Question about Electrolux EIFLW55I Washer
Sewer odor when draining - Electrolux EIFLW55I Washer
  • Electrolux Master
  • 17,130 Answers
Please check this link for tips for maintenance of your machine. click this link to keep it odour free.
Posted on Jan 12, 2013
What does a freon leak in a deep freeze smell like?
Freon is odorless. A sewer odor could be caused by an unused sink, tub, or floor drain trap where the water has evaporated. A gas odor is a very serious issue that should be checked immediately by the gas company or the fire department. Gas can seep in from a leak outside the house or accumulate in a wall if a fitting fails.
Aug 26, 2014 | Kitchen Appliances - Others
Smell of rotten eggs in shower drain
This is likely "sewer gas" and can cause headaches, dizziness, etc. if you remain exposed to it for a prolonged period of time. This originates mostly in the drain openings of fixtures that are seldom used - such as sinks and showers of basements, guest rooms, etc.
When these fixtures do not get used regularly, the relatively small amount of water that is designed to always be present in the "trap" portion of the drain pipe eventually evaporates. This trapped water prevents the the gasses in the sewer / septic system from passing through the trap. Without it, these gasses will rise through the pipes connected to the sewer / septic system and exit into your living space via the drain opening in the floor drain, shower, tub, sink and even toilet if left unused long enough.
It is usually resolved very easily by slowly pouring about a 1/2 gallon of water down the drain. The water now isolates the drain opening from the sewer / septic system and effectively stops odors from escaping. If you find that this is happening regularly (often from floor drains in dry basements) you should slowly pour water 1/2 gallon of water into the drain, and then add 2 to 3 ounces of cooking oil. The oil is lighter than water and will sit on top of the water surface. Oil does not evaporate and blocks the water from evaporating through it. Evaporation of the water in the trap will take place from the sewer / septic side of the trap, but it occurs at a much slower rate.
After filling the traps with water or water & oil, just ventilate and you're done!
Apr 03, 2014 | Maax Breeze: One Piece Round Shower...
Sewer smell coming from sink when water runs into drain
is there a trap in the sink drain just under the sink
if not put one in
a trap holds water in a bend so sewer gases dont come up through the drain
Nov 20, 2013 | Dishwashers
Smelly kitchen drain
Copy following link for sewer smell:
http://waterheatertimer.org/Plumbing-Vents.html
Copy following link if drain is clogged, and that appears to be source of smell: Use white vinegar and or hydrogen peroxide:
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html#tubular
Copy following link if rotten-egg odor is coming from hot water:
http://waterheatertimer.org/Replace-anode-rod.html#smell
Add a comment... and it is possible that fixya will sent me note, and I can answer further questiions
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jul 05, 2013 | Home
Washing machine sewer odor
The drain pipe that your drain hose goes into is more than likely the problem. The drain pipes should have a p trap which looks kind of like an S- shape the water stays in the trap preventing the smell from backing into your home . If there is none, install one.
Jun 09, 2013 | Washing Machines
Odor coming from washing machine - smells like sewer gas
The odor coming from your washing could indicate a problem with your
hot water heater or possibly your city's cold water supply line.
In some cases the odor might be originating from the drain located adjacent to
the washing machine. During long periods of inactivity, if no water is flushed
down the drain, a sewer smell will be emitted from the drain. To alleviate
this condition, just flush water down the drain.
I hope this helps you solve your problem.
Jan 17, 2011 | GE Washing Machines
When machine pumps out the smell comes through the sink
All plumbing drains whether under a sink or the stand pipe drain, for a washer, are required by LAW to have a trap to prevent the sewer gases from entering a home.
Sewer gases are dangerous in many ways, not the least of which is the terrible smell. Sewer gas can build up and if allowed to accumulate near an appliance that operates on gas (LP or natural) can combust and cause a fire and/or an explosion.
Yes, if you can do the installation youself, do it ASAP, or contact a licensed plumber and have installed a proper drain trap for the sink and also make sure the drain that the washer is draining into, also has a trap in it.
This will have a profound impact on the smell and will help alleviate foul odors from your sewer lines.
Hope you found this Very Helpful and best regards!
Sep 22, 2009 | Whirlpool AWM5145/2 Front Load Washer
Odor from Decolav bottle trap
there really should be a trap with a bend in it on the system at somepoint to prevent odour ingress?
Nov 22, 2008 | Deco Lav DECOLAV Chrome Polished Grid...
Dishwasher has odor
Check the drain line under the kitchen sink. The drain line is supposed to run from the bottom of the cabinet, and run as high in the cabinet as you can get, (up to the bottom of the counter top) then connect the drain. This is called an air gap, and helps keep a little water in the drain line, which will prevent sewer gases from entering your dishwasher.
Please rate this solution.
Aug 03, 2008 | Siemens 24 in. SL84A305UC Built-in...
Electrolux EIFLW55I Washer Logo
Top Electrolux Washing Machines Experts
Tim Whalen
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
