Hotpoint aquriaus dryer door lock broke replaced but found catch had also broken how do i replace this part it seems i have to take the whole dryer apart to replace this
Door handle snapped then found catch on other side had also broken can this be replaced because it seems i have to go from the inside of the appliance to get to it
  • Washing Mach... Master
  • 17,130 Answers
Check this link for tips to replace the Door lock.
Click on Door lock
Posted on Jan 12, 2013
SOURCE: Broken Handle
Contact this person and his company. They have the handle kit for the WD-2100
Darrell Klein National Service Director
Westland Sales /
Splendide Combination Washer Dryers
15650 SE 102nd Ave.
Clackamas, OR 97015
503-210-3914
darrell.klein@westlandsales.com
Posted on Jul 28, 2008
SOURCE: Broken door handle Hotpoint WD860
Managed to work it out, you have to slide the outer door case away from the handle locking mechanism, slide left and move away (after undoing the 6 screws on the inside) :-)
Posted on Dec 05, 2008
SOURCE: broken door handle...
I have the same problem and I have a makeshift solution which I was able to do in 45 minutes and total cost was less than $1.
Step 1: Remove door from machine.
Step 2: Disassemble door with the two plastic donut shells. This means removing 6 or so flathead screws. Take care to note alignment of glass parts because they aren't perfect circles and only fit one way.
Step 3: Pull out pin that threads the spring and broken plastic handle remnant and metal latch piece.
Step 4: Discard broken plastic and replace the rest of the apparatus. The metal latch can move up and down, but that's ok.
Step 5: Purchase a paint-can opener:
http://www.istockphoto.com/file_thumbview_approve/525566/2/istockphoto_525566_opener_for_paint_can.jpg
Step 6: Re-attach door.
Step 7: You can use the paint-can opener to the right of the latch to lever-open and lever close the latch in order to open and close the door.
Cheap, easy. Not pretty at all. Definitely something your friends would make fun of you for doing, but it saves you $1,000 of a new machine, in this economy.
Posted on Jan 17, 2009
  • 3 Answers
SOURCE: Broken door handle on Splendid 2100 RV Washer/Dryer Combo
The Splendide distributor in OR sells handles for about $45.
Posted on Jan 28, 2009
  • 566 Answers
SOURCE: door handle of washing machine broken
if clothes are still in washer? and machine has finished cycles? then handle broke so unable to open ??? your best option is to unplug/ and if necessary disconnect water supply hoses then remove the top screws from rear panel which also secure the top panel as you will observe ? then pull backwards top panel and loft off ? you now have access/visual of the door catch inside front machine look?? at the catch and you will see how it locks ? you can lever the catch gently and door opens to fit a new door catch is easy diy and not expensive if you are confident usual problem these break ? is the time delay micro switch sticks with age /moisture try dw40 and work plunger b4 you refit door back after replacing handle/catch assy
Posted on Feb 16, 2009
Door locked,cant open
just get an old door from any ariston..hotpoint or indersit machine make sure it is the same size
Jan 12, 2014 | Ariston Technologies Ariston AWD12 Front...
Door will not open on hotpoint bwd 129 catch may be broken
Your door lock assembly needs to be replaced to open the door try the following procedure.
To open the door, get a piece of string and feed it into the door recess, work it around until both ends come out opposite the door handle.
Pull the string to the side and with your other hand pull the door open.
You will need to get a replacement lock assembly for the machine which isn't too hard to fit if you are a bit handy with tools.
Mar 07, 2012 | Hotpoint Washing Machines
Door will not open
Remove the top cover, and release the door catch from inside the washer, you will probably need a screwdriver or similar to do do this.You will need to replace the door catch and spring, and possibly the door lock, as it may break when you force the door open.
Thank you !!
Jun 26, 2010 | Hotpoint Aquarius WD640 Front Load...
How do i open the door on hotpoint WD440, latch is broken?
Please rate my solution.
Thanks.
Nov 06, 2009 | Hotpoint Aquarius WD640 Front Load...
How do I repair the handle on a Hotpoint Aquarius? The handle has not come off just door catch is broken.
Remove all vvisible screws securing both parts of door, and seperate the 2 halves, be careful you do not drop the door glass.
This will enable you to see what is broken, and what needs to be replaced
Thanks.
Nov 04, 2009 | Hotpoint Aquarius WD640 Front Load...
Door handle of washing machine broken
Feb 16, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WF440 Washing m/c - Door Lock light
You have probably knocked of the connector or the catch (and on these it is very fragile as I have changed the catch 3 times on mine) is broken
Jan 22, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint aquarius 1000wm 20 I have to bash front door to start
I do not think it is the door lock that is faulty, more likely to be a weak or broken door spring or broken door catch.
I would replace these first,and then if it is still the same, then replace the door lock.
To replace the spring and or handle catch, undo all the screws that secure the 2 halves of the door, and prize apart the 2 halves,
Replace the spring and catch, reassemble the door.
Plz rate my solution.
Thanks.
Jan 07, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint CTD00 Door Catch Replacement
If yuo are referring to the catch on the door, then undo all the scews holding the 2 halves of the door together, and prize apart, fit new door catch.
If you mean the door lock, then you will have to remove the top cover and right hand side panel to access the door lock.
Hope this helps.
Plz rate this solution.
Thanks.
Dec 26, 2008 | Dryers
Dishwasher door won't close
OUrs did the same, it was a tiny spring that needed replacing. We just turned off at mains, unscrewed front and took out the unit. Took broken spring out and found one at our local DIY shop. fitted and put back in. ALOT cheaper than replacing the unit!
Oct 20, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
