14, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
My Hoover elite 920 goes through it's cycle put
the pump is bad. not worth the repair bill. get a new washer
Nov 03, 2011 | Hoover Washing Machines
Do you need a hot water supply into a hoover six 1300
If it has only one water supply pipe the answer is clearly no as you will be aware ;-0)
If it needs a hot and cold supply, but you do not have a hot supply convenient, you will need to purchase, from a hardware (?) store, a 'Y' adapter. Upside down the single end (internal thread) screws into the cold water supply and the hot and cold washer pipes screw into the double end (external threads). The washer is fooled into thinking it has hot and cold! When it expects hot, it opens its hot valve but instead gets the cold water and has to heat it up. It will therefore take longer for the machine to do the washing. When it wants cold for rinses, it opens its cold valve and gets the same water! Simple ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Jul 12, 2011 | Washing Machines
Have been given Hoover HC6-110 (fitted with hot
This machine does not have a heater. You could use a Y connector or just cap off the hot and only use the cold settings.
Feb 24, 2010 | Hoover HC6 110M Front Load Washer
Hoover 750L top loader washing machine
Dec 29, 2007 | Washing Machines
Hoover Elite 1205 washing machine
Does an Hoover elite 920 gearbox fit the hoover elite 1205 thanks
Sep 18, 2007 | Washing Machines
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
