Question about Sennheiser Pc 350 Collapsible Gaming Headset With Vol Control &
Sennheiser PC350 mic not working
The mic stopped working and it may be the mute switch or a wire broken.
4 Suggested Answers
rockdiarylv
  • 27 Answers
SOURCE: sennheiser e835 wireless mic won't turn on
how long did you hold the on button for? press it longer
Posted on Mar 02, 2009
  • 11 Answers
SOURCE: On/off button fell off Sennheiser wireless mic
This is quite common with G2's, and really annoying!
If you are lucky, 50% of the time the red button is pushed inside the mic.
You need to remove the bottom section:
- open the battery compartment
- there should be 3 star-bit screws around the outside (remove)
- pull the bottom of the mic off
If the red button is not inside, they are available as a spare part from Sennheiser dealers.
Be carefull when putting the mic back together, it needs to line up correctly with the internal guides, forcing the base back on could damage the ribbon cable. when the line-up is correct it slides on very easily.
Best of luck.
PTB
Posted on Jul 07, 2009
  • 611 Answers
SOURCE: I'm looking for micro switch: SH ES-T 0.4 VA MAX,
Try calling Sennheiser to see if they have the part.
Posted on Feb 14, 2011
Mute switch stopped working. Help please.
Try to get a one track sound mixer and your problem will be solved.
Feb 13, 2015 | Sennheiser Audio Players & Recorders
How do i sync my mic to my receiveri have a ew 100 g3 and after some kids were playing with it, I can't get any sound
Pressing the sync button whilst holding the mic close to the IR unit on the receiver should sync things back up. If this has already been done things to try next are as follows.
RF Mute. Press and release the power button. RF Mute should be displayed. Press the roccker switch and select RF mute OFF, press the rocker switch again.
Check in the advanced menu that the pilot tone is on on the handheld AND the receiver.
Jan 23, 2014 | Sennheiser Evolution G2 100 Series UHF...
Sennheiser ew135 mutes at random moments during a show and it also displays MUTE on the LCD screen. Any solutions would be greatly appreciated. Thanks!
It sounds like wireless signal problems...the receiver will mute when it loese signal from the transmitter (mic).
1. Raise the receiver up higher in the performance area.
2. Stay within the recommended range/distance stated in the owners manual.
3. Read "If a problem occurs" section of owners manual...page 31 "MUTE appears on display panel." For some reason I can't link the owners manual here, but sweetwater music has it at the bottom of the Sennheiser ew135 sales page.
Sep 10, 2013 | Audio Players & Recorders
How should I connect an ATM73a headset to a sennheiser SK300
Audio Technica and Sennheiser each have proprietary connectors for their mics. A lot of times the mics require Phantom power which is drawn from the battery of the pack.This is important as the mic will need to be wired correctly to function.
The first thing you will need is the correct plug from the company. Check with Sennheiser customer Support for the correct part. If you aren't extremely good at soldering, do not attempt this. You can change the plug but the wires are extremely delicate and can short easily. Moreover because of the phantom power, the plug must be wired correctly for the mic to function, or you may end up damaging the mic by sending phantom power up the wrong line. I would advise having a music store or pro audio service that handles these products do the wiring for you. If you feel you are up to it, you can do it yourself, but be careful.
Feb 19, 2011 | Sennheiser SK 300 G2 Wireless Bodypack...
Sound only comes through one channel, have you any idea why? Norman Bevan
Most likely there is a broken wire inside the mic. You'll have to disassemble it to fix it, and it's not what I would call an easy job. Get a tech to help you, if you can. Chances are that it's just a wire that's broken and needs resoldering.
Also, on the following page, they talk about determining whether the problem is with the mic or headset, which should always be done first.
Sennheiser recommends sending it in for repair, and here's their site:
http://www.sennheiserusa.com/serviceandsupport_faqs_other-questions
Good luck, and hope this helps.
Nov 15, 2010 | Sennheiser K6 Professional Microphone
Wireless headset receiver ALWAS says mute
You must use a compatible transmitter, not just any old one on the right frequency.
Oct 03, 2009 | Sennheiser (EW100ENGG2C) Professional...
How do you remove the mute from the reciever?
turn the dial at the base of the mic,til u see the word mute.flick the switch away from the white dot.to turn mute off.
Mar 14, 2009 | Sennheiser (EW100ENGG2C) Professional...
Broken power switch
If you have a G1 SKM100 mic, the small on/off switch is an SKQLLC Tact switch made by ALPS. I don't know what's in a G2 or anything about the ones with the orange button. I just replaced the on/off switch and it took about 20mins. It's a bit fiddly but not too bad so long as you have a reasonably fine-tipped soldering iron. If you're in the USA then it look like there are a number of distributors who will sell one-offs. I'm in the UK and had to go back to the place I originally bought the mic from (DM music), who got it from Sennheiser and then sold it to me. For some reason Sennheiser wouldn't sell it to me direct. Good luck.
John
Dec 14, 2007 | Sennheiser SKM100 Wireless Handheld...
Mic doesnt work
Totally the same with me.. any soloutions anyone?
Dec 26, 2006 | Sennheiser PC130 Consumer Headset
Sennheiser Pc 350 Collapsible Gaming Headset With Vol Control & Logo
24 people viewed this question
Top Sennheiser Radio Communications Experts
 Grubhead
Grubhead
Michial Gueffroy
Are you a Sennheiser Radio Communication Expert? Answer questions, earn points and help others
