Question about Mitsubishi XD280U Projector
I have a mitsubishi xd 280u it turns on and works gerat for 10 seconds then it shuts off and the power light flashes green end red what could this be
SOURCE: projector automatically shuts off immediately after turning it on
If your comfortable w/surface mount troubleshooting and soldering, download the service manual from elsewhere online. Part of the troubleshooting tree for this type of problem is to check the surface mount fuses on the underside on the Main PWB (schematic page 1/8). On mine, the 12V surface mount fuse, F3004 (2.3A) was open (quadrant C1 on the schematic). Replaced it, reassembled the projector (3 interlocks don't 'cha know) and it came up just fine.
Doug
Posted on Dec 10, 2007
Shuttle83
  • 1139 Answers
SOURCE: Projector will not project light (Mitsubishi LVP-X80U) LCD Proje.
Hello toma_leonard,
First check your lamp to make sure it is seated properly in the socket.
Then check all of your interlocks (see your manual for locations), these are usually located on any hatches or doors that allow access to the lamp and or fan area. Once you check your interlocks make sure the filter and fan area is clear of dust, (some projectors have air flow sensors), and the recheck the interlocks. Once this is done , If the interlocks are not broken, or the lamp fuse blown, the projector should be working. If not it is the lamp that needs changing.
I know this may be expensive, however these lamps do go bad, as much as we wish they would not.
If you still feel it is not the lamp, have a technician check the voltage levels to the lamp and the levels of the control board circuitry.
I hope this helps,
Thank you,
Shuttle83
Posted on Nov 20, 2008
SOURCE: alternating power and lamp status lights
...replace the lamp. The lamp is most likely WAYYYYY past its prime so I suggest starting there. Sometimes even if you had just replaced the lamp the new lamp could've blown. When there is no signal running through the lamp circuit there is no signal to the display sensor, which means no image.
hope this helps!
Posted on Feb 25, 2009
SOURCE: automatic power shut off
Hold right left and power all at the same time and it will reset...
Posted on Feb 28, 2009
joeshea123
  • 65 Answers
SOURCE: The projector suddenly shuts off.
have you check the filter?
Posted on Mar 27, 2009
Sanyo pcl-xu50 flashing red power light when i turn on my projector the light goes green it powers up for about 20 seconds then the power light changes to a red flashing one for about 10 seconds then back...
Projectors shut off when they overheat. They overheat when air does not move through the projector cooling it. This happens when the fans are not working or air filters/vents are not working.
Check to see whether the fans are working. If they are working, open the cover and see whether air filters/vents are covered with dust. If so clean them.
Sep 26, 2011 | Office Equipment & Supplies
Indoor unit start up as if the unit is fine then as soon asthe compressor is about to kick in (after 10 or 20 seconds) the green light on the front of the unit start flashing and the unit shuts down. went...
get the owners manuel and check q&a there should be a section that deals with the codes. the different sequences can help you trouble shoot. be careful the codes are not always correct. contact mitsubishi if you can't find. if all else fails call a repair person
Aug 06, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
Replaced bulb yesterday worked fine. Today light will not turn on. projector turns on both lights green for 10 seconds, then power goes red and status blinks green for about 5 seconds, then status light...
green green is power on, normal
then it tries to light the lamp, but it can't so the protection circuit comes activated.
you get red and green blinking
Then it goes to standby, red and off.
so something has happened to the lamp, or lamp ballast power supply.
Take the lamp out and check if all is OK with the 2 terminals in the connector, and the leads to the lamp are intact.
Failing that, I would suspect the ballast lamp power unit
Mar 25, 2011 | Mitsubishi HC1600 Projector
Projector screen turns off after 10-20 seconds
Is the projector receiving a source signal? if not it will power itself down after whatever time you have it set to do so when no signal is present.
Just an idea?
Jan 03, 2010 | NEC NP-1000 Projector
Green flashes then tv turns off
or a new lamp. you could first replace the lamp.
the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
Aug 23, 2008 | Sony KP-51HW40 51" Rear Projection...
Mitsubishi XD280U Projector Logo
49 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
